[Rom][21/08/2013][Sense5][JB][4.2.2][OTA][Enhanced Audio][Xposed Framework]MagioROM R1.5
CHANGELOG :
R1.5: OTA
added XBLAST ( Tweak App )
made sound even better!!!
R1.2: OTA
Wifi fixed..... thanks go to RichmondoUK
R1: Initial Release
rebased 4.18.401.2 (HTC WWE base)
Added CRT Animation and 30 step volume mod
Fixed volwake mod you will now have advanced power menu and the mod enabled
power-profile enhancments
Awesome Battery Life
Tweak audio mods the sound now should be crisp/loud/quality
Xposed Framework.
The official thread is here: http://forum.xda-developers.com/show....php?t=1574401. In a nutshell the Framework allows to modify system files on the fly. Something like Tweaks APP from my previous ROMs.
Xposed Framework (you find it in app drawer if you choose the option in AROMA) doesn't do much for the user by itself. Only allows you to use modules.
Modules can be found here on xda or on modaco:
Modaco Toolkit has some very nice features a user can use and customize the device to his liking. Probably the most feature rich at the moment.
More modules can be found on this very forum on xda
[MOD][XPOSED] BlinkFeed Back to Top [1.0][HTC Sense 5]
[MOD][XPOSED] Smart Alarm Icon [1.2][HTC/Samsung 4.0.3+]
Added AudioBeats enhancements
New Xloud/Clear audio framework added
Sony Bravia engine added for clearer Images
Finally got advanced power menu working
Fixed Rom not working at all for some users. Everyone should have no issues with Rom not booting now
Added DevTool OTA announcements and updates support. please note you have to manually install updates through recovery until i work out how to do it automatically
New OTA support included in Rom via Romdb this also means that I can send announcements if you subscribe to this and instant OTA notifications and download.
Improved battery comsumption by zipaligning apps and editing framework-res values,
new default wallpaper by MagioROM
new boot and down animations by @grinder19
Sense 5
Android Jellybean 4.2.2
Quick settings
Blinkfeed
Show battery level in status bar
sleep mode in power settings
12 quick settings tiles (Being Replaced in next update to Magiorom systemui Exclusive)
ae / af lock feature / Lock Exposure / Focus
Video highlights, 30 seconds show in 12 different themes
100 jpeg quality (props @ivicask)
Music channel visualization with live lyrics
Rooted / unsecured boot.img
init.d support
busybox
Advanced power menu (reboot to bootloader, recovery, hot reboot, safe reboot)
optional for enhanced mms ( light up screen on sms / mms receive)
Full wwe
TELECHARGEMENT :
R1.1 Download
http://d-h.st/a77
R1.2 OTA
http://d-h.st/C6H
R1.5 OTA(wipe cache/dalvik cache after)
http://d-h.st/qtk
OTA Fix Download
http://d-h.st/rxp
Modifié par nicolas@LOVE.android/4
[mention d'application hors charte] dans le screen, ça donne le ton... :)
Blagues à part.. je suis mitigé, d'où je ne l'ai pas encore testée (comme insercoin).. quand je vois toutes ces OTA, ça freine un poil (en si peu de temps)
Bon je suis dessus..
Comment dire : c'est un peu genre j'en met le plus, donc c'est meilleur... c'est fouilli. Aroma, c'est le bordel... dans les mod, ils se supperposent : 3 mod qui ont des fonctions similaires, donc pour param les tweacks...
Sinon c'est pas mal, à voir
XBLAST a l'air intéresant par contre. A voir si on peut l'incorporer ds une autre ROM
Modifié par boisdulait
  • Like 2
  • 1 month later...
Arfff tu triché aussi avec CM ;) beau score !!
Oui moi aussi j'ai du mal avec leur sur couche sense ou touchwiz , cela alourdit bien ... mais bon faut bien tester de temps en temps pour être sûr :)
Ba personnes juste cm , cela ne m'intéresse plus , je préfère les mixe, après ça doit bien fait plus de 6 mois que j'ai plus testé une cm en même temps. Pour la relook alors la je sais pas perso mais si tu le dis ;)
Thewytcher :) tu parlais de qu'elle rom , j'ai pas suivi la .
Envoyé de mon GT-I9505 en utilisant Tapatalk
Oui ont pourai dire ça mais je t'avourai que je me suis pas encore hasardé à bien testé ça et là viper je l'ai pas encore testé en 4.2.2 :(
Modifié par herveonex
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
Version  MagioROMx R4 - HUB FIXED!
R4
https://mega.co.nz/#!fVknBRjC!YAZp9z...9wOkL70-g2AbhI
or
http://d-h.st/CUW
or
https://drive.google.com/file/d/0B43...it?usp=sharing
R4
-Rebased to 4.18.401.3
-FIxed APM issues
-all tweaks ported
-more improvements
-and a lot more
