[ROM][4.1.2][14/08] Velocity ROM series
Le but de cette ROM est une optimisation de la RAM ainsi que les performence, le tout, sur une interface propre et claire.
1. Based On latest version of JB for galaxy s3 mini (4.1.2) AMG3
2. De - bloated
3. De - Odexed
4. Bravia Engine 3
5. Direct Inject Mods included
6. All new Wallpapers and Cyanogen Ringtones added
7. Aura Status bar series
8. Latest Google Play store (4.3.10)
9. All new UI sounds ( was tired of the nature sounds)
10. New fonts (from s4)
11. LMT LAUNCHER (gives you pie controller options) (if selected from add-ons package)
12. Latest Busy-box and Superuser
13. Complete bare-bone.. It cant get any better than this. See the Screen Shots.( u install what u want from addons package)
14. Supports all versions of GS3 mini
16. TouchWiz/holo launcher/ nova launcher (what ever u want)
FIRST OF ALL DOWNLOAD THE ROM AND THE ADD-ONS PACKAGE. READ THE F.A.Q SECTION THEN.(ITS REALLY IMPORTANT)
1. Back Up all Your Important Files as the Rom is wipe-only.
2. Copy the rom to SD CARD and Boot to CWM revovery.
3. Click WIPE CACHE PARTITION -> wipe
4. Click Advanced -> Wipe Dalvik - Cache -> wipe
5. Click Mount Partition ->
a. Format /System -> yes
b. Format /Data -> yes
c. Format /Cache -> yes
6. Click Wipe Data/Factory Reset -> yes
7. Install the rom
 Click sur l'image.
AS U CAN SEE THAT THE ROM IS COMPLETE BARE-BONE AND HAS ONLY A HAND FULL OF APPS INSTALLED. SO I HAVE ADDED UP AROMA INSTALLATIONS FOR INSTALLING WHAT YOU LIKE...
Installation :
1. After Installing the rom Download the Add-ons Package.
2. Flash it via CWM and follow Instructions and install your favourite apps.
Lien: http://d-h.st/K9n
A ne pas oublier les ADD-ons sinon, il n'y aura pas le Play Store.
Lien du topic officiel: http://forum.xda-developers.com/showthread.php?t=2385568
Modifié par YoshiFrance
Salut le premier fichier c'est la Rom et le deuxième utilise le système aroma pour mettre des options différentes, mais après une journée d'utilisation intensive j'ai réinstallé la DMOD V6 qui est pour moi la meilleur rom à utiliser au quotidien :-)
Modifié par fandef
Ah oui et n'oublie pas de flasher les addon sinon aucune apps ! Je l'ai en ce moment parce-que je suis en camping et elle tient bien en batterie ;)
Envoyé depuis mon GT-I8190N en utilisant Tapatalk 4 Beta
Comment fait tu? Moi elle fond a vue d'oeuil! Je sais pas pk... bon... jessaye pendant 1 semaine et je vous fais un retour.
Dis moi qua tu change dans le cpu control, @bigyohann
Rien :D économie d'énergie et c'est tout... Après, je l'utilise pas trop en ce moment, je fais du kayak toute la journée mais je préfère rester en rom stock, la batterie tient mieux !
Je vais peut-être installé la ROM, je vais voir ^^
Par contre, est-ce qu'on peux installé la ROM avec le TWRP ?
Envoyé de mon iPod touch à l'aide de Tapatalk
