bigyohann Posté(e) 19 mai 2013 Posté(e) 19 mai 2013 (modifié) Bon alors je vais vous présenter un nouveau thème: Ginger Revolution fait par la (D)evilTeam et modifié par leather.face Pour commencer ce qui a été modifier: - AccuweatherDaemon.apk - ClockPackage.apk - SamsungCamera.apk - SecBrowser.apk - SecCalculator2.apk - SecCalendar.apk - SecContacts.apk - SecEmail.apk - SecMms.apk - SecNoteMyFiles.apk - SecPhone.apk - SecSettings.apk - SystemUI.apk - Talk.apk - only odexed version - - framework-res.apk - twframework-res.apk - AndroidClock.ttf - AndroidClock_Highlight.ttf - AndroidClock_Solid.ttf - Clockopia.ttf - DroidSans.ttf - DroidSans-Bold.ttf - Roboto-Bold.ttf - Roboto-Regular.ttf Changelog en entier (Désolé la flemme de tout traduire :P ): 5/1/2013 - initial release 5/3/2013 - added deodexed version - added extra zip with cleaned statusbar - below - - deodexed flashable zip untested by me - rename in v1.5 5/5/2013 - many apk files themed - you can this see under the first post - Ginger Smileys in framework-res.apk - AccuWeatherDaemon.apk - tw-framework.apk themed - SecSettings.apk from faria - SystemUI.apk from faria - Blue Phone.apk 5/6/2013 - added to v2.2 - blue icons for the emergency_call (SecPhone.apk) - blue hooks in SecEmail.apk - blue and green contact icons in 1/ SecContacts.apk 5/7/2013 - added to v2.3 - new icons in ... - framework-res.apk 1/ keyguard_deafult_wallpaper.jpg 2/ emergency_default_wallpaper.png 3/ changed button on/off (screenshot) - ClockPackage.apk 1/ widget_alarm_clock_on.png 2/ widget_clock_alarm_ic_off.png 3/ alarm_icon_on.png 5/10/2013 - modified to XXAMD3 - a few png files modified 5/11/2013 - added deodexed flashable zip - GingerRev. 3.0 - 5/15/2013 - added new theme - Ginger Rev. v3.5 - - complete current and professional Ginger dialer - new modified in the folder: 1/ drawable-mcc310-mnc004-sw320dp-hdpi 2/ drawable-mcc310-mnc005-sw320dp-hdpi 3/ drawable-mcc310-mnc012-sw320dp-hdpi 4/ drawable-mcc311-mnc480-sw320dp-hdpi 5/ drawable-mcc450-mnc05-hdpi 6/ drawable-mcc450-mnc06-hdpi 7/ drawable-sw320dp-hdpi 8/ drawable-sw320dp-land-hdpi 5/16/2013 - added to v4.2 - Ginger Rev. - by me - modded files in: 1/ SecPhone.apk 2/ SystemUI.apk 3/ framework-res.apk - only odexed download version 1/ Talk.apk - what is themed: - SecPhone.apk ... 1/ call_img_conference.png 2/ call_img_unknown.png - SystemUI.apk ... 1/ New Ginger Rev. battery from AOKP with percent indicator 2/ stat_sys_battery.png and 3/ stat_sys_battery_charge_animation.png 4/ the battery also modded in the framework-res.apk - Talk.apk 1/ changed stock emos ... I added the Ginger emos - framework-res.apk 1/ stat_sys_battery.png 2/ stat_sys_battery_charge_animation.png 3/ default_wallpaper.jpg 4/ keyguard_wallpaper.jpg 5/ I added a new beats by dre default_wallpaper 6/ spinner_black_16.png 7/ spinner_black_20.png 8/ spinner_black_48.png 9/ spinner_black_76.png 10/ spinner_white_16.png 11/ spinner_white_20.png 12/ spinner_white_48.png 13/ spinner_white_76.png 5/18/2013 - added my theme to v4.6 - new Nexus 7 battery icon with - blueDroid load icon - this modified in ... 1/ SystemUI.apk 2/ framework-res.apk - new beats audio default and keyguard wallpaper in: 1/ framework-res.apk Installation: Bon alors là ca devient interressant parcequ'il y a plusieurs moyen d'installation ! Méthode 1 pour le script et rom ODEX ! -Télécharger le .rar -Dé zippez le -Lancez le script du thème (leather.face) -Si vous avez l'applications adb insecure tapez directement 2 sinon tapez 1 -Après un reboot le thème devrait être appliqué! Méthode 2 pour flasher via recovery et pour rom ODEX! -Avoir installé un recovery custom -Télécharger le .zip -Mettez le à la racine de la mémoire interne/externe -Flashez le (Install zip from Sdcard/Extsdcard) Méthode 3 pour flasher via recovery et pour rom DEODEXED! La même que la seconde méthode mais pas avec le même fichier :P Téléchargements : -Méthode 1 : ici -Méthode 2 : ici -Méthode 3 : ici Et pour retourner comme avant (Via recovery) : ici Et pour finir les screens : P.S:Je trouve l'icone de batterie assez moche sur le thème (sur les screen je l'ai changer) c'est pourquoi j'ai modifié l'icone de batterie et j'ai modifié un .zip pour le flasher via recovery: www.4shared.com/zip/6YtN1qQx/icone_batterie.html P.S 2: Mon icone il est pas tout le temps rose vous inquiétez pas :D Lien original: http://forum.xda-dev...d.php?t=2259191 Modifié 20 mai 2013 par bigyohann Citer
bigyohann Posté(e) 19 mai 2013 Auteur Posté(e) 19 mai 2013 Avec plaisir :D Au fait personne ne sait comment réduire les images direct par le forum ? Citer
danymat Posté(e) 19 mai 2013 Posté(e) 19 mai 2013 Touchwizz est une rom odex ou deodex? Envoyé depuis mon GT-I8190 avec Tapatalk Citer
bigyohann Posté(e) 20 mai 2013 Auteur Posté(e) 20 mai 2013 Touchwizz est une rom odex ou deodex?Envoyé depuis mon GT-I8190 avec Tapatalk Ça depend de ta ROM ,si tu es root tu vas dans system/app et tu regardes si ya des fichiers odexEnvoyé depuis mon GT-I8190 avec Tapatalk Citer
danymat Posté(e) 20 mai 2013 Posté(e) 20 mai 2013 Oui il y en a Envoyé depuis mon GT-I8190 avec Tapatalk Citer
danymat Posté(e) 20 mai 2013 Posté(e) 20 mai 2013 OK merci vous deux:D Envoyé depuis mon GT-I8190 avec Tapatalk Citer
bigyohann Posté(e) 20 mai 2013 Auteur Posté(e) 20 mai 2013 OK merci vous deux:DEnvoyé depuis mon GT-I8190 avec Tapatalk D'ailleurs il ya pas beaucoup plus d'application qui ont le thème sur une rom odex ! Envoyé depuis mon GT-I8190 avec Tapatalk Bon alors je vais vous présenter un nouveau thème: Ginger Revolution fait par la (D)evilTeam et modifié par leather.face Pour commencer ce qui a été modifier: - AccuweatherDaemon.apk - ClockPackage.apk - SamsungCamera.apk - SecBrowser.apk - SecCalculator2.apk - SecCalendar.apk - SecContacts.apk - SecEmail.apk - SecMms.apk - SecNoteMyFiles.apk - SecPhone.apk - SecSettings.apk - SystemUI.apk - Talk.apk - only odexed version - - framework-res.apk - twframework-res.apk - AndroidClock.ttf - AndroidClock_Highlight.ttf - AndroidClock_Solid.ttf - Clockopia.ttf - DroidSans.ttf - DroidSans-Bold.ttf - Roboto-Bold.ttf - Roboto-Regular.ttf Changelog en entier (Désolé la flemme de tout traduire :P ): 5/1/2013 - initial release 5/3/2013 - added deodexed version - added extra zip with cleaned statusbar - below - - deodexed flashable zip untested by me - rename in v1.5 5/5/2013 - many apk files themed - you can this see under the first post - Ginger Smileys in framework-res.apk - AccuWeatherDaemon.apk - tw-framework.apk themed - SecSettings.apk from faria - SystemUI.apk from faria - Blue Phone.apk 5/6/2013 - added to v2.2 - blue icons for the emergency_call (SecPhone.apk) - blue hooks in SecEmail.apk - blue and green contact icons in 1/ SecContacts.apk 5/7/2013 - added to v2.3 - new icons in ... - framework-res.apk 1/ keyguard_deafult_wallpaper.jpg 2/ emergency_default_wallpaper.png 3/ changed button on/off (screenshot) - ClockPackage.apk 1/ widget_alarm_clock_on.png 2/ widget_clock_alarm_ic_off.png 3/ alarm_icon_on.png 5/10/2013 - modified to XXAMD3 - a few png files modified 5/11/2013 - added deodexed flashable zip - GingerRev. 3.0 - 5/15/2013 - added new theme - Ginger Rev. v3.5 - - complete current and professional Ginger dialer - new modified in the folder: 1/ drawable-mcc310-mnc004-sw320dp-hdpi 2/ drawable-mcc310-mnc005-sw320dp-hdpi 3/ drawable-mcc310-mnc012-sw320dp-hdpi 4/ drawable-mcc311-mnc480-sw320dp-hdpi 5/ drawable-mcc450-mnc05-hdpi 6/ drawable-mcc450-mnc06-hdpi 7/ drawable-sw320dp-hdpi 8/ drawable-sw320dp-land-hdpi 5/16/2013 - added to v4.2 - Ginger Rev. - by me - modded files in: 1/ SecPhone.apk 2/ SystemUI.apk 3/ framework-res.apk - only odexed download version 1/ Talk.apk - what is themed: - SecPhone.apk ... 1/ call_img_conference.png 2/ call_img_unknown.png - SystemUI.apk ... 1/ New Ginger Rev. battery from AOKP with percent indicator 2/ stat_sys_battery.png and 3/ stat_sys_battery_charge_animation.png 4/ the battery also modded in the framework-res.apk - Talk.apk 1/ changed stock emos ... I added the Ginger emos - framework-res.apk 1/ stat_sys_battery.png 2/ stat_sys_battery_charge_animation.png 3/ default_wallpaper.jpg 4/ keyguard_wallpaper.jpg 5/ I added a new beats by dre default_wallpaper 6/ spinner_black_16.png 7/ spinner_black_20.png 8/ spinner_black_48.png 9/ spinner_black_76.png 10/ spinner_white_16.png 11/ spinner_white_20.png 12/ spinner_white_48.png 13/ spinner_white_76.png 5/18/2013 - added my theme to v4.6 - new Nexus 7 battery icon with - blueDroid load icon - this modified in ... 1/ SystemUI.apk 2/ framework-res.apk - new beats audio default and keyguard wallpaper in: 1/ framework-res.apk Installation: Bon alors là ca devient interressant parcequ'il y a plusieurs moyen d'installation ! Méthode 1 pour le script et rom ODEX ! -Télécharger le .rar -Dé zippez le -Lancez le script du thème (leather.face) -Si vous avez l'applications adb insecure tapez directement 2 sinon tapez 1 -Après un reboot le thème devrait être appliqué! Méthode 2 pour flasher via recovery et pour rom ODEX! -Avoir installé un recovery custom -Télécharger le .zip -Mettez le à la racine de la mémoire interne/externe -Flashez le (Install zip from Sdcard/Extsdcard) Méthode 3 pour flasher via recovery et pour rom DEODEXED! La même que la seconde méthode mais pas avec le même fichier :P Téléchargements : -Méthode 1 : ici -Méthode 2 : ici -Méthode 3 : ici Et pour retourner comme avant (Via recovery) : ici Et pour finir les screens : P.S:Je trouve l'icone de batterie assez moche sur le thème (sur les screen je l'ai changer) c'est pourquoi j'ai modifié l'icone de batterie et j'ai modifié un .zip pour le flasher via recovery: www.4shared.com/zip/6YtN1qQx/icone_batterie.html P.S 2: Mon icone il est pas tout le temps rose vous inquiétez pas :D Lien original: http://forum.xda-dev...d.php?t=2259191 Envoyé depuis mon GT-I8190 avec Tapatalk Citer
