HUAWEI G700 [MT6589 2Gb RAM 8Go ROM 3G 900Mhz]
One
Voilà un petit qui me semble intéressant avec ses 2Gb de RAM embarqué le tout avec la qualité HUAWEI et le support de la 3G 900Mhz :)
Brand / Model
Huawei G700
CPU
CPU: MTK6589 Quad Core 1.2GHz
GPU: PowerVR SGX544MP
OS
Android V4.2.1
Default English.
We can install Italian, German, Russian, Portuguese, Spanish, French, Dutch, Czech, Polish, Romanian, Danish, Greek, Brazil Portuguese, Croatian, Latvian, Lithuanian, Hungarian, Afrikaner, Ethiopic, Indonesian, Malay, Catalan, Norwegian, Roma, Slovak, Slovenian, Finnish, Swedish, Swahili, Filipino, Vietnamese, Turkish, Zulu, Bulgarian, Serbian, Ukrainian, Persian, Hindi, Thai, Korean, Arabic, Hebrew, others please ask
(Please advice us your favorite language upon order confirmation)
Memory
RAM : 2GB / ROM : 8GB eMMC
MAX supports 32GB Class 10 Micro SD Memory Card (TF-Card)
Size
142.5 x 72.8 x 8.95 mm
Weight
155g with battery
Screen
5.0" HD, 1280 x 720, 16M Colors, IPS-LCD
Capacitive Multi Touch Screen
Network
2G: GSM/GPRS/EDGE: 900/1800/1900 MHz
3G: WCDMA/HSPA: 900/2100MHz
SAR: 0.405W/Kg
Color
Black / White
GPS
Built-in GPS
Connection
Bluetooth with EDR & A2DP
Wi-Fi : IEEE 802.11 b/g/n, supports Wi-Fi hotspot
micro USB 2.0
Camera
Dual Camera
Back 8.0 mega pixel / Auto Focus / Flash Light
Front 1.3 mega pixel, supports Skype Video Calls
Support to shoot 1080P with sound
Sensor
Gravity Sensor, Proximity Sensor, Light Sensor
Radio
FM
Video
AVI, MP4, FLV, 3GP, MOV, ASF, MPEG, RMVB, H.263, H.264, etc.
Audio
MP3, AAC, WAV, etc, 3.5 mm Audio
Special function
G-sensor, P-Sensor, L-Sensor, FM radio, Wifi, GPS, Multi-touch, Schedule Power on/off
Package Includes
- Li-ion Battery 2150mAh x 1
- Earphone / 3.5 mm Audio Jack
- USB Cable
- Charger
A vos avis!!
En quoi?
C'est un tél de marque normal qu'il soit plus chère que les no-names puis des phone avec 2Gb ram compatible 900Mhz ça court pas les rues! Moi ça me semble être une bonne alternative au ZTE v987 :o
Bah c'est de la daube un peu
Ton commentaire aussi, sans argumentation pour le moment c'est de la daube... Évitez quand même ce genre de commentaire, ça fout en général une salle ambiance.
EDIT : Vu que tu as corrigé, je corrige aussi ^^
Modifié par Psychotiks
Si si il est double sim :)
photo a l'appui en bas a droite
Il est dispo a 201€ sur un site frais de port compris, pour 10€ de plus qu'un wiko cink five on a un vrai téléphone de marque avec quelques plus bienvenus :)
J'ai bien hésité avec le zte v987. Je me suis décidé pour celui ci. compromis... batterie plus petite , look qui à l'air moins sympa, un poil plus grand.
Mais 2go de ram et 8 go de rom. Je crois la boussole aussi mais bon pas trop utile pour moi.
Le plus dur serra de se faire à la taille. Dommage que les jiayu passent pas sur le 3g 900mhz.
Commandé hier , plus qu'a patienter.
Tu peux nous faire un retour s'il te plaît quand tu l'auras tâté un peu? ^^
Pas de soucis. Le temps qu'il soit expédié et avec le délais sing post.
A voir aussi si il est otg ou non. Bon j'en ai pas spécialement l'utilité mais je testerai aussi.
Tu la reçu? Si oui, les GAPPS sont installés?
Pas la peine de citer son message pour répondre, et si tu avais regardé la date, tu aurais vu que ça ne fait que 3 jours...
Impossible d'être livré sous 3 jours depuis le Chine.
@Nicnic94
Le fait de citer la réponse précédente vaut aussi pour toi ^^
NICNIC94 as aussi citer et pourtant il na pas eu droit a ce commentaire.
3 jour c´est impossible de chine mais comme je n avais pas vu "sing post", il aurait pu l´acheter sur un site européen...
Modifié par Tuga
Hello.
Ce tel me tente bien pour remplacer mon Xperia T
Seulement, aucune info sur la langue : C'est indiqué que l'on peut ajouté la langue Française, mais cela veux dire qu'il faut surement rooté le tel ?
Les menus seront-ils en Français ?
Merci pour les réponses
Oui il faut le rooter.
Installer Mobileuncle puis le recovery cwm.
Ensuite installer soit une rom custom multi-langue soit l'appli morelocale2
Si on n'installe pas une rom custom avec les gaps il faut aussi les mettre par le recovery.
Sur needrom il y a une custom basée sur le dernier firmware du 15 aout qui à tout de compris.
Sinon passer par la dernière rom stock et ensuite faire tout seul c'est amusant aussi. Je pense que je ferais ça quand je l'aurais reçu.
Téléphone reçu aujourd'hui. Pas mal pour l'instant.
Pour l'instant juste rooté et mis les gapps.
J'ai mis les gaps cyanogen car pas trouvé les complete paranoid pour android 4.2.1.
Viré quelques applis chinoises.
Rien de plus pour l'instant.
Dans le menu ingénieur il y a bien WCDMA 2100 et 900. Mais pas encore testé.
Édit : 13284 sur antutu 3.4
Et un petit truc pas mal du tout : il est EAPSIM direct. Freewifi secure OK.
Modifié par NicNic94
Pas de test du 900 Mhz uniquement pour l'instant.
Je n'arrive plus a afficher le menu engineer MTK.
Possible que çà viennes de la dernière version de la rom.
Je ne trouve rien de probant sur le net à ce sujet la.
Par l'appli téléphone quand je tape la dernière étoile la ligne disparait.
Et dans mobile uncle quand je vais dans engineer ça revient sur le menu principal.
Bonsoir,
Pour le GPS ça semble impeccable. Depuis la fenêtre de mon appart, donc pas de bonnes conditions.
Premier test avec wifi, dix assez rapide. J'ai laisser tourner 10 minutes.
Ensuite en mode avion 5 minutes plus tard fix quasi instantané.
Ensuite 20 mintutes plus tard fix en 12 sec.
A tester encore en conditions réelles mais ça me semble tout bon.
Bonsoir,
Essai du GPS un jour plus tard en extérieur et en mode avion. Pas de soucis fix en 30s sous un arbre.
Pour le non essai du 900nhz avec le mode engineer qui ne fonctionne plus, je verrais a la prochaine ROM Huawei.
J'en profiterai pour approfondir le test du launcher émotion ui qui semble pas mal. Je suis actuellement sur une ROM custom avec apex.
L'autonomie a l'air pas mal pour l'instant.
La qualité audio telephone est bonne.
La fonctionnalite miracast fonctionne bien (affichage sur TV en wifi).
Ce n'est pas encore mon téléphone principal mais j'attend avec impatience la sortie de Blackberry messenger pour qu'il le devienne.
Bon une nouvelle rom vient juste d'arriver sur le site de huawei. Ca va m'occuper se we....
J'espere que cela réglera le mode engineer. Pas de changelog comme d'habitude...
Bonsoir,
Info très intéressante. Le G700 arrive en Septembre en Europe.
Tarif indiqué de 249 euros.
EDIT : Viens de voir l'article sur le site désolé c'est déjà dit. Ça reste pas mal quand même, même contre le Nexus 4 qui est simple sim ,et sans sd...
