TrustNo_1 Posté(e) 6 juillet 2013 Share Posté(e) 6 juillet 2013 (modifié) :excl: Voici un beau petit kernel pour overclocker son HTC ONE X jusqu'à 1,700 GHz !!!!FONCTIONNE AVEC AOSP/ AOKP/CM/SENSELien XDA : http://forum.xda-dev...d.php?t=2138586FONCTIONS : Sweep2Wake - Dennis Rassmann (Showp1984)Custom User Voltage Control - Faux123/XmisterGPU OC @ 520 - TripNRaVeRCPU OC up to 1600 QUAD (Variant 0 and 1 - may not be stable)CPU OC up to 1700 QUAD (Variant 2 and 3 - may not be stable)Patch from 3.14 base to 3.18Cpuquiet - Faux123/NvidiaMpdecision - (Currently not in use after 005) Dennis Rassmann (Showp1984)Smartdimmer - TripNRaVeRDynamic Fsync (Currently not in use after 006) - Faux123TripNDroid Vibrator Driver (Currently not in use after 004) - TripNRaVeRCPU Freq Hard Cap and Max Scaling Freq - Maxwen / Showp1984 for initial scaling freq setupBacklight Button Notification - Maxwen / XmisterSmartmax Governor - MaxwenFastcharge - TbaldenTouchdemand Governor - MetallicePerformance governor patch to actually use all for cores in quad mode - MetalliceLZ4 Compression/decompressionLinaro/Arm optimizations - showp1984Changelogs : 2013-04-13 Timothy Nelson (HEAD, origin/013, 013) KozmiKKernel: Updating cpuquiet defconfig to 013 ddcdb90 2013-04-13 Timothy Nelson KozmiKKernel: Removing pesky cpu_user_cap from aokp ramdisk 2f8c0a8 2013-04-13 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 3296c18 2013-04-13 Timothy Nelson Revert: mach-tegra: tegra3_clocks: adjusting idx for min/max 5300bfa 2013-04-13 Timothy Nelson Patch: Part 2: Adding OC Up 1700 for variants 2 & 3, and OC down to 1600 for variants 0 & 1. Increased GPU voltage to stock and 89569cb 2013-04-11 Timothy Nelson Patch: Adding OC Up 1700 for variants 2 & 3, and OC down to 1600 for variants 0 & 1. Increased GPU voltage to stock and raise CP bb14267 2013-04-11 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 7370d9a 2013-04-11 Timothy Nelson Patch: Integrating HTC's mess into ti-openlinks wl12xx source 611ab65 2013-04-11 Timothy Nelson (origin/011, 011) drivers: leds: leds-lp5521_htc.c: Setting slow_blink_brightness back to 255 2943aea 2013-04-10 Timothy Nelson KozmiKKernel: Updating Sense ramdisk 1a7f497 2013-04-10 Timothy Nelson KozmiKKernel: Updating compile script d0f9141 2013-04-10 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 085836e 2013-04-10 Timothy Nelson KozmiKKernel: Updating ramdisk's 68eb085 2013-04-11 maxl smartmax: it helps if the per cpu ideal_speed value is updated :) 002d627 2013-04-11 maxl smartmax: separated awake and suspend ideal freq 9de53e1 2013-03-30 maxl leds: add custom option if slow blink brightness should be limited to button brightness - default is true b3f16f2 2013-03-25 maxl led: remove HTC derp e33f16c 2013-03-25 maxl led: limit BLN brightness to button brightness 4ec2874 2013-03-25 maxl led: another derp cdc51dd 2013-03-24 maxl led: cleanup that log mess 0db54f7 2013-03-24 maxl led: derp - dont change backlight_mode 1b74b90 2013-03-24 maxl backlight: enable hidden sysfs for color enhance 60c7d74 2013-03-23 maxl led: apply button brightness change only if on d6532c3 2013-03-23 maxl led: added button brightness sysfs interface - thanks xmister 48223ba 2013-03-22 Xmister leds: lp5521_htc: fix auto-bln not turning off c781009 2013-03-16 maxl led: disabled currents for green and amber cause they do dont work correctly 29360fc 2013-03-22 Xmister leds: lp5521_htc: update auto-bln a247245 2013-03-17 Xmister Add missing config for Sense deed438 2013-04-10 Timothy Nelson sweep2wake: Enable sweep2wake by default with button-backlight enabled 76978e7 2013-04-10 Xmister drivers: leds: Setup auto-bln with sense variable b32221b 2013-03-16 maxl led: disabled currents for green and amber cause they do dont work correctly 07f4715 2013-03-05 maxl LP5521 LED: Add slow blink mode for button-backlight LED 6655ef0 2013-02-17 Thomas Wendt LP5521 LED: Use a work queue for button backlight fading 5fc26ca 2013-04-10 Timothy Nelson drivers: cpufreq: cpufreq_smartmax.c: Updating to latest revision 040913 6106765 2013-04-10 Timothy Nelson sound: soc: codecs: tlv320aic3008.c: Adding 32bit pcm 13deb3b 2012-09-09 TripNRaVeR tegra_pcm: support audio up to 32bits d3e69ce 2013-04-10 Dennis Rassmann sweep2wake: enable button_backlight eacd6b6 2013-04-10 Timothy Nelson sweep2wake: Adding backlight_mode_set for use with Sweep2Wake a20bc32 2013-04-10 Timothy Nelson kozmikkernel: Updating cpuquiet defconfig 5bfac8f 2013-04-10 Timothy Nelson drivers: leds: leds-lp5521_htc.c: Reverting all changes back to stock ebe8177 2013-04-10 Timothy Nelson (origin/009, 009) kozmikkernel: Updating debug cpu to j8 in debug script 88883b1 2013-03-26 Timothy Nelson (master) Drivers: Net: Wireless: Removing unused compat-wireless drivers. Building from direct source now. 4a96e5f 2013-03-26 Timothy Nelson mach-tegra: board-endeavoru-sdhci: Setting board_tcxo_clock properly c68ab8f 2013-03-26 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 7c8cb9a 2013-03-26 Victor Goldenshtein Patch: Updating Wifi through TI-OpenLink 03-19-13 52aafae 2013-03-26 Timothy Nelson KozmiKKernel: Updating ramdisk with recent AOKP revisions b0ae5a5 2013-03-26 Timothy Nelson Revert: mach-tegra: board-endeavor-panel: Increasing tegra_dc_mode endeavor_dsi_modes clock to 30000000 14f3dc5 2013-03-26 Timothy Nelson KozmiKKernel: Updating compile script dcd2f30 2013-03-26 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig f0ca677 2013-03-26 Timothy Nelson mach-tegra: tegra3_dvfs: Adjusting Variant 0 frequencies. 48b0231 2013-03-26 Timothy Nelson KozmiKKernel: Switching to Sense ramdisk from Alex-v's 007 build 0f8caf3 2013-03-26 Timothy Nelson Revert: include: mm: increase readahead buffer 92f8937 2013-03-26 Timothy Nelson arch: arm: mm: Adding dma-na-mapping.c from Nvidia reference branch l4t/l4t-r16-r2 to enable NON_ALIASED_COHERENT_MEM 4a2d4b1 2013-03-26 Timothy Nelson drivers: net: wireless: wl12xx: Use HTC firmware cae4292 2013-02-12 TripNRaVeR patch: build wifi drivers from source cc66342 2013-03-17 Timothy Nelson mach-tegra: board-endeavoru.c: Uncommenting gps components e6df373 2013-03-17 Timothy Nelson Patch: drivers: misc: ti-st: Updating to Nvidia reference branch l4t/l4t-r16-r2 48e8b32 2013-03-09 Timothy Nelson KozmiKKernel: Switching to AOKP ramdisk 3b7a94a 2012-05-07 showp1984 arch/arm/return_address.c: hide annoying warning 5f0b528 2012-03-25 showp1984 netfilter: xt_log.h: fix warning: value computed is not used 50a4471 2012-03-19 showp1984 net / netfilter: remove annoying 'comparison will always be true' warning 09a7044 2012-03-19 showp1984 arm: mm: fixing 'offset.un' may be used uninitialized in this function d70edb0 2013-03-07 Timothy Nelson mach-tegra: tegra3_clocks: adjusting idx for min/max 0267ab0 2013-02-08 Metallice cpufreq: touchdemand: increase up threshold to 98 75713d9 2013-02-04 Metallice cpufreq: touchdemand: increase up threshold and decrease sampling rate bd0bb8b 2013-01-19 Metallice tegra: lower G min and touch floor min c2b5633 2012-09-15 Henrik Rydberg Input: Send events one packet at a time 70b372a 2013-01-18 Metallice cpufreq: touchdemand: add touch minimum core number lock and tweak values 04e093a 2013-01-13 Metallice cpufreq: touchdemand: more balanced defaults e91c530 2013-01-11 Metallice cpufreq: touchdemand: add touch factor, a down differential multiplier tweak some values as well c65beb4 2013-01-11 Metallice cpufreq: add touchdemand governor 67d6156 2013-03-07 Timothy Nelson Patch: Adding/Updating IOMMU/Tegra SMMU from Nvidia Reference branch l4t-l4t-r16-r2 1e85345 2013-03-07 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig e058e31 2012-03-19 faux123 Optimized ARM RWSEM algorithm 46829d2 2013-01-30 Kyungsik Lee arch: arm: Kconfig: enable efficient unaligned access feb2af3 2013-01-31 Dave Martin ARM: 7583/1: decompressor: Enable unaligned memory access for v6 and above 3e7c797 2013-03-05 Metallice fixups for lz4 and enable in defconfig 3e82ca6 2013-03-07 Timothy Nelson arm: add support for LZ4-compressed kernels 863e9c8 2013-01-30 Kyungsik Lee lib: add support for LZ4-compressed kernels e543015 2013-03-07 Timothy Nelson mach-tegra: tegra3_dvfs: Increasing 1600 and 1624 voltages slightly f1bbd51 2013-03-07 Dennis Rassmann lib: avoid ICE on linaro 8.12 c9f1d99 2013-01-30 Kyungsik Lee decompressors: add lz4 decompressor module b5c1b1b 2013-02-28 faux123 lib/rwsem.c: fix compatibility issues with Linux 3.1.y 3f27b08 2013-02-24 faux123 tmpfs: fix mempolicy object leaks 23f3d38 2013-02-24 Greg Thelen tmpfs: fix use-after-free of mempolicy object bd044d3 2013-02-05 Alex Shi rwsem: steal writing sem for better performance 738fd74 2013-02-28 faux123 rwsem-spinlock: let rwsem write lock stealable 163ff7c 2013-02-11 Metallice cpufreq: performance: lock to 4 cores ad20a55 2012-11-02 Vincent Guittot Add ARM cpu topology definition 554b67c 2011-12-17 showp1984 makefile: vectorize for quadword registers e70ff1f 2012-03-22 TripNRaVeR vfp: compile with neon 61a0350 2011-11-02 showp1984 Makefile: Optimizing build-options for linaro d210d2e 2011-09-12 showp1984 Makefile: Added ARM optimizations 76d127a 2013-03-06 Timothy Nelson mach-tegra: board-endeavor-panel: Increasing tegra_dc_mode endeavor_dsi_modes clock to 30000000 ca0ceac 2013-03-06 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig ffba840 2013-03-06 Timothy Nelson mach-tegra: Setting 1624 as the max possible clock when increasing freqency. fce4dfe 2013-03-06 Timothy Nelson Patching to endeavoru-jb-crc-3.1.10-8580daa e797168 2013-03-06 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 4bb5a4f 2013-03-06 Timothy Nelson mach-tegra: tegra3_dvfs: Adding 1624 freq and setting voltage for it at 1163mv 4c29ef2 2013-03-06 motley mach-tegra: tegra3_clocks: Adding 1.624 Clock rate 878c873 2013-03-05 Timothy Nelson mach-tegra: tegra3_dvfs: Lowering voltage for 1700 to 1188 from 1200 b4e7e6b 2012-08-08 David McCullough arm/crypto: Add optimized AES and SHA1 routines 8f4c7f0 2013-03-03 Thomas Wendt LP5521 LED: Add slow blink mode for button-backlight LED 924c121 2013-03-02 maxl battery: fast_charge switch without replug - now it works 7ad938e 2013-03-05 Timothy Nelson mach-tegra: tegra3_speedo: Setting speedo 13 back to 1237 4559d99 2013-03-05 Dennis Rassmann mach-tegra: edp: Setting up edp boost 054d052 2013-03-05 Timothy Nelson mach-tegra: tegra3_dvfs: Updating frequencies and increasing max freq to 1.7ghz b78a48b 2013-03-05 Timothy Nelson mach-tegra: tegra3_clocks: Updating 1.6 & 1.7 frequency tables 71067ca 2013-03-05 Timothy Nelson Patch: Updating Wifi drivers to ti-compat-wireless-R5-SP3-03 30253ce 2013-03-04 Timothy Nelson mach-tegra: Removing 1550mhz and increasing max to 1650mhz c8bf907 2013-03-03 Timothy Nelson mach-tegra: tegra3_dvfs: Making variants 0,1,3 use the same frequency array as variant 2 for cpu id 4 6323ceb 2013-03-02 Timothy Nelson revert: mach-tegra: tegra3_dvfs: Reverting core voltages back to stock and modifying core floor voltages slight based initial on 6382dad 2013-03-02 Timothy Nelson mach-tegra: tegra3_dvfs: Removing HTC Fixup so that get_core_nominal_mv_index(int speedo_id) can properly call get_core_edp() d623a6b 2013-03-02 TripNRaVeR mach-tegra: tegra3_dvfs: Adjusting freqencies to match those of tegra3_clocks 1.6ghz freqency table that is being used. 0656a99 2013-03-02 Timothy Nelson mach-tegra: tegra3_dvfs: Reverting core voltages back to stock and modifying core floor voltages slight based initial on stock. 4d8dfc9 2013-01-08 TripNRaVeR tegra3_clocks: stop this useless warning with log filling 074bbc3 2013-03-02 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 83fd657 2012-09-20 Tatyana Brokhman block: Adding ROW scheduling algorithm e85a38d 2013-03-02 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 2718ec2 2013-03-02 Timothy Nelson sound: codecs: tlv320aic3008: Lowering AUD_CPU_FREQ_MIN to 25500 11b4589 2013-03-02 Timothy Nelson mach-tegra: pm: Lowering AWAKE_CPU_FREQ_MIN to 25500 2498259 2013-03-02 Timothy Nelson mach-tegra: tegra3_dvfs: Adding back in the final two voltages that were accidently removed, and lowering the core min to 900 8d501a6 2013-03-02 Timothy Nelson mach-tegra: tegra_pmqos: Lowering TS_CPU_MIN_FREQ to 25500 1d67cd5 2013-03-02 Timothy Nelson mach-tegra: tegra3_speedo: Aligning speedo id's with their respective voltages c43281a 2013-03-01 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 7f0de7c 2013-03-01 Timothy Nelson mach-tegra: tegra3_clocks: Adding 25500 freq a4e22a7 2013-02-28 TripNRaVeR KozmiKKernel: ramdisk-aosp: Adding increasing read ahead size of mmc block devices to 2048 a8cefe0 2013-02-28 Timothy Nelson mach-tegra: tegra3_clocks: Adjusting emc to cpu ratio setup 8ea95b7 2013-02-28 Timothy Nelson mach-tegra: tegra3_dvfs: Updating voltages and GPU OC 270905d 2013-02-28 Timothy Nelson mach-tegra: tegra3_dvfs: Removing hardcoded cpu speedo id if statement 3f9203b 2013-02-28 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig 4a584fe 2013-02-28 Timothy Nelson drivers: smartmax: Cleaning up a few warnings ba9ba76 2013-02-28 Timothy Nelson mach-tegra: cpu: several changes, see commit msg f0d1a08 2013-02-28 Timothy Nelson Patch: Adding CPU Freq Hard Cap and Max Scaling Freq 018f754 2013-01-21 TripNRaVeR arm: tegra: enable gpu oc 520mhz e87da86 2013-02-26 TripNRaVeR cpu-tegra: remove user_cap hacking from htc 8b1ff7e 2013-02-26 TripNRaVeR cpu-tegra: cleanup some unneeded earlysuspend stuff that was left in d4507d1 2013-02-26 TripNRaVeR cpu-tegra: remove ril_boost 4245729 2013-02-26 TripNRaVeR cpu-tegra: usb: remove release_screen_off_freq_lock b67965d 2013-02-26 TripNRaVeR cpu-tegra: usb: remove lock_screen_off_freq_lock beab439 2013-02-26 TripNRaVeR cpu-tegra: remove tegra_cpufreq_resume/suspend from htc fef4b43 2013-02-26 TripNRaVeR cpu-tegra: remove htc_suspend_resume_work(er)(s) a8cc379 2013-02-23 TripNRaVeR cpu-tegra: remove htc early suspend hacks 9b7ae44 2013-02-26 Xmister Voltage control: Report only the minimal voltage per frequency 4a83280 2013-02-26 Xmister Voltage control fixes 8edbb84 2013-02-26 Xmister Proper Voltage control interface 08e6c01 2013-02-21 TripNRaVeR rcu: add jrcu for small smp systems 46145ac 2013-02-26 TripNRaVeR cpufreq: fix setting governor accros hotplug cpus (maxwen) a40b4aa 2013-02-28 Timothy Nelson mach-tegra: tegra3_speedo: Matching up with dvfs d7e9761 2013-02-28 Timothy Nelson mach-tegra: tegra3_dvfs: More fixing up of voltages bc874e4 2013-02-28 Timothy Nelson mach-tegra: common: Increasing pmu_core_edp to 1350 7099a3f 2013-02-28 Timothy Nelson mach-tegra: tegra3_clocks: Increasing to quad 1600 7d22f39 2013-02-27 Timothy Nelson KozmiKKernel: Removing cpu_user_cap hardcoding from aosp ramdisk 731006e 2013-02-27 Timothy Nelson mach-tegra: tegra3_speedo: Removing the 14th and 15 speedo controls to be inline with the core 13 that are now being used in dvfs d659e02 2013-02-27 maxl drivers: cpufreq: smartmax: Adding smartmax governor 9891a4a 2013-02-26 Timothy Nelson KozmiKKernel: Updating aosp ramdisk with CM beta 7 ramdisk 5115db8 2013-02-21 tbalden battery: Adding USB fastcharge option when connecting to PC 9eec5ab 2013-02-26 Timothy Nelson mach-tegra: Adding OC up to 1600 21b6af4 2013-02-26 Timothy Nelson mach-tegra: tegra3_dvfs: Fixing up voltage table and cpu_0 freqs to match new table setup dd468c6 2013-02-26 Timothy Nelson mach-tegra: tegra3_dvfs: Removing AP33 chipset from cpu_0 alt freq table set 5e64eef 2013-02-26 Timothy Nelson mach-tegra: dvsf.h: Lowing freqs to mach simpler nvidia rel-15r7 58c2ef6 2013-02-26 Timothy Nelson mach-tegra: tegra3_dvfs: Bringing voltage/freqs inline with simpler nvidia rel-15r7 ff9d064 2013-02-24 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig b47e9f4 2013-02-24 Timothy Nelson KozmiKKernel: Reverting aosp ramdisk changes back to CM standard e0ced79 2013-02-21 Timothy Nelson KozmiKKernel: Updating mpdecision defconfig 84283f4 2013-02-21 Timothy Nelson KozmiKKernel: Updating cpuquiet defconfig a0626ce 2013-02-21 Timothy Nelson KozmiKKernel: Removing old kozmik_defconfig in favor of the hotplugging configs 6a95e3e 2013-02-21 Timothy Nelson KozmiKKernel: Adding a menu system to compile script for selecting defconfig based on hotplug 561c388 2013-02-21 Timothy Nelson KozmiKKernel: Updating some wording in debug script 97bd42c 2013-02-21 Timothy Nelson KozmiKKernel: Adding a menu system to debug script for selecting defconfig based on hotplug cd40d41 2013-02-21 Timothy Nelson KozmiKKernel: Adding/Updating defconfigs 720add4 2013-02-21 Timothy Nelson kernel: sys: Revert adding extern void disable_auto_hotplug(void) f8ca265 2013-01-09 Timothy Nelson board/cpu-tegra3: Additional runnable threat edits necessary for compilation option for htc devices 5e2ea86 2012-09-09 faux123 cpuquiet/governors/balanced: make runnable thread as a compilation option 10c2180 2012-09-09 faux123 board/cpu-tegra3: make runnable thread as a compilation option c72f339 2012-09-23 faux123 drivers/cpuquiet/governors: make balanced as default governor f190e52 2012-07-05 Sai Charan Gurrappadi ARM: tegra: Remove duplicate clock inits 105b880 2012-09-12 faux123 drivers/cpuquiet/governors/runnable_threads: fix typo derp 58af742 2012-08-24 Sai Charan Gurrappadi cpuquiet: Add notifiers for the runnables governor 1cf2f59 2012-07-25 Sai Charan Gurrappadi cpuquiet: Runnable threads governor 4fa564a 2012-07-25 Sai Charan Gurrappadi ARM: tegra: cpuquiet: Fix cpuquiet notifiers 23217ae 2012-07-10 Sai Charan Gurrappadi ARM: tegra: cpuquiet: Notify the cpuquiet governor when the driver is busy 9d5d094 2012-09-22 faux123 Revert "drivers/cpuquiet/governors: make balanced default" 0fe6a74 2012-09-12 faux123 drivers/cpuquiet/governors: make balanced default dfefeaf 2012-09-04 faux123 kernel/sys: cpuquiet compatibility fixup 4fb699b 2012-07-05 Sai Charan Gurrappadi cpuquiet: Account for the corner case frequency when setting state a6b36c9 2012-06-14 Sai Charan Gurrappadi cpuquiet: Fix compiler warning c50fa12 2012-06-14 Sai Charan Gurrappadi cpuquiet: Update stats only on successful operations c99fe19 2012-06-22 Sai Charan Gurrappadi cpuquiet: Properly return the first registered governor 822faf8 2012-06-11 Peter De Schrijver ARM: tegra: add sysfs support for tegra cpuquiet driver cf1bae3 2012-06-19 Sai Charan Gurrappadi ARM: cpuquiet: Go to and stay on G-CPU if min_cpus 1 is requested 32e8a5c 2012-06-18 Sai Charan Gurrappadi cpuquiet: Updated balanced governor to use the runnable threads patch 6ff6d2a 2012-06-11 Peter De Schrijver drivers: cpuquiet: fix error message bfe9eea 2012-03-30 Peter De Schrijver ARM: tegra: cpuquiet driver for Tegra3 7e8856d 2012-03-30 Peter De Schrijver cpuquiet: balanced governor a36116c 2012-03-30 Peter De Schrijver cpuquiet: userspace governor 3ff7f08 2012-03-30 Peter De Schrijver cpuquiet: governor support be81a8f 2012-03-30 Peter De Schrijver cpuquiet: sysfs interfaces 2998a74 2012-03-30 Peter De Schrijver cpuquiet: driver support e143b3f 2012-03-30 Peter De Schrijver cpuquiet: public interfaces for cpuquiet 4f44628 2012-03-30 Peter De Schrijver cpuquiet: base files 5726963 2013-02-07 Timothy Nelson mach-tegra: Removing cpu aging from dvfs 566bbeb 2013-01-28 TripNRaVeR cpufreq_ondemand: dont use interactive tracers, create youre own 336c7dc 2013-02-21 TripNRaVeR build: ramddisk-aosp: Adding increasing read ahead size of mmc block devices 8cf2111 2013-02-21 TripNRaVeR build: ramddisk-aosp: Adding # leds section 30e55ff 2013-02-21 TripNRaVeR build: ramddisk-aosp: Updatating # Sensor section 9bbe634 2013-02-21 Timothy Nelson build: ramddisk-aosp: Removing user cap e531881 2013-02-21 TripNRaVeR build: ramddisk-aosp: Updating permissions 7a20282 2012-08-09 Preetham Chandru usb: ehci: tegra: Fix Slab corruption error d313a52 2013-02-17 Timothy Nelson sweep2wake: Setting cmdline flag to 0 so that this is disabled by default and if the user wants it they can enable it by setting a509061 2013-02-17 Timothy Nelson sweep2wake: Removing additional irq_wake switch that was added 22d37e0 2013-02-17 maxl sweep2wake: Fixup merge mistakes to fix compiling 68205ba 2012-09-29 Dennis Rassmann input: touchscreen: sweep2wake: fix unsafe locking 30a2a0c 2012-09-20 Dennis Rassmann drivers: touchscreen: sweep2wake: add sysfs interface c593298 2012-05-18 showp1984 sweep2wake: fix up a damn mess in the suspend function 6681d97 2012-05-18 showp1984 sweep2wake: remove redundant code b537748 2012-05-17 showp1984 sweep2wake: increase fake suspend time aa065a8 2012-05-17 showp1984 sweep2wake: fix mutex exceptions 2177600 2012-05-09 showp1984 sweep2wake: remove debug message 735d357 2012-05-09 showp1984 sweep2wake: fix values. Somehow I was getting the wrong position data from userspace 7626930 2012-05-09 showp1984 sweep2wake: relocate code to the correct position 1e2de70 2012-05-09 showp1984 sweep2wake: finetune values to allow easier triggering 50136ef 2012-05-08 showp1984 sweep2wake: add Kconfig switch 6f15a5f 2012-05-08 showp1984 cmdline_opt: add initial KConfig switch since sweep2wake depends on this 6af7feb 2012-04-15 showp1984 sweep2wake: add initial sweep2wake support e4846dc 2013-02-17 Timothy Nelson sound: soc: codecs: tlv320aic3008.c: Lowering AUD_CPU_FREQ_MIN to 51000 fd766ea 2011-06-22 jdkoreclipse include: mm: increase readahead buffer 417a122 2011-09-26 jdkoreclipse mm: adjust vm ratios ce2fed6 2011-12-14 Dave Kleikamp Asynchronous I/O latency to a solid-state disk greatly increased between the 2.6.32 and 3.0 kernels. By removing the plug from do_ 6d9804a 2012-06-07 Puneet Saxena cpufreq: Protected access of policy attribute 575109e 2012-09-18 faux123 fs/dyn_sync_cntrl: dynamic sync control 19ba2d6 2012-02-25 faux123 sched: disable GENTLTE_FAIR_SLEEPERS for better performance on Android fca06b7 2013-01-21 Gokhan Moral add SIO I/O scheduler 1896aad 2012-07-29 faux123 tegra: custom user voltage control e5105fb 2013-02-19 TripNRaVeR touchscreen: synaptics_3200: disable SYN_CALIBRATION_CONTROL 64ada4a 2013-02-19 TripNRaVeR cpufreq: interactive: tweak settings f625a66 2013-02-19 TripNRaVeR cpufreq: interactive: init more default settings f612ffb 2013-02-18 TripNRaVeR cpu-tegra: add proper transition latency b463ea5 2013-02-18 TripNRaVeR cpufreq: update interactive governor to latest revision 28ce653 2013-02-17 TripNRaVeR arm: set HZ to 100 90a5d7f 2013-02-17 TripNRaVeR tegra3_throttle: remove no_thermal_throttle_limit b7396b6 2013-01-27 TripNRaVeR cpu-tegra: always set clock speed for all cores 0f331ef 2013-01-27 TripNRaVeR cpu-tegra: remove no_edp_limit bb1393d 2013-02-19 Thomas Wendt Disable OS check for the mass storage gadget 0bbcda7 2013-02-17 tbalden Removing endeavoru lun_cdrom flag to let ums work rw instead of ro. c5c1b79 2013-02-20 Timothy Nelson KozmiKKernel: Updating init.rc f6d69f8 2013-02-20 Timothy Nelson KozmiKKernel: Updating compile script to build boot.img from source rather than from base db17adb 2013-02-20 Timothy Nelson KozmiKKernel: Removing bootimg.base directory as it is no longer necessary since we are now bulding boot.img from source rather t ad6e396 2013-02-20 Timothy Nelson KozmiKKernel: Adding aosp/cm ramdisk for compiling 7dc690d 2013-02-20 Timothy Nelson KozmiKKernel: Adding sense ramdisk for compiling ce5d14c 2013-02-19 Timothy Nelson Patch: Complete removal of BEST_TRADE_HOTPLUG, TEGRA_INTERACTIVE_GOV_ON_EARLY_SUSPEND, and TEGRA_CONSERVATIVE_GOV_ON_EARLY_SUSPEN f467216 2013-01-03 TripNRaVeR cpu-tegra: fix compiling without BEST_TRADE_HOTPLUG enabled 9946af0 2011-08-21 Nandita Dukkipati Proportional Rate Reduction for TCP. cd01458 2012-08-10 faux123 block/deadline: tweaked for better performance on android dc84aa3 2013-02-19 TripNRaVeR board-endeavoru: volume wake fix af391fe 2013-02-18 TripNRaVeR board-endeavoru-panel: fix warning passing argument 5 of 'setup_timer_key' makes integer from pointer without a cast cce6e11 2013-02-18 TripNRaVeR board-endeavoru-panel: add and enable smartdimmer settings bc0b00e 2013-02-18 TripNRaVeR board-endeavoru-panel: lower default brightness 26e7ce1 2013-02-19 TripNRaVeR misc: cable_detect: enable ac charger for unknown chargers 4448a3e 2013-01-03 TripNRaVeR patch: remove htc's check of rebooting system (fix permission error on aosp) e361756 2012-08-10 Karthik Ramakrishnan arm: tegra: Board files settings for LP1 0.95V CoreV 6047921 2013-02-17 Timothy Nelson arm: tegra: Set Core to 0.95V in LP1 c2e9965 2013-02-17 Thomas Wendt LP5521 LED: Use a work queue for button backlight fading 46de18f 2013-02-02 tbalden Refreshing bluetooth driver fro use with android 4.2.1_r1 39a096f 2013-02-15 tbalden Audio cleanup, removing unneeded changes, reverting DPS flag back - fixes FM radio. c9fc07b 2012-06-10 David Herrmann HID: uhid: introduce user-space I/O driver support for HID 95950cd 2013-02-16 showp1984 Updating .gitignore 93515c6 2013-02-16 Timothy Nelson arch: arm: adding piggy.xzkern.S necessary for using XZ compression 5cc3621 2012-05-12 showp1984 arch/arm: add XZ compression support f343e39 2013-02-17 TripNRaVeR KozmiKKernel: Updating bootsense.img with edits to stop pnp from trying to run 24c07a2 2013-02-17 Timothy Nelson KozmiKKernel: Fixing compile script to properly build booticj.img 1df6060 2013-02-17 Timothy Nelson KozmiKKernel: Setting up to compile and build both sense boot.img and icj boot.img c264289 2013-02-10 Timothy Nelson KozmiKKernel: Update debug script to return to Build directory after compiling e6648b5 2013-02-10 Timothy Nelson KozmiKKernel: Add debug script just to compile kernel to aid in quicker debugging. 97fd2d3 2013-02-05 Timothy Nelson Patching to endeavoru-jb-crc-3.1.10-e8d900a c33d806 2012-09-26 Colin Cross timekeeping: fix 32-bit overflow in get_monotonic_boottime 22225f7 2013-02-07 Timothy Nelson KozmiKKernel: Fixing compile script to copy cfg80211.ko from compat rather than from net. Necessary for wifi to work. 06ba1c3 2013-02-07 Timothy Nelson KozmiKKernel: Setting permissions for modules in install script e189420 2013-02-07 Timothy Nelson KozmiKKernel: Defconfig: Updating 57a2843 2013-02-07 Timothy Nelson KozmiKKernel: Defconfig: Updating 882b6e7 2013-02-07 Timothy Nelson KozmiKKernel: Defconfig: Updating 6ea51d6 2013-02-06 Timothy Nelson KozmiKKernel: Removing unused structure.new files and directories as well as the extract script which is been integrated into the 81cfec2 2013-02-06 Timothy Nelson KozmiKKernel: Removing unused structure.new setup from compile script 24a8137 2013-02-06 Timothy Nelson KozmiKKernel: Fixing compile script to compile and remove changed items upon compiling fa195e2 2013-02-06 Timothy Nelson KozmiKKernel: Changing compile script to use kozmik_defconfig 99a3a0d 2013-02-06 Timothy Nelson KozmiKKernel: Adding kozmik_defconfig 5607edb 2013-02-06 Timothy Nelson KozmiKKernel: Adding .gitignore to exclude KozmiKKernel.zip upon compiling e917236 2013-02-06 Timothy Nelson KozmiKKernel: Adding update script / binary 7c785f3 2013-02-06 Timothy Nelson KozmiKKernel: Updating compile script 16485e2 2013-02-06 Timothy Nelson KozmiKKernel: Updating Kernel Injector with endeavoru sense boot.img 2388f16 2013-02-06 NIKER Kernel injector 3aef8ff 2012-09-24 Dennis Rassmann fix gcc4.7 compile 4cfe921 2013-02-05 Timothy Nelson ts27010_misc.h: Inlining error, removing inlining to fix 1e90dff 2013-02-05 Timothy Nelson endeavoru-jb-crc-3.1.10-cl128187-3 TELECHARGEMENT (v013) : http://d-h.st/qXCINSTALLATION :- :excl: :excl: FAITES UN BACKUP :excl: :excl: :excl:- Flasher la boot.img (contenu dans le zip) fastboot flash boot boot.imgLe zip contient 2 boot.img :-bootaosp pour les ROM aosp-bootsense pour les ROM senseEvidemment il faut flasher la boot.img en rapport avec sa ROM !!- Flasher le zip téléchargé via le recovery-Redémarrer et profiter de l'overclock !! :excl: :excl: A 1,700 Ghz votre téléphone seras brûlant, si vous voulez effectuer un test de cpu attendre que le téléphone se stabilise a 30°C :excl: :excl: :excl: Si vous n'attendez pas le téléphone redémarreras (surchauffe) ou sinon vous pouvez le mettre au frigo comme herveonex !!Avec ce kernel je vous conseille vivement d'utiliser l'appli Cpu Master pro disponible sur le playstore ==>https://play.google.com/store/apps/details?id=com.antutu.CpuMaster&hl=fr pour ainsi éviter de cramer votre sac ou votre poche quand vous ne vous en servez pas :P Selectionner profiles =>cocher sreen off => mettre la fréquence max en dessous de 1000 MHz (1Ghz)Pareil pour "Charging" pour éviter les surchauffes quand il charge ! (cpu + batterie en charge = ...) Modifié 28 août 2013 par nicolas@LOVE.android/4 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
thewytcher Posté(e) 6 juillet 2013 Share Posté(e) 6 juillet 2013 il va exploser! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 6 juillet 2013 Auteur Share Posté(e) 6 juillet 2013 Faut pas le mettre a 1,700 GHz c'est tout ! Tu peut monter à 1,624 GHz large Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 6 juillet 2013 Share Posté(e) 6 juillet 2013 Je teste ça lundi avec la probam mix ,si c'est compatible bien sûre . mode vidage de batterie en 30 minutes :) Envoyé depuis mon HTC One X avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 6 juillet 2013 Auteur Share Posté(e) 6 juillet 2013 C'est compatible ! Tu verra c'est pas mal 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 6 juillet 2013 Share Posté(e) 6 juillet 2013 (modifié) Cool ; ) je fais un retour après. Envoyé depuis mon HUAWEI MT1-U06 en utilisant Tapatalk 4 Beta Modifié 6 juillet 2013 par herveonex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 7 juillet 2013 Share Posté(e) 7 juillet 2013 (modifié) Testé sur la domination build 11 ::: chauffe trop vite (logique) , domination 10 mix superjey : idem ............. A 1.624 ghz (build 11/ 10 mix) un test antutu et quadrant et le tel boot :P pour un score décevant , test à 30° merci le frigo :o . A 1.700 ghz (build 11/ 10 mix )un test sous quadrant toujours à 30° le tel boot direct au lancement. Par contre a 1500 ghz ,c'est une fusé le build mix, pas testé les scores mais la je le laisse ce refroidire doucement ,pour passer à la probam v2.2 mix. Modifié 7 juillet 2013 par herveonex 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 7 juillet 2013 Auteur Share Posté(e) 7 juillet 2013 Je te conseille d'utiliser cette appli ou un équivalent pour économiser de la batterie et pour que le tel refroidisse plus vite : https://play.google.com/store/apps/details?id=com.antutu.CpuMaster&hl=fr Tu vas dans profiles et tu coche "screen off" =>tu met la frequence max en dessous de 1000MHz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 7 juillet 2013 Share Posté(e) 7 juillet 2013 (modifié) jdcjdr > ce kernel est répertorié depuis belle lurette dans le sujet concernant les kernels -_- est c'est bien précisé qu'il est oveclocké , faites gaffe quand même hein (je pense que kernel-panic peux vous sauvez la vie mais bon...) Modifié 7 juillet 2013 par superjey Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 7 juillet 2013 Share Posté(e) 7 juillet 2013 En général je reste avec le kernel fourni, la je voulai juste tester ,après oui pour leurs autonomie je reste à 1300 lorque c'est possible. . Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 7 juillet 2013 Auteur Share Posté(e) 7 juillet 2013 Je le sait très bien qu'il est répertorié dans le sujet des kernels :) Mais comme ça m'envoyer vers une page XDA, qu'il a été mis a jour récemment j'ai voulu faire un petit tuto car les gens veulent pas forcément ce donner la peine d'essayer de comprendre sur XDA Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jeyy Posté(e) 7 juillet 2013 Share Posté(e) 7 juillet 2013 bientôt on ira chez les gens leur installer des ROM alors? :P 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
TrustNo_1 Posté(e) 8 juillet 2013 Auteur Share Posté(e) 8 juillet 2013 Et pourquoi pas ^_^ ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
