alexgalaxy73 Posté(e) 27 août 2013 Share Posté(e) 27 août 2013 (modifié) Features : -System Wide audio (NO NEED TO TURN ANYTHING ON, IT WILL WORK ALREADY LIKE NORMAL SOUND)-New Powerful custom compiled audio libraries-SoX Codec for Superior Audio quality-MP3 LAME Codec for Superior MP3 Quality-Audio Fluence mode set to Broadside-Qualcomm Fluence mode set to FluencePRO-Enabled Qualcomm Surround-Sound recording-Custom made ALSA with auto config feature-Audio Resampling from Android 4.2.2 with level set to maximum of 4-SRS Effect ENABLED (But does not load TruMedia effects so it's just a simple SRS virtualization)-Custom tuned snd_soc_msm main audio configs-xLOUD with modified volumeThis official port is a "lite" version of PureXAudio, as I do not have the device, I cannot port all features of PureXAudio from the XZ :) v5.0 DOWNLOAD HERE v5.0b For ViperOne users compatible with xLOUD tweak (Fixed) Installation : 1) Faire une Nandroid Backup ( Aucune solution pour désinstaller ne sera donner) 2) Télécharger et collez-le à la racine de votre téléphone3) Redémarrez en recovery4) Installez le mod comme n'importe quelle mod/rom5) Aucun wipe nécessaire, juste redémarrez est l'audio devrait être mieux Changelog : v5.0b:-Removed xLOUD files, replaced with posteffect wrapper to make xLOUD compatible with ViperOne users (Thanks to :.Infinityx.: for testing)v5.0:-Added Samsung Audio Engine libraries-Added working Sound Alive libraries (system-wide)-Added mysound, preprocessing and output processing from SGS4-New ADSP firmware with adsp-loader module which automatically gets loaded upon startup-NEW MOTO X SoundFX Libraries and NEW audio files!-NEW MOTO X MMI Effects-NEW Android 4.3 Libraries and added to audio_effect.conf-Corrected audio_effects.conf-Fixed FCs on 3rd party Equalizers (e.g Noozxoide) if FC was there before-Cleaned up some files-Removed TFA folder to prevent any speaker distortion or abnormalities-Added xLOUD-Modified snd_soc_msm_2x_Fusion to make xLOUD work like Xperia devices-Increased xLOUD volume by 5 values morev4.0:-General Clean-Up-Added a whole bunch of new libraries-Added some Samsung audio libraries (mysound, soundalive etc)-Added new WCD9310 firmware from Nexus 4-Started from scratch again-Added Butterfly Sense 5.1 audio libraries and Beats Audio-Fixed low speaker volume (Stupid HTC :p)v3.0:-ALSA Ported from Xperia Z's PureXAudio-Re-written asound.conf from scratch-ALSA Now uses apq8064tablasnd as PCM to load other plugins-Enabled Complex Convert-Enabled Rate Conversion to 48kHz-Added Dmix PCM-Added Auto-Convert custom pcm-Converts every source audio to Stereo-Much better stereo audio-Even better audio quality-Cleaner MP3 compressed audio with less distortions-Larger buffer size to prevent audio skipping (Uses up more RAM though)-Forced audio to play 48kHz, FLOAT64_BE format and 2 channels (Stereo)-Added loads of new ALSA libraries custom compiled ages ago by aznrice2k4-added apq8064tablasnd soundcard to alias.confv2.0:-Added custom configured asound.state for HTC One-Force Enabled HAC Amplifier-Opened maximum amount of channels in all SLIMBUS Mixers-Enabled a few Mixer switches-Enabled SRS Effect though SND_SOC_MSM_2x_Fusion3 (DOES NOT LOAD TRUMEDIA FILES! It's just the effect)BETA 1.3:Updater script now auto mounts system and data without errors :) (Thanks to legents for testing)BETA 1.2:-reverted 192kHz audio back to stock sampling rateBETA 1.1:-Removed mounting lines temporarily to fix Status 6 errorBETA 1: Initial release of the official port Modifié 27 août 2013 par :..Infinityx..: Lien vers le commentaire Partager sur d’autres sites More sharing options...
