gnondpomme Posté(e) 28 mai 2013 Share Posté(e) 28 mai 2013 (modifié) PAC-man ROM is a combination of the three Super ROMs Available Paranoid + Aokp + Cyanogen = PACman This ROM packs all the tweaks from the three super ROMs into one. Why Choose Among ROMs , When You have All-In-One !! And now built from source for Endeavoru ! Screenshots http://forum.xda-dev...38;d=1369664167 Instructions Code: - Make Sure You're On The Latest CWM/TWRP Recovery - Flash boot.img on fastboot - Go to Recovery - Wipe Data/cache/Dalvik Cache - Format /system if coming from Sense ROM - Flash ROM - Reboot - Wipe Dalvik Cache - Flash Gapps - Reboot Bugs Code: PA UI Prefs Currently not copied to the zip file will be fixed in the Next Build THIS IS HOW YOU TAKE LOGCAT AND REPORT BUGS Code: How To File a Bug Report with Logcat: Install android sdk Install drivers for adb on PC Connect phone to PC Open cmd.exe or terminal Type 'adb logcat' without the quotes Start the app that causes the issues Wait for the app to close or get to the error Copy logcat contents and put in pastebin Copy pastebin links here How To Find Wakelocks: Install android sdk Install drivers for adb on PC Connect phone to PC Open cmd.exe or terminal Type 'adb shell cat /proc/wakelocks > wakelocks.txt' without the quotes Copy contents and put in pastebin Copy pastebin links on your post How To Get dmesg logs: Install android sdk Install drivers for adb on PC Connect phone to PC Open cmd.exe or terminal Type 'adb shell dmesg > dmesg.txt' without the quotes Copy contents and put in pastebin Copy pastebin links on your post Before filing a bug report, please consider the answer to these: Is the bug reproducible? How do you reproduce it? What is the expected behavior? What actually happens? Are you on the default Kernel? Did you restore data of System Apps using Titanium Backup? Changlog For Nightly Code: Nightly-1 *Fixed PA Prebuilt Preferences Nightly-2 *Option to disable menu overflow *Gps Fix for singleshot session that doesnt stop *Fix for ribbon icons Kernel Features Explained Code: Kernel Features Explained By csec CREDITS Code: LorDClockaN Mithun46 n3ocort3x Alex-V PAC team PA Team AOKP Team CM Team ICJ Team DONATORS Code: * I dont Expect Donations...Please Donate Whoever I thanked in this OP * Pressing The Thank Button is Highly Appreciated for my Hard Work DOWNLOADS Release v22.3.0 (24/5/2013) PAC v22.0.3 Code: http://www.xdafilese...deavoru_PAC_JB_ Rom en cours de test chez moi ça ressemble fortement à JellyBam avec des mods et tweaks un peu différents. Stable, fluide, configurable. Pour ce qui est de la batterie je vous tiendrai informé pour le flash c'est comme d'habitude : - flash boot.img via fastboot - flash ROM - flash Gapps Have fun ! Modifié 28 mai 2013 par gnondpomme 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 28 mai 2013 Share Posté(e) 28 mai 2013 Rom installée :) Envoyé depuis mon HTC One X avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gnondpomme Posté(e) 28 mai 2013 Auteur Share Posté(e) 28 mai 2013 cool un autre testeur ! ^_^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
redem0n Posté(e) 28 mai 2013 Share Posté(e) 28 mai 2013 on va voir ce qu'elle a dans le ventre x) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 29 mai 2013 Share Posté(e) 29 mai 2013 (modifié) Elle est sympa cette rom . Surtout Pacman Google :) Envoyé depuis mon HTC One X avec Tapatalk Modifié 29 mai 2013 par herveonex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gnondpomme Posté(e) 29 mai 2013 Auteur Share Posté(e) 29 mai 2013 Pour ma part je vais rapidement changer. Comparer à JellyBam ou IceColdJelly je la trouve moins fluide, j'ai des soucis d'accroche réseau et surtout j'ai un bug sur Google Play Music qui au bout d'un quart d'heure de lecture me sort des erreurs comme quoi les fichiers sont illisibles alors que tout fonctionnait parfaitement avnt le changement de ROM ... Obligé de désinstaller/réinstaller pour que ça remarche et comme je suis un gros consommateur de musique sur mon HOX c'est juste pas possible ... :mellow: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
redem0n Posté(e) 29 mai 2013 Share Posté(e) 29 mai 2013 (modifié) c'est vrai qu'elle est moins fluide que jellyBam et j'ai également des soucis de réseau obliger de redémarrer pour que le réseau revienne et le téléphone redémarre tout seul quelque fois mais je pense qu'il faudra attendre les prochaines versions pour réellement la tester ^^ Modifié 29 mai 2013 par redem0n Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
