vaskezsanchez Posté(e) 3 juin 2013 Posté(e) 3 juin 2013 (modifié) Decouvrez cette toute nouvelle rom sous Jelly Bean évolution de la tres bonne rom Experience 1.4.3 et basée sous la rom stock JB de Munjeni!!! Requis : Bl unlock Jb rom par Munjeni Zip de la rom 2 post Présentation : [/center] Presentation : [*]Based on latest 6.2.A.0.400 JB firmware apps. [*]AROMA installer. [*]Tiny Size - Only ~350MB [*]Barebone and PRE-ROOTED. [*]Extreme fast & stable. [*]First time ~175MB FREE RAM on Barebone(minimal) installation. [*]SpeedyDroid deeply integrated. [*]Adblocker for fast browsing. [*]6 best fonts(Default, Ubuntu, Nokia Pure, Sony Sketch, Xperia Z, Rosemary) [*]3 best root management apps(SuperUser, SuperSu, CWM superuser) [*]All stock features with tweaks. [*]Munjeni's Memory Tweaks+OC kernel. [*]Xperia T launcher with settings + Fast Xperia Z launcher with settings + JB default launcher [*]All New Sony Widgets. [*]Bravia Engine 2 from Xperia Z. [*]Xperia White Magic Balance [*]Xperia Z taskswitcher. [*]Xperia Z smallapps. [*]Cybershot Mod 4.7.2 [*]Settings with CPU Control and CPU Stats included [*]Auto start app control in settings [*]New Sony JB Walkman with Working Download Info - illuminate your music. [*]New Sony JB Album and Movies. [*]Xperia Z Sociallife [*]Latest Xperia Matel themes+ Xperia flow themes + Xperia ribbon themes + Xperia space themes + Default Xperia NxT Themes. [*]Xperia JB bootanimation + Xperia NxT bootanimation + Naxus bootanimation. [*]Xperia Z home wallpapers + Xperia Z lockscreen wallpapers + Auni wallpapers. [*]CM10 ringtone pack. [*]Xperia Z charging animation [*]My Xperia - find your lost phone. [*]Dholphine HD + Opera Mini + Stock + Chrome Browser [*]Facebook + Whats App Plus + Gmail 4.2 [*]ES File Manager 3 [*]BatteryCalibration [*]Supports OTA(over the air) updates. - [will be available from next release] [*]All new build.prop tweaks added. [*]Init.d support [*]GPU, CPU, VM, Kernel, Network Tweaks [*]Mali 400 & Gaming Tweaks [*]Smooth Scroll [*]Improved Gaming Performance (don't expect much) [*]Battery Life Tweaks [*]Enhanced Deep Sleep and Power Saving. [*]Added More Speed [*]And Many More... Check Out For Yourselves.... Installation et réglages : Modifié 3 juin 2013 par Dragnxt Citer
vaskezsanchez Posté(e) 3 juin 2013 Auteur Posté(e) 3 juin 2013 Telechargement : http://d-h.st/tqi Citer
Kidy973 Posté(e) 4 juin 2013 Posté(e) 4 juin 2013 Je pense que je vais la tester. Ca donne quoi dans le multitask et les jeux ? Parce que la stock de munjeni, j'ai du force close au bout de 2 minute quelque soit la cadence ou le governenor/ordonnaceur. Avec la utimate rom v7, ben là c'est FC dès que la 3D s'affiche dans les jeux, pas de multitache (exemple je peux pas utiliser la musique et les SMS en même temps, la musique plante) et le clavier disparait trop souvent. Citer
vaskezsanchez Posté(e) 5 juin 2013 Auteur Posté(e) 5 juin 2013 Je pense que je vais la tester.Ca donne quoi dans le multitask et les jeux ? Parce que la stock de munjeni, j'ai du force close au bout de 2 minute quelque soit la cadence ou le governenor/ordonnaceur. Avec la utimate rom v7, ben là c'est FC dès que la 3D s'affiche dans les jeux, pas de multitache (exemple je peux pas utiliser la musique et les SMS en même temps, la musique plante) et le clavier disparait trop souvent. en oc a 1.15ghz c est mieux avec le reglage ondemandax/sio, j ai pas testé tout les jeux avec cette ROM ci mais le multitask est ok, au pire fait un nandroid backup sur ta sd ext et si ca te plait pas restore ton ancienne rom. ^_^ tapatalk Citer
Kidy973 Posté(e) 5 juin 2013 Posté(e) 5 juin 2013 J'ai essayé et j'approuve. Les jeux fonctionnent correctement malgré quelques lags mais pas de FC sur dead trigger ou RR3. juste un sur Airport city dans une ville un peu trop développée. Je continue les tests, je vous tiens au courant 1 Citer
vaskezsanchez Posté(e) 5 juin 2013 Auteur Posté(e) 5 juin 2013 J'ai essayé et j'approuve. Les jeux fonctionnent correctement malgré quelques lags mais pas de FC sur dead trigger ou RR3. juste un sur Airport city dans une ville un peu trop développée. Je continue les tests, je vous tiens au courant Cool, moi je l'ai installé sur le sola blanc de ma femme et elle est ravie ;) Pour ma part je vais aussi la tester ce week end en profondeur sur mon sola, pas eu le temps... :( Profitez bien de la video pour installer et regler la rom tranquillement, oubliez pas d'installer aussi xbooster et de le mettre en mode gaming au besoin, pas testé avec cette rom mais cette appli est bien donc ca devrait apporter un plus encore ;) Citer
