[ROM] Cyanogenmod for Hero v1.4.3
mr_kuja
Une autre ROM sans Sense du genre rapide et légère (49.14Mo) avec OTA updater!
Topic officiel : http://forum.xda-developers.com/showthread.php?t=708673
Téléchargements
v1.4.2 & 1.4.3 disponibles OTA à partir de la v1.4.1
ROM complète v1.4.1 : http://www.multiupload.com/WFN3XGALGW
MD5sum: 029a2029990142e25d88856a0c5cfb0b
Google Apps : http://www.multiupload.com/N5GQKR9HJK
MD5sum: e6f7f6d84e03a42369054c8f4fc91aa3
Changelogs
27.07 -- Version 1.4
-- complete rebuild of system and all kernels
-- usb tethering via Settings
-- re-worked jit stuff
-- and a lot of tweaks/optimizations
-- Droidwall working, Ndrive working (although you'll see only squares instead of characters if your locale is unsupported in the app)
-- and not working Raging Thunder 2 (but I really don't have the willingness to 'fix' it)
23.07 -- Version 1.3.6
-- notification leds working
-- trackball stuff in settings
-- you now have the option to enable/disable touch UI during calls
-- updated updater
22.07 -- Version 1.3
-- all OTA updates incorporated
-- reverted into flashing rom and google apps separately. The installer will try to backup your google apps if you flash that on top of CMH 1.3+
-- added fully working Facebook sync
-- added some new stuff in settings
-- recompiled all kernels from the official source
05.07 -- Version 1.2
-- updated libraries, including libgps that caused unsatisfactory GPS performance
-- OTA updater
-- Cyanogen-ish bootanimation, thanks to iiro
-- 264/576 MHz kernel by default
Fonctionnalités
Cyanogenmod 5.0.8 final
Auto-brightness
Jogball lights
A2DP
JIT
Compcache
Apps2SD
BFS enabled kernel
Outstanding 3D
360 degree rotation
5 mp camera
Live Wallpapers from Market work nice
Compcache on by default
Screenshots
Kernels
BFS kernel cadencé à 176/691 MHz -- celui utilisé pour le test donnant 34.7 fps
http://www.multiupload.com/Y21VV9SKLG
MD5sum: 9a274f339dafdaa692771ffd843c3a42
Le nouveau kernel par défaut cadencé à 264/576 MHz, pour ceux qui souhaitent privilégier l'autonomie ou ceux dont le Hero ne supporte pas des fréquences plus hautes
http://www.multiupload.com/4X7PL8MRWU
MD5sum: 59f896f1c2a729134083efecaf17324b
Kernel cadencé à 176/691 MHz, supporté par la majorité des Hero
http://www.multiupload.com/U1T6BWLAQ3
MD5sum: 56980b17d1ed5fad398cabcc9f4479b1
Kernel cadencé à 176/768 MHz pour les Hero "chanceux"
http://www.multiupload.com/BBQ5BYWYOH
MD5sum: d5f0ca098b0550200ca988404877a015
Kernel cadencé à 264/691 MHz pour ceux qui rencontrent des problèmes en veille mais qui peuvent supporter jusqu'à 691 MHz
http://www.multiupload.com/PB50ZXSMUQ
MD5sum: 727a8241177bef30001e3a95f3a36db5
Soft-overclockable kernel
http://www.multiupload.com/279QAYAPAU
MD5sum: fa1962e801cc20700b7bb9586d834817
Howtos
Activer JIT
Dans le terminal en root, taper :
jit-on
et suivre les instructions :
- Installer le cache fix : Yes
- Où se trouve votre dalvik-cache : SD card si vous utilisez App2SD ou normal dans le cas contraire
Si vous avez une carte SD de classe 6, il est conseillé de stocker le dalvik-cache sur celle-ci.
Compcache
Pour le désactiver : Paramètres --> Spare Parts --> Compcache (fortement déconseillé)
Apps2SD
Pour l'activer : Paramètres --> Applications --> Apps2SD
Modifié par mr_kuja
  • Réponses 53
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
je suis passé de la Ezhero 5 a celle ci.
tout marche pour le moment ( j'ai changé car anetshare faisais reboot mon Hero après utilisation )
par contre, mon widget overclockwidget ne fonctionne plus, bloqué a 576Mhz..... même en éditant a la main les valeurs, pas moyen de monter a plus....
ça c'est a cause du kernel.
edit : je m'était embrouillé dans ma phrase :x
Modifié par rubixcube
J'utilise launcher pro au lieu d'ADW qui est dans cette ROM
pour l'instant c'est assez impressionnant de fluidité
je donnerais mes impressions générales dans quelques jours
j'étais avant sur vanillaeclair j'en étais content mais là ça à l'air vraiment pas mal
sinon existe t il des themes pour cette ROM?
Modifié par tiago
Une petite news sympa!
This thread will be discontinued very soon! There will be a merge with CMH and aHero and probably with EzHero.
Stay tuned and check your CMH updater daily (yes, the update will be released over-the-air).
Pour les anglophobes, en gros les rom Cyanogenmod for Hero, aHero et a priori EzHero vont fusionner.
Le dev recommande de vérifier régulièrement l'OTA updater pour la mise à jour. :)
Déjà une nouvelle petite mise à jour de dispo : CMH 1.3.6
Elle était censée être dispo OTA mais vu les problèmes sur xda, le dev a filé les liens des zip à flasher! Je met à jour le topic avec les nouveaux liens! :)
Changelog
-- updated updater
Modifié par mr_kuja
Je l ai chargée,juste pour me la "péter" avec le process a 768 Mhz.........ben,cela bloque tout :(
Grosse galére pour revenir en arriere,le nandroid est a l ouest.Et la mise a jour en ota ne fonctionne pas chez moi.
Bref,malgré ses qualités,et ses ptits +,je réessaye la 2.2 Fusion.
Le dev explique bien que le kernel overclockable jusqu'à 768 MHz n'est pas supporté par tous les Hero!
Après pour l'OTA, c'est fixé dans la 1.3.6. Pour ceux en 1.3 il faut se juste se taper la mise à jour "à l'ancienne" et après tout roule! :)
Ok,mais cela m avexé que mon Hero ne supporte pas les 768 Mhz :(
Et cela m a mis un boxon dans mon recovery.Impossible de faire un nandroid pour revenir a ma rom preferée.
En plus,impossible de remettre mes add ons (les deux thémes pour behero). je suis "vénere" apres cette rom.
par contre, je voudrais savoir , la recherche vocale marche bien chez vous ? parce que moi pas moyen d'en tirer quoi que ce soit.
par exemple , je fais un test, je dis "appeler olivier" et lui il me fait une recherche google en cherchant ... "oblivion" . heu ouai, je sais que je suis pas toujours très clair quand je parle mais quand même .
Hello hello,
Suite au conseil de Mr Rubixcube, je suis passé de la rom EzHero à Cyanogenmod (176/691mHz) ; car sous EzHero - même si tout était impec' - le clavier ramait à mort!
Problème résolu, avec Cyanogenmod c'est super fluide! Tout va bien donc, mais j'ai juste une petite question.
Lorsque je vais dans les propriétés de mon téléphone, ils est indiqué que ma rom est EzHero (et non pas Cyanogen) !!?
Est-ce normal? Pourtant j'ai bien fait un wipe total...
Et par contre, impossible d'activer le JIT (sh: Can't open /data/JIT/script/jitfixsd.sh)
Donc si quelqu'un aurait un lien vers ce fameux dalvik-vm fix, je suis preneur! (j'suis une buse, j'arrive pas à le trouver!)
Merci pour vos réponses,
A+
