[ROM][4.2.2][UMS/MTP][HWKEYS_REMAP][PARANOIDANDROID_3.15][GCC4.7-O3.Linaro]
___PARANOID_ANDROID^3.15____
Source :
XDA
Built from source, based on AOSP 4.2.2
Compiled with GCC 4.7 -O3 from SaberMod and Linaro String routines optimizations
Features: Hardware keys remapping from CM under Settings > Toolbars, One X Settings, no more 0 folder on sdcard, USB Mass Storage and NCX kernel.
Screen artifacts and signal issues FIXED. Camera with faces working.
Everything works
Please test and report problems! If you like my job, buy https://play.google.....recovery&hl=it to keep it alive
Flash boot.img from ROM zip, then erase fastboot cache
Install these ROM and GAPPS, wipe cache and dalvik (full wipe is recommended when coming from another rom)
http://d-h.st/TnZ
http://d-h.st/ry7
CHANGELOG
Quote: 15MAY-Implemented CM's Power Widget and Carbon's Notification Shortcuts (into Settings > Toolbars > Notification Drawer), kernel updated to NCX v39, added DoubleTap2Wake in Advanced Settings
29APR-Lockscreen ring shortcuts - CM (Settings > Lockscreen > Slider Shortcuts), Quick Settings flip and reworked colors configuration (Settings > Toolbars > Quick Settings panel, now you can choose what random colors you want)
25APR-Ported colored statusbar tiles from BAKED under Settings > Toolbars > Quick Settings, Camera from maxwen, Graphite enabled and -mfloat-abi=softfp flag
23APR-Added UMS/MTP switch to allow ADB at the same time with storage
19APR-Fixed buttons backlight from Advanced Settings, added CRT Off and style, T9 dialer and optimizations tweaks, NCX V35 included
14APR-Added HW keys remapping, built with SaberMod GCC 4.7 and Linaro string routines, BLN and notification led working
25MAR-Update to PA3.15: new PAPrefs, Hybrid mode quick toggle, n3okernel v31c
22MAR-Fixed LatinIME(Swype keyboard), Camera faces, NCX v28 included
If PAPrefs doesn't apply your settings, set /system/etc/paranoid/properties.conf permissions to rw-rw-rw
Très certainement ma futur ROM vu que je suis un peu déçu de la PACMAN et que j'adore PARANOID je vais essayer de flasher ça dans la soirée
See Ya
Modifié par gnondpomme
  • Like 2
ROM installé depuis hier soit, beaucoup moins de tweaks (mais c'est normal) que sur les JellyBam, PACMAN, etc ...
C'est fluide et stable. Par contre il y a toute une série de réglage dans le paramétrage paranoid que je ne maitrise pas vraiment pour l'instant ... Je voulais avoir le même écran que sur le screen shot mais ça n'est pas si simple que cela à obtenir.
Dès que c'est un peu mieux configuré je vous fait signe.
En tout cas pour ceux qui veulent s'amuser un peu je conseille vivement cette ROM qui est très agréable !
ouaaaaaah t'as dû mettre pas mal de temps! mais c'est vrai que c'est bien sympa ;)
EDIT: c'est dans les paramètres paranoid que t'as rendu les icônes comme ça?
Modifié par redem0n
Bon j'en suis a mon 2nd cycle de batterie, mais j'ai tenu plus de 17h à mon 1er cycle, ce que je trouve pas mal sachant que je l'utilise beaucoup. Elle est très agréable, fluide, stable, pas de surchauffe ou de lag, bref j'adore :D, je referai un retour à la fin de mon 3e cycle ^^
Merci pour la trouvaille gnondpomme!!
De nada , j'utilisais déjà cette ROM sur mon Nexus S et elle était très bonne donc je m'attendais a du tout bon et c'est bien le cas !
Pour ma part elle est aussi bonne que IceColdJelly qui était déjà excellente !
Là je vais faire une sauvegarde et en essayer une autre avant de me fixer définitivement ...
Bonjour a tous
jai un petit soucis avec cette rom... je n'arrive pas a avoir l'affichage de mes parametres normal, je l'ai en interface tablette est cest asser petit donc peut pratique.
sinon tres belle rom, stable et fluide.
Oui sa fait short ^^
Mais bon l'écran n'a pas eu le temps de s'éteindre, jai toucher un peut a tout, flasher le mod du son etc etc. Enfin on verra bien :)
Par contre jaimerais que l'on me guide pour afficher mes paramètre normalement, je l'ai aïs en deux volets et c'est passer peut pratique car tout est en tout petit.
Merci.
ha désolé j'peux pas faire mieux, je ne m'en souviens plu trop c'est lointain pour moi cette ROM
tu n'as pas touché aux DPI sinon? car ça peux bien sûr en être la cause.
ou encore : il me semble qu'il y avait une appli qui carrément changeait l'apparence globale genre tu pouvais mettre "en mode tablette".
sinon pour la sentinel le dev cherche un beta testeur, je crois qu'il a vendu son HOX lol en même temps il ne s'en servait pas d'où les 4jours d'autonomie :P
regarde a 40 sec c'est de ça que je parle >>
