tablette storex ezee805
J'ai acquis il y a peu une tablette storex. Ma fille a voulu installer le jeu des SIMS sur playstore. Cela ne fonctionnait pas. En regardant les forums, il était indiqué qu'il fallait installer lcd density pour augmenter la résolution à 240. Depuis, la tablette bloque sur la page de démarrage storex. j'ai suivi un tuto sur le forum au sujet d'adb mais rien n'y fait. Quelqu'un pourrait il m'aider svp ?
Merci d'avance !
ci-joint un copier-coller de mon adb :
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-serialno - prints: <serial-number>
adb status-window - continuously print device status for a specifie
d device
adb remount - remounts the /system partition on the device re
ad-write
adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
tloader or recovery program
adb reboot-bootloader - reboots the device into the bootloader
adb root - restarts the adbd daemon with root permissions
adb usb - restarts the adbd daemon listening on USB
adb tcpip <port> - restarts the adbd daemon listening on TCP on th
e specified port
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PPP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be u
pdated.
- If it is "system" or "data", only the corresponding partition
is updated.
environmental variables:
ADB_TRACE - Print debug information. A comma separated list
of the following values
1 or all, adb, sockets, packets, rwx, usb, sync
, sysdeps, transport, jdwp
ANDROID_SERIAL - The serial number to connect to. -s takes prior
ity over this if given.
ANDROID_LOG_TAGS - When used with the logcat option, only these de
bug tags are printed.
C:\adb>restor
'restor' n'est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
C:\adb>Adb Push c:\nouveau /sdcard
Android Debug Bridge version 1.0.26
-d - directs command to the only connected USB devic
e
returns an error if more than one USB device is
present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is r
unning.
-s <serial number> - directs command to the USB device or emulator w
ith
the given serial number. Overrides ANDROID_SERI
AL
environment variable.
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices - list all connected devices
connect <host>[:<port>] - connect to a device via TCP/IP
Port 5555 is used by default if no port number
is specified.
disconnect [<host>[:<port>]] - disconnect from a TCP/IP device.
is specified.
Using this command with no additional arguments
will disconnect from all connected TCP/IP devic
es.
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> [<local>] - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(-l means list but don't copy)
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] <file> - push this package file to the device and i
nstall it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data
('-s' means install on SD card instead of inter
nal storage)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories
adb bugreport - return all information from the device
that should be included in a bug report.
adb help - show this help message
adb version - show version num
DATAOPTS:
(no option) - don't touch the data partition
-w - wipe the data partition
-d - flash the data partition
scripting:
d device
ad-write
e specified port
networking:
pdated.
is updated.
C:\adb>adb shell ls -l /system
drwxr-xr-x root root 2013-03-18 01:15 app
drwxr-xr-x root shell 2013-03-18 01:06 bin
-rwxrwxrwx root root 2685 2013-05-18 19:11 build.prop
drwxr-xr-x root root 2013-03-18 01:06 etc
drwxr-xr-x root root 2013-03-18 01:06 fonts
drwxr-xr-x root root 2013-03-18 01:06 framework
drwxr-xr-x root root 2013-03-18 01:07 lib
drwxr-xr-x root root 2013-03-18 01:06 lost+found
drwxr-xr-x root root 2013-03-18 01:07 media
drwxr-xr-x root root 2013-03-18 01:06 tts
drwxr-xr-x root root 2013-03-18 01:06 usr
drwxr-xr-x root shell 2013-03-18 01:07 vendor
drwxr-xr-x root shell 2013-03-18 01:07 xbin
C:\adb>adb get /system/build.prop
e
present.
unning.
ith
AL
is specified.
is specified.
es.
device commands:
tcp:<port>
nstall it
nal storage)
DATAOPTS:
scripting:
d device
ad-write
e specified port
networking:
pdated.
is updated.
C:\adb>adb pull /system/build.prop
37 KB/s (2685 bytes in 0.069s)
C:\adb>
ci joint mon build.prop
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=JRO03H
ro.build.display.id=STOREX-dt-805F-yx-4.1.1-20130317
ro.build.version.incremental=20130317
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.1
ro.build.date=Sun Mar 17 18:51:47 CST 2013
ro.build.date.utc=1363517507
ro.build.type=eng
ro.build.user=root
ro.build.host=guangg-pc
ro.build.tags=release-keys
ro.product.model=eZee Tab805
ro.product.brand=STOREX
ro.product.name=rk30sdk
ro.product.device=rk30sdk
ro.product.board=rk30sdk
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=STOREX
ro.wifi.channels=
ro.board.platform=rk30xx
# ro.build.product is obsolete; use ro.product.device
ro.build.product=rk30sdk
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=STOREX-dt-805F-yx-4.1.1-20130317
ro.build.fingerprint=STOREX/rk30sdk/rk30sdk:4.1.1/JRO03H/20130317:eng/release-keys
ro.build.characteristics=tablet
# end build properties
# system.prop
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyUSB2
# ADDITIONAL_BUILD_PROPERTIES
ro.com.android.dateformat=MM-dd-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=80m
dalvik.vm.heapsize=384m
ro.config.facelock=enable_facelock
persist.facelock.detect_cutoff=5000
persist.facelock.recog_cutoff=5000
sys.bluetooth.module.mtk=0
sys.4in1.module.mtk=0
ro.product.locale.language=fr
ro.product.locale.region=FR
persist.sys.language=fr
persist.sys.country=FR
persist.sys.strictmode.visual=false
dalvik.vm.jniopts=warnonly
ro.rksdk.version=RK30_ANDROID4.1.1-SDK-v1.00.00
sys.hwc.compose_policy=6
sys.rkadb.root=0
ro.sf.fakerotation=true
ro.sf.hwrotation=270
ro.rk.MassStorage=false
wifi.interface=wlan0
ro.sf.lcd_density=120
ro.rk.screenoff_time=60000
ro.rk.def_brightness=200
ro.rk.homepage_base=http://www.google.com/webhp?client={CID}&source=android-home
ro.rk.install_non_market_apps=true
ro.default.size=100
persist.sys.timezone=Europe/Paris
ro.product.usbfactory=STOREX
wifi.supplicant_scan_interval=15
ro.opengles.version=131072
ro.factory.tool=0
ro.kernel.android.checkjni=0
ro.factory.storage_policy=0
persist.sys.usb.config=mass_storage
testing.mediascanner.skiplist=/mnt/sdcard/Android/
rild.libargs=-d_/dev/ttyUSB1
ril.pppchannel=/dev/ttyUSB2
rild.libpath=/system/lib/libril-rk29-dataonly.so
ril.function.dataonly=1
ro.product.version=1.0.0
ro.product.ota.host=www.rockchip.com:2300
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
j'ai changer la valeur 240 par 120 (ro.sf.lcd_density)
Modifié par ricco88
