Lygoss Posté(e) 8 septembre 2013 Share Posté(e) 8 septembre 2013 (modifié) /!\La procédure qui suit a été testé et est sûre mais le risque zéro n'existe pas. En aucun cas Frandroid, XDA ou moi même pourront être tenu responsable en cas de problème /!\ Ce Kernel est basé sur les dernieres source de Maclaw avec Hotplug et PegasusQ governors d'ajouté . Ce Kernel fonctionne sur les ROM CM10.1 de la team Maclaw . Changelog: 2013-09-07 added I/O schedulers ROW, and VR 2013-09-07 added governors PegasusQ and Hotplug 2013-09-08 added I/O scheduler SIO 2013-09-08 removed governor SmartassV2 2013-09-08 compiled with GCC Linaro 4.7.4 2013-09-11 fixed screen tearing 2013-09-11 added abyssplug governor 2013-09-21 added CFQ scheduler 2013-09-21 added Maclaw's offline charging support 2013-09-21 added exFAT support 2013-09-25 added support for 64GB sd cards by Maclaw 2013-09-25 fixed drivers for offline charging by Maclaw 2013-10-02 added I/O scheduler BFQ 2013-10-02 added governor Wheatley 2013-10-04 added XZ kernel compression method (10% faster overall system performance) 2013-10-04 enabled kernel size optimization (additional 5% faster overall system performance) 2013-10-05 added FSync control (Prevents file loss) 2013-10-05 build vfp with neon+hardware-float instead of software-float 2013-10-13 removed XZ compression method and added LZMA compression method (even more fast overall system performance) 2013-10-02 kernel updated to 3.0.100 by Maclaw 2013-10-02 removed LZMA added GZIP again temporarily till LZO is fixed 2013-10-02 updated BFQ scheduler to BFQ-v6r1 2013-10-22 new ramdisk update by Maclaw 2013-10-24 new ramdisk update by Maclaw 2013-11-10 new ramdisk update by Maclaw 2013-11-10 added SELinux support (Permissive) 2013-11-10 refresh rate changed to 61Hz (No screen tearing) Compatibilité: Maclaw's CM10.1 Maclaw's AOKP Maclaw's P.A.C ROM Il est recommandé d'utiliser les dernière build pour chaque ROM. Telechargement: GT-I8190N NFC Kernel - Temporarily stopped developmentGT-I8190 CM10.2 Linaro KernelGT-I8190 CM10.1 Linaro KernelGT-I8190 AOKP Linaro Kernel - Update coming soonGT-I8190 PAC Linaro Kernel - Update coming soonNFCJB_Enabler_V2 - Temporarily stopped development Sources du Kernel: https://github.com/Benzonat0r/android_kernel_samsung_golden# Modifié 10 novembre 2013 par Lygoss Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
danymat Posté(e) 8 septembre 2013 Share Posté(e) 8 septembre 2013 qu'apporte ces nouveaux gouverneurs? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 8 septembre 2013 Share Posté(e) 8 septembre 2013 Tu est expliqué ici: http://forum.xda-developers.com/showthread.php?t=1736168 Je l'ai installé mais la déchirure d'écran est apparut :( aussi, selon Benz, la meilleur combinaison est Pegasusq+vr (meilleur performance et batterie plus performance) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AGC93 Posté(e) 9 septembre 2013 Share Posté(e) 9 septembre 2013 Comment ça une déchirure ? Envoyé depuis mon GT-I8190 en utilisant Tapatalk 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 9 septembre 2013 Share Posté(e) 9 septembre 2013 Le petit freeze de l'écran. Mais il y a une nouvelle realise et elle tourne bien ! Envoyé depuis mon GT-I8190 en utilisant Tapatalk 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
AGC93 Posté(e) 9 septembre 2013 Share Posté(e) 9 septembre 2013 OK ^^ Je pense que je vais changer pour une CyanogenMod.... En ce moment mon téléphone bug trop.... Envoyé depuis mon GT-I8190 en utilisant Tapatalk 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 11 septembre 2013 Share Posté(e) 11 septembre 2013 Bonne nouvelle, il y a une nouvelle realise et elle a une super autonomie ! Envoyé depuis mon GT-I8190 en utilisant Tapatalk 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LNA17000 Posté(e) 12 septembre 2013 Share Posté(e) 12 septembre 2013 Bonjour,Je suis en train d'installer CM 10.1 et je voulais savoir à quoi servait les deux fichiers proposés dans ce post ?Merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 12 septembre 2013 Share Posté(e) 12 septembre 2013 Il y a une nouvelle realise sur le topic officiel. Ce kernel apporte une autonomie amélioré. Envoyé depuis mon GT-I8190 en utilisant Tapatalk 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lygoss Posté(e) 12 septembre 2013 Auteur Share Posté(e) 12 septembre 2013 Le topic n'est pas a jour je le mettrais a jour demain ;) -Tapatalk- Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LNA17000 Posté(e) 13 septembre 2013 Share Posté(e) 13 septembre 2013 Merci :) J'installerai ça après mis à jour du topic alors :) Bonne journée à tous ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lygoss Posté(e) 13 septembre 2013 Auteur Share Posté(e) 13 septembre 2013 Topic mis a jour :) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
iVhael Posté(e) 14 septembre 2013 Share Posté(e) 14 septembre 2013 Je n'ai pas trouver d’évolution significative de l'autonomie. c'est peut etre moi qui suis exigent, mais la dmod, tien facile 3 ou 4 heure de plus minimum. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 14 septembre 2013 Share Posté(e) 14 septembre 2013 L'autonomie sur la CM10.1 et d'environ 15h~18h et sur la Dmod environ 24h (selon mon utilisation: 30 minutes internet, 1h de jeu et 30~45 minutes de lecture de PDF) Envoyé depuis mon GT-I8190 en utilisant Tapatalk 4 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
LNA17000 Posté(e) 14 septembre 2013 Share Posté(e) 14 septembre 2013 Je dois vraiment pas savoir réglé tout ça car je tiens très peu de temps avec CM 10.1 même avec le kernel donc je suis repassé sous Dmod avec qui je peux tenir jusqu'à 48h, là 10h max donc j'ai dois pas être douée x) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bigyohann Posté(e) 14 septembre 2013 Share Posté(e) 14 septembre 2013 Depuis que j'ai cours, je finis la journée avec environ 50% et 12h sur la batterie ;) après, des que j'utilise ça descend vite par contre :D Envoyé depuis mon GT-I8190 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lygoss Posté(e) 22 octobre 2013 Auteur Share Posté(e) 22 octobre 2013 Topic mis a jour :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 26 octobre 2013 Share Posté(e) 26 octobre 2013 J'ai installé ce kernel, je le trouve plus fluide que celui d'origine Envoyé depuis mon GT-I8190 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebastoo69 Posté(e) 26 octobre 2013 Share Posté(e) 26 octobre 2013 C'est quoi la différence entre un kernel et une ROM ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 26 octobre 2013 Share Posté(e) 26 octobre 2013 Le kernel gère la fréquence du CPU, la ROM, gère l'interface utilisateur. Envoyé depuis mon GT-I8190 avec Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebastoo69 Posté(e) 26 octobre 2013 Share Posté(e) 26 octobre 2013 Ca fait quoi exactement, on peut faire quoi avec et surtout, ca change quoi ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
YoshiFrance Posté(e) 26 octobre 2013 Share Posté(e) 26 octobre 2013 Ça peut augmenter les performances du téléphone (le derniers Call of Duty fonctionne mieux) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lygoss Posté(e) 26 octobre 2013 Auteur Share Posté(e) 26 octobre 2013 Topic mis a jour :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lygoss Posté(e) 10 novembre 2013 Auteur Share Posté(e) 10 novembre 2013 Mis a Jour :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
