[ROM][4.2.2 JB] MoKee OpenSource Project
Je voudrais vous présenter une ROM que j'utilise depuis un petit moment maintenant, qui intègre des fonctionnalités intéressantes.
Voici déjà le lien vers XDA : http://forum.xda-developers.com/showthread.php?t=2330749
Cette ROM s'appelle donc MoKee OpenSource Project. Je vous préviens, elle nous vient de Chine ! :)
Site officiel : http://www.mfunz.com/
Liste des fonctionnalités :
- Odexed for faster performance (only in official releases, nightlies are deodexed)
HALO (https://play.google.com/store/apps/details?id=com.paranoid.halo)
PIE control (https://play.google.com/store/apps/details?id=jun.ace.piecontrol)
- Calendar - with lunar and solar calenders
Lunar calendar in lock screen
- Task switching sidebar in recent apps (the list will increase if you install supported apps)
- Bulk SMS recipients
Adjustable SMS font size
Smart dialing
IP dialing
Adjustable navigation bar height
Custom transparency for status bar and navigation bar
Ad-Hoc peer-to-peer network connection - Use MoKee's built-in kernel, otherwise the function is not available.
Built in timer in Apollo - determine when to stop playing music
CRT animation switch
Custom operator name
Network speed in status bar
Preview option in launcher (similar to the preview function in launchers found in Play Store)
Permissions Manager
MoKee NotePad
ListView animations
Many more! Since we are constantly adding new features, see changelogs to keep updated!
- Magic Fun Desktop logical adjustment (you'll like it)
- Multi-user settings
- Adjustable status bar - quick setup to adjust the number of lines
- Quick tiles row option
ListView Animations
Gesture support in launcher
Téléchargement :
RC4 :
umts_spyder : http://d-h.st/hDy
spyder : http://d-h.st/pE3
Nightly :
umts_spyder : https://s.yunio.com/public/folder/token/oq!xua/tokenurl/JTJG/suburl/JTJGdW10c19zcHlkZXI=
spyder : https://s.yunio.com/public/folder/token/oq!xua/tokenurl/JTJG/suburl/JTJGc3B5ZGVy
Par la suite, on peut s'inscrire sur le forum du site officiel pour pouvoir récupérer les nouvelles versions. Lorsqu'une nouvelle version est dispo, une notification apparaît sur le terminal.
Il vous faudra également les GApps :
Des packs intéressant sont dispo ici : http://goo.im/devs/deveshmanish/gapps
Installation :
Note:This ROM uses kexec kernel(3.0.8).
Wipe data/factory reset
Wipe dalvic cache
Flash ROM(SS slot 1,BMM any system)
Flash Gapps
Reboot
Je vous laisse regarder les screenshots mis à disposition sur XDA.
J'ai pu l'installer sur BMM romslot 2.
  • 6 months later...
Toujours seul sur ce sujet, c'est dommage, la ROM est extra ;)
Après quelques mois sans utiliser cette ROM, je l'installe à nouveau car elle a été mise à jour avec la version 4.4.2 KitKat.
Un nouveau topic a été ouvert sur XDA pour la version 4.4.2 : http://forum.xda-developers.com/showthread.php?t=2596176
L'ancien lien pointant vers la version 4.2.2/4.3.
Voici les features :
  • Odexed for faster performance (only in official releases, nightlies are deodexed)
  • Incremental updates
  • OTA updates - update on the fly!
  • Native exFAT support (Samsung devices only)
  • ListView animations
  • Multi window
  • Calendar - with lunar and solar calenders
  • Lunar calendar in lock screen
  • Task switching sidebar in recent apps (the list will increase if you install supported apps)
  • Bulk SMS recipients
  • Adjustable SMS font size
  • SMS sending delay
  • Smart dialing
  • Speed dialing
  • IP dialing
  • Custom carrier name
  • Network speed in status bar (upload and download!)
  • Ad-Hoc peer-to-peer network connection - Use MoKee's built-in kernel, otherwise the function is not available.
  • Built in timer in Apollo - determine when to stop playing music
  • MoKee NotePad
  • MoKee Setup Wizard
  • Active Display
  • HALO
    ** Not yet merged
  • PIE control
  • Auto hide status bar
  • Adjustable navigation bar height
  • Custom transparency for status bar and navigation bar
  • CRT animation switch
  • Smart capture
  • Preview option in launcher (similar to the preview function in launchers found in Play Store)
  • Many more! Since we are constantly adding new features, see changelogs to keep updated!
Parmi ces features, il est indiqué qu'il y a HALO mais je ne l'ai visiblement pas sur la version que j'utilise.
Par contre, ActiveDisplay est une vraie bombe ! :)
Comme la version précédente, j'ai pu l'installer sans problème avec BMM en romSlot 2.
  • 1 month later...
J'utilise la Mokee 4.4.2 depuis deux jours... jusqu'ici tout va très bien! :)
Installation ultra-rapide (avec SafeStrap)
Je la préfère même à la CM11, elle me parait plus fluide, et j'ai l'impression d'avoir plus d'autonomie... à confirmer...
Petit tracas: je ne trouve pas comment changer le nombre de lignes et de colonnes du homescreen?
Désolé, j'ai déjà changé de ROM :D Au profit de la CyanFox ^^
Je ne me souviens plus si c'était possible de changer la disposition du homescreen. A vrai dire, j'utilise Nova Launcher depuis pas mal de temps, du coup j'ai pris l'habitude de l'installer directement après l'installation de la ROM
