[ROM][CM7.2] REINCARNATION ROM SERIES pre-Final [JB UI & S4 UI] [02-11-2013] | patch pour regler le problem de drainage de battrie ajoutè
Avec Aroma Installer, cette rom vous donne le chois pour
1-Choisissez votre style de ROM Jelly Bean Series or Touchwiz Series
2-Sélectionnez votre style de barre d'état . Barre d'état transparent ou normal
3-Choisissez votre continent pour le GPS
4-Choisissez le pilote wifi. Stock CM ou Stock firmware
5-Possibilité d'installer Link2SD
Base de Rom: CM7.2 cooper officiel
Concept de Rom: une musique de qualité et la Beauté de l'Interface
Aroma personnalisation
> Jelly Bean interface transparente et non transparente
> Touchwiz / S4 interface transparente et non transparente
Performance :
> FIrekernel OC by dragonn, with 13 type CPU Governor
> 2.3.8 Bluetooth versions
> Adrenaline Engine v.4.5
> Adrenaline Boost PRIME
> Beauty sound system media
> BLN work
> Build.prop tweaks
> Built in flash player 11
> Faster GPS lock, patched GPS fix by Lagloose
> Full GPU rendering
> Integrated host file for adblocker
> Reincardio Engine, give excellent music quality
> Removed beep volume panel
Interface :
> Android 4.x all icon
> Android 4.x clock widget
> Android 4.x dialog
> Android 4.x fonts
> Android 4.x installer
> Android 4.x title bar
> Android 4.x notification panel
> Android 4.x statusbar style. transparent and non transparent
> Android 4.x window animation and transition. with mod by me
> Android 4.x lockscreen
> Android 4.x security lockscreen
> Modded CM lockscreen
> Changeable transparent and non transparent Interface in theme chooser
> New boot animation
Application ajouté:
> Achep theme, modded very light
> Battery bar
> Clean file manager
> Dodol keyboard
> Holo launcher
> Holo locker
> Quicpic gallery
> Samsung stok task manager
> Samsung digital clock widget
> Stopwatch and timer
> Super SU
> Videos like stock samsung video app
> Wallpaper base honeycomb wallpaper
Changelog Versions :
 >Reincarnation pre-Final (02-11-2013)
Both series
> Fix black text in widget picker
JB series
> Change some ICS icon to JB icon
> Revert back apollo music player to MIUI music player
Reincarnation pre-Final (01-11-2013)
Both series
> Aroma Installer Customization
> Merged Reincarnation and Naturalizer
> Improved wifi connection
> Added GPS customization
> Added Statusbar style option.
> Reworked Settings apk
> fix task manager not function
> update Playstore 4.4.21
> Updated Link2SD 2.4.10
> Updated SuperSU 1.65
> Updated Dodol Keyboard
> Removed X-Reality engine
> Added fix fc script
JB series
> Reworked JB Non Transparent theme
Touchwiz Series
> Statusbar with S4 Style
> Replace Stock My Files with Modded Clean File Manager
> Change Boot Animation
> Add Theme for get S4 UI, only 380 kb,
> Mod Holo Locker
Reincarnation V.3 (29-09-2013)
> Restyled all apk
> JB style titlebar
> JB style on/off settings
> JB style caller
> JB Send button Mms
> JB Style center shutter camera
> JB Notification download panel
> JB holo locker for full JB style
> Mod music player to beats style
> Mod deskclock
> Add mod achep ics Theme for get Non transparent UI, only 115kb
> Add samsung digital clock widget, mod to JB Style
> Add Video.apk, Mod to Stock video with JB Style
> Add Wallpaper.apk base Honeycomb wallpaper
> Add battery percent to Expanded Statusbar
> Reworked framework Script and png
> ICS Security lockscreen style
> Change default wallpaper
> Change boot animation to Blue plazma Bootanimation
> Patched GPS patch by lagloose
> Optimize png and zipaligning apk
> Updated Link2sd to 2.4.6
> Add X-Reality Engine tweak from Xperia,i thinks its work fine
> Android 4.3 Font
> Updated Batterry bar 3.2 and Holo Launcher 2.0.3
> And Many More
Reincarnation V.2 (20-08-2013)
> AROMA INSTALLER
> Work both brigthness toggle and slider brigthness
> Updated Gallery QuicPic 2.9.6
> Updated Link2SD 2.4.5
> Updated Q2 Keyboard
> Updated Google Play Store 4.3.11
> Updated Super SU 1.45> Change Dialog Popup Transparency to 75%
> New Dialog Popup Animation
> New Setup Wizard Android Icon
> Corrected Audio Engine
> Corrected Build.Prop
> Corrected SystemUI & Framework Script
Reincarnation V.1.1 (19-07-2013)
> Updated Clean File Manager
> Fix Wifi & Statusbar bug issues
> Correct Build.prop
> Removed some unused binary files
Reincarnation V.1 (15-07-2013)
> Full GPU Rendering
> Mix Beauty System Sound
> Jelly Bean style Statusbar
> Include Battery Bar for MIUI Look
> QuicPic is default gallery
> Latest Holo Launcher and Holo Locker is Default
> Jelly Bean Style Installer
> Blue Setup Wizard And Google Service Framework
> Beauty MIUI Music Player with shortcut equalizer settings
> Jelly Bean style settings Launcher,Lockscreen,statusbar,theme,wallpaper,Superuser,task manager shortcut to settings> Jelly Bean Style MMS with SMS Popup support
> Jelly Bean Style Camera
> Jelly Bean Style Recent App
> Jelly Bean Style Dialog Layout
> Cool Boot Animation
> Transparent Google Search
> Youtube 2.1.6 with Downloader
> Add Stopwatch and Timer apk
> Replace LatinIME with Q2 Keyboard
> Android 4.x Fonts
> Mod CM Lockscreen
> Initial release
buges:
-texte Blanc sur blanc dans certaines application
-Parfois, et que parfois, vous ne pouvez pas modifier la connexion de données,
ex, après vous utilisez une connexion wifi, vous ne pouvez pas utiliser la connexion de données, il suffit de redémarrer ce sera résolu
Comment faire pour installer:
1. Reboot into Recovery
2. Wipe Data
3. Wipe Cache Partitions
4. Wipe Dalvik Cache
5. Install Zip from SD Card
6. Reboot
Download Link :
- CM7.2 Reincarnation Cooper pre-Final.zip
patche pour la battrie
http://www.mediafire.com/?u8vhaiz0qj1o5n7
source:
http://forum.xda-developers.com/showthread.php?t=2506773
Modifié par android akram
  • 5 weeks later...
  • 1 month later...
1 - soit tu peux piquer une apk "settings" d'une autre rom compatible et l'installer dans le system/app avec les permissions
2 - soit tu reflash la rom pour test
3 - soit tu test une rom plus recente comme celle la https://forum.frandroid.com/topic/180185-romcm7-x-themer-%E2%96%BAsealg4-light-%C3%A9dition-release/#entry2892315
Bonjour, voila je viens de l'installer , elle à l'air pas trops mal.
J'ai juste un petit souci , je n'ai pas acces aux parametres de volume ( fermeture soudaine de l'application parametres ,....... )
je penche pour la 2eme solution
