steph_du_38 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 (modifié) La première ROM Android 4.2.2 Custom pour Micromax A116 Canvas HD (Stable ROM) Without TP Upgrade BLOW TO UNLOCK+WALKMAN+TOUCHWHIZ+S4 MEDIA+BUMP+S-VOICE Features:- --> Android 4.2.2 --> S4 TouchWiz Launcher --> S4 Task Manager --> Samsung S4 Wallpapers --> Samsung S4 Music --> Samsung S4 Widgets --> S4 AccuWeather --> Samsung S4 Sounds --> S4 UI Sounds --> S4 Notifications --> S4 Alarms --> Samsung Bootanimation --> Samsung Boot Logo --> Samsung S4 Fonts --> Samsung S4 Dailer --> Samsung Framework --> Samsung Settings --> Wireless Display --> New LockScreen (blow to unlock) --> New Gesture supported Keyboard --> New Sound Recorder --> Ext4 Tweaks --> Maxed out speed & Performance --> Disabled most logging activities --> Battery calibrated automatically --> VM heap tweaks --> Extended Reboot Commands --> Init.d Added --> Open VPNs --> Bash Command Added --> Fully Deodexed --> Removed Micromax Registration --> Full CPU & GPU Utilization --> Build.prop Tweaks --> Init.d Scripts --> Faster and Smoother --> Faster Streaming --> Internet Tweaks --> Network Tweaks --> Proximity Tweaks --> Battery Tweaks --> Samsung S-Voice --> Bump feature (sharing) --> Walkman --> GPS fixed Xposed Framework --> XTheme Engine --> Xposed Tweakbox --> Xposed TabletUi --> Xposed Clock --> Xposed Delivery Notify Toast --> Xposed Additions --> Xposed Icon Themer --> Xposed Smiley Replacer --> Xposed CRT Animation NO need to DOWNLOAD any other app for downloading videos from YOUTUBE "Click on OGyoutube" it will show download option for videos {Same GUI as YOUTUBE} How To Flash : You Can Take CMW Backup/TWRP Backup to Revert back to your old system (Just in case) Please Note that the first boot may take upto 10 minutes. 1) Download Melting Rocks.zip File 2) Put into External/Internal SD Card 3) Go to CMW Recovery/TWRP Recovery 4) Wipe Data 5) Wipe Partition 6) Wipe System 7) Wipe Dalvik Cache 8) Select Install From SD (Internal or External) 9) Select Melting Rocks.zip and Select YES 10) If in CWM select OK / TWRP swipe to flash NOTE:- This ROM is not Pre-Rooted so u have to root it; Download and Flash Attachment below after installing My Rom 11) Reboot Your System 12) Enjoy Known bugs: NONE as GPS is fixed no extra patch needed TELECHARGEMENT ou sur MEGA PATCH pour améliorer l'installation, merci YAK-B ;-) A faire avant de mettre la ROM sur la SD. Voila, alors les fichiers à remplacer sont là dedans : melting.zip Prenez le fichier "Melting Rocks V1 JB-4.2.2.zip", supprimez le dossier META-INF et le fichier logo.bin qui sont dedans, et mettez les fichiers de "melting.zip" Il doit y avoir à la racine du zip de la ROM: data META-INF (celui de melting.zip) system boot.img Voila ça devrait passer :) TELECHARGEMENT ROOT LIEN POUR LE SITE OFFICIEL DE LA ROM Modifié 13 juillet 2013 par steph_du_38 Citer
titi8637 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 J'vais attendre les 1er retours, mais je pense que celle ci c'est la bonne !!! !!! Citer
ccd_24 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Je suis en plein DL, une fois testée, je vous donnerai un retour, sachant que la Xperia V2 est pour l'instant la meilleur sur tous les points... Je resterai objectif bien entendu. Par contre quelqu'un sait si elle est en français? Citer
brolysan Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 si quelqu'un l'ayant dl pouvait la re upper ailleurs, histoire de pouvoir la dl...trop d'users dessus...:) https://docs.google.com/file/d/0B5s5hOXKxZmJTndzZkVnd1QwRTA/edit?usp=sharing http://www.facebook.com/l.php?u=http%3A%2F%2Fwww.mediafire.com%2Fdownload%2Fgy6mm6s9la1lcy1%2FMelting_Rocks_V1_JB-4.2.2.zip&h=4AQGoHTew Citer
SuperdroidFR Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 c'est dommage car sur le micromax/peax/king/five c'est toujours xperia ou samsung qui revient tout le temps Citer
amapi Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Domage qu'ils ne propose pas une rom light (avec RIEN dessus) plutot qu'une custom directement full gadget. Mais je salut quand même l'effort et le partage Citer
ccd_24 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 si quelqu'un l'ayant dl pouvait la re upper ailleurs, histoire de pouvoir la dl...trop d'users dessus...:) https://docs.google.com/file/d/0B5s5hOXKxZmJTndzZkVnd1QwRTA/edit? usp=sharing Va sur le lien officiel puis tu aura un lien miroir http://www.facebook.com/l.php?u=http%3A%2F%2Fwww.mediafire.com%2Fdownload%2Fgy6mm6s9la1lcy1%2FMelting_Rocks_V1_JB-4.2.2.zip&h=4AQGoHTew ROM très fluide et installation pas plus longue que les autres...10min non...3 oui. Pour le reste tout fonctionne! Citer
amapi Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 gps, boussole, capteur de luminosité, radio FM tout tout tout ? (c'est pas que je veux pas tester, mais a 0.00000000000001 kb/s je risque de finir le download a la prochaine eclipse de jupiter ...) Citer
steph_du_38 Posté(e) 12 juillet 2013 Auteur Posté(e) 12 juillet 2013 (modifié) Par contre quelqu'un sait si elle est en français? Oui tu peux la mettre en FULL FR si quelqu'un l'ayant dl pouvait la re upper ailleurs, histoire de pouvoir la dl...trop d'users dessus... :) Sur MEGA ca t'irais ??? EDIT : AJOUT DU PATCH ROOT dans le 1er POST (a flasher sous CWM) EDIT 2 : Upload sur MEGA en cours (encore 55 min. environ) Modifié 12 juillet 2013 par steph_du_38 Citer
amapi Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Hum de ce que je vois dans cette rom. Le stockage interne na pas été étendu, il est toujours a 1Go il n'y a pas de swap sd interne / externe. C'est un peu embêtant. Citer
steph_du_38 Posté(e) 12 juillet 2013 Auteur Posté(e) 12 juillet 2013 (modifié) Le plus drôle dans tout ca c'est que moi, je n'arrive même pas a l'installer cette ROM :-( :-( :-( Installation OK mais après, ca reste bloqué sur le logo animé SAMSUNG Modifié 12 juillet 2013 par steph_du_38 Citer
amapi Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Le plus drôle dans tout ca c'est que moi, je n'arrive même pas a l'installer cette ROM :-( :-( :-( C'est à dire ? Ca bug au flash via CWM ou alors ça bootloop aprés l'install ? Citer
steph_du_38 Posté(e) 12 juillet 2013 Auteur Posté(e) 12 juillet 2013 (modifié) bootloop apparement :-( Deja 3 ou 4 fois que je réistall avec TOUS les wipes avant... J'comprend pas J'ai retiré mes 2 cartes SIMS et ca fonctionne... Trop bizarre... Modifié 12 juillet 2013 par steph_du_38 Citer
amapi Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Moé ... bon, dans le doute, je vais pas installer alors (meme pas fini de dl ...). Déjà que je suis pas fan des gadjet et des surcouche, autant pas tenter le diable Citer
steph_du_38 Posté(e) 12 juillet 2013 Auteur Posté(e) 12 juillet 2013 si quelqu'un l'ayant dl pouvait la re upper ailleurs, histoire de pouvoir la dl...trop d'users dessus... :) Voila le LIEN sur MEGA. Citer
brolysan Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 je vais tester, mais ca va être dur d'etre mieux que la rom Emotion (pour ma part). Wait and feedback.... Citer
YAK-B Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Ils ont porté le framework Samsung pour de vrai ?? :rolleyes: Avec le double fenêtre et tout ?? Il faut que je teste ce truc, merci pour le lien :D Citer
steph_du_38 Posté(e) 12 juillet 2013 Auteur Posté(e) 12 juillet 2013 Pour le peut que j'ai testé, une fenêtre par dessus le HOME pour voir une vidéo ca fonctionne a merveille.. Citer
brolysan Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 j'ai testé rapidement, je reviendrai plus tard dessus je pense, je retourne à mon ancienne en fait. Citer
titi8637 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 j'ai testé rapidement, je reviendrai plus tard dessus je pense, je retourne à mon ancienne en fait. Qu'en pense tu ? Citer
brolysan Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Qu'en pense tu ? bien, ca reste dans le plus pur produit Android, j'avoue humblement que je préfère la Lewa mais surtout l'Emotion en ce moment :) Citer
titi8637 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 Pas eu de soucis particulier dans ton test ? Citer
YAK-B Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 J'ai pas osé installé le zip, le script a l'air foireux Du coup j'ai refais un zip avec le kernel et un script plus "propre", ça a démarré sans problème J'ai pas testé longtemps, c'est trop "samsung" pour moi Mais en tous cas la fluidité du scrolling est impressionnant, rien à voir avec les ROMS 4.2.1 qu'on a Et le framework est pas porté en entier c'est bien ce que je pensais :D Citer
amapi Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 J'ai pas osé installé le zip, le script a l'air foireuxDu coup j'ai refais un zip avec le kernel et un script plus "propre", ça a démarré sans problème J'ai pas testé longtemps, c'est trop "samsung" pour moi Mais en tous cas la fluidité du scrolling est impressionnant, rien à voir avec les ROMS 4.2.1 qu'on a Et le framework est pas porté en entier c'est bien ce que je pensais :D Hoho tu nous partagerais ton zip ? Envoyé depuis mon Wiko Cink Five avec Tapatalk Citer
titi8637 Posté(e) 12 juillet 2013 Posté(e) 12 juillet 2013 J'ai pas osé installé le zip, le script a l'air foireux Du coup j'ai refais un zip avec le kernel et un script plus "propre", ça a démarré sans problème J'ai pas testé longtemps, c'est trop "samsung" pour moi Mais en tous cas la fluidité du scrolling est impressionnant, rien à voir avec les ROMS 4.2.1 qu'on a Et le framework est pas porté en entier c'est bien ce que je pensais :D C'est à dire ? Tu veux dire quoi par "pas porté en entier"? J'me renseigne car elle m'intéresse :-) Citer
