Root Acer Iconia Tab B1-A71
Co
  • 1 month later...
Bonjour ; moi j ai un probleme Voici :
======= Acer Iconia Toolkit v0.7.2 =======
Which device do you have?
[1] Acer Iconia B1-A71
[2] Acer Iconia A1-810
[3] Acer Iconia B1-710 / B1-A710
[Q] Quit
Enter a selection:
E: Only '1', '2', '3' and 'Q' is allowed!
[Q] Quit
Enter a selection: &1
[Q] Quit
Enter a selection:
[Q] Quit
Enter a selection: 1
======= Acer Iconia B1-A71 Toolkit v0.7.2 =======
What do you want to do?
[1] Root
[2] Unroot
[3] Internal 2 External (needs root)
[4] Odex (needs root)
[Q] Quit
================== Root =================
Before we can start, please do following:
1. Make sure drivers for your Acer Iconia B1-A71 are installed, you can find the
2. Plug-In your Acer Iconia B1-A71 into this PC.
3. Enable USB Debugging Mode by going into Settings -> Developer Tools.
4. Put prerooted system.img.gz into folder: system_image of this toolkit.
5. Keep your device plugged in until it's finally rooted, or this procedure is a
borted!
If you sucessfully applied the steps above, we can now start.
You can always abort by pressing Ctrl+C
[ENTER] Continue
[Q]     Quit
Enter a selection:
Trying to establish ADB Connection...
ADB Connection to your Acer Iconia B1-A71 successful.
Copying Busybox to your Acer Iconia B1-A71.
4230 KB/s (1062992 bytes in 0.245s)
Successfully copied Busybox to your Acer Iconia B1-A71.
Starting Telnet server on your Acer Iconia B1-A71.
Please turn on your Acer Iconia B1-A71 now and unlock the screen. Only hit ENTER
 when the screen of your Acer Iconia B1-A71 is unlocked!
[ENTER] Continue
[Q]     Quit
Enter a selection:
Don't touch the screen! I'm taking it over now ;-)
Checking, if telnet server is started. If the tool crashes now, try to start tel
net server manually by clicking on 'Run'.
Successfully started Telnet server on your Acer Iconia B1-A71.
Checking firmware version.
740 KB/s (4537 bytes in 0.005s)
Firmware version 'RV05RC05' installed. MAKE SURE YOUR system.img.gz IN system_im
age FOLDER IS OF THE SAME VERSION, OTHERWISE YOU GET A BOOTLOOP!
Copying rooted system.img.gz to your Acer Iconia B1-A71 (This will take 1-2 minu
tes)...
[ENTER] Continue
[Q]     Quit
Enter a selection:
E: No system.img.gz found in folder 'system_image' in toolkit directory.
If you keep getting this error, try to run toolkit with -d or --debug parameter
Press Enter to leave Application...
procédure suivi à la lettre : tablette briquée....
C'est bon, après avoir fait un reset ca fonctionne
Bon finalement la tablette fonctionne mais le foot n a pas fonctionner longtemps...
Modifié par joak
  • 1 month later...
  • 5 months later...
  • 1 month later...
