[ROM] OPPO T29 by pratikmore
Fully working Oppo Rom (MT6577,Jelly bean) : http://rapidshare.com/files/30356093...ppo_Rom_V2.zip
# All the bug solved,now you can use it as a Daily rom.
OPPO T29 rom ported from lenovo p770
Feature :
1)Smooth and very fast lighting rom.
2)very cool UI with lots of theme and features
3)different types of settings
Bugs:
1) Usb mounting issue (can be solved by chinese app installing on pc)
2)Front camera is not there because oppo has only rear camera
3)internal memory card you cant see in file explorer but in root explorer it can be usable.
capture :
http://forum.xda-dev...62&postcount=40
Modifié par spanish
Le wifi, je ne pense pas entre les captures et la sortie de la ROM beaucoup de temps a passé, je pense que le wifi fonctionne, sinon il l'aurait indiqué dans les bugs
  • 3 weeks later...
