[ROM][4.3][STABLE][Build 2] --Slim Bean N7000--
Update:
 Slim-n7000-4.3.build.1.9-WEEKLY-1282
Changelog:
2013-10-20 | weekly 1.9 [Lars Greiss]
2013-10-20 | Update Nova Launcher [Josue Rivera]
2013-10-20 | snd_soc_msm: Increase microphone volume for camcorder [Dan Pasanen]2013-10-14 | Revert "sprint apns" (HEAD, m/jb4.3, github/jb4.3) [cordell abney]
2013-10-20 | netd: Support the Qualcomm SoftAP SDK. [Jeff Johnson]
2013-10-20 | netd: IPv6 Tethering Support [Chris Lei]
2013-10-20 | netd: Change QualcommSoftapCmd to add AR6004 support [Ming-yi Lin]
2013-10-20 | netd: Add enhanced routing support [Guntawee Tiwapong]
2013-10-19 | Update common proprietary-files [dhacker29]
2013-10-19 | track BluetoothExt [Lars Greiss]
2013-10-19 | snd_soc_msm: Raise speaker volume to 50, no distoration and still safe [dhacker29]
2013-10-19 | snd_soc_msm: Raise Speaker and Voice Speaker usecase volume [dhacker29]2013-10-19 | Move nfc.msm8960 package to device (HEAD, m/jb4.3, github/jb4.3) [dhacker29]
2013-10-19 | snd_soc_msm: Change 'Basic Dock' to 'Dock' [nadlabak]
2013-10-19 | snd_soc_msm_2x: Fix in-call high pitch buzz; enhance Camcorder TX [nadlabak]
2013-10-19 | selinux: add policies [Emerson Pinter]
2013-10-19 | root: Revert back to old thermald, add proper symlink [dhacker29]
2013-10-19 | root: Move thermal conf to device [dhacker29]
2013-10-19 | root: move file_system_config overrides to family [dhacker29]
2013-10-19 | RIL: Use Rlog [dhacker29]
2013-10-19 | Remove signalstrength option to fix 4G signal bar [Emerson Pinter]
2013-10-19 | Refactor recovery build optiosn [dhacker29]
2013-10-19 | Refactor gps HAL to family tree [dhacker29]
2013-10-19 | Refactor for qcom-common [dhacker29]2013-10-12 | Switch to devil kernel by DerTeufel (HEAD, m/jb4.3, github/jb4.3) [tchaari]2013-10-15 | Revert "Add apnlist" (HEAD, m/jb4.3, github/jb4.3) [shareef Ali]
2013-10-19 | Refactor extract files for qcom-common [dhacker29]
2013-10-19 | Refactor: Add libI420colorconvert.so move modem scripts to common [dhacker29]
2013-10-19 | proprietary-files: Update to 4.3 libs keep old adreno for msm8960 [dhacker29]
2013-10-19 | proprietary-files: add libtime_genoff [dhacker29]
2013-10-19 | overlay: Move storage and powerprofile to family tree [dhacker29]
2013-10-19 | Move egl config to family [dhacker29]
2013-10-19 | Move charge_only_mode product from qcom-common to msm8960-common [dhacker29]
2013-10-19 | Move camera wrapper define to family tree [dhacker29]
2013-10-19 | Move batt_health package to family [dhacker29]
2013-10-19 | merge caf latest BT commits into Slim [cordell]2013-10-13 | DSPManager: UG translation, added Uyghur translation. [sahranbay]2013-10-19 | Fixes Mako continues focus problem (HEAD, m/jb4.3, github/jb4.3) [Josue Rivera]
2013-10-19 | libril: Revert custom libril and use BOARD_RIL_NO_CELLINFOLIST [dhacker29]
2013-10-19 | init.target.rc: Add permissions for Torch [nadlabak]
2013-10-19 | fstab: disable encryption [Emerson Pinter]
2013-10-19 | Frameworks: reimport translations [Lars Greiss]
2013-10-19 | build bluetoothEXT [cordell]
2013-10-19 | bluetooth: enable the qcom features for WCNSS [Emerson Pinter]2013-10-19 | Move nfc.msm8960 package to device (HEAD, m/jb4.3, github/jb4.3) [dhacker29]
2013-10-19 | audio: return volume levels to original values [Emerson Pinter]
2013-10-19 | audio: Lower volume for Speaker and Voice Speaker [Emerson Pinter]
2013-10-19 | Add recovery options [dhacker29]
2013-10-19 | Add digital dock route for tunnel audio [nadlabak]
2013-10-19 | Add build barrier to include only msm8960-common devices [dhacker29]
Open-pdroid patch:
http://d-h.st/JwS
Je l'utilise depuis la 1.8 et je dois dire que j'en suis plus que satisfait, encore plus fluide que Slim bean 4.2.2, c'est vraiment plaisant de l'utiliser tout les jours. Aucun problème pour ma part sur cette build, tout fonctionne correctement.
Envoyé de mon GT-N7000 en utilisant Tapatalk
  • 3 weeks later...
Bonjour a tous
Alors voila je viens tout telechargé pour mettre cette version sur mon note qui est stock depuis que je l'ai.
Puis je mettre la version 2 direct sans probleme ou faut il que je root d'abord ?
Faut il que je change ma version d'abord ?
Faut il que je change mon kernel ? (sur ce point la je suis perdu je comprend pas bien comment le choisir et lequel prendre)
Voici ma version 4.1.2 N7000XXLSA
Kernel 3.0.31-549786 se.infra@SEP-64#3 SMP PREEMPT Tue Nov 20 00:02:36 KST 2012
Merci de votre aide
Modifié par tokidu13
Il faut que tu installe un kernel pour que tu sois root est ainsi avoir accès au recovery est oui tu peu installer la build 2 direct d'ailleurs moi je suis ravies de cette rom j'ai régler tout mais souci depuis mon dernier message
Salut à tous
Je suis plein déménagement, le PC dans un carton et donc aucun moyen de construire un patch openpdroid pour la build 2.2
@Karamelos, sans abuser de ta gentillesse tu sais où je peux trouver un tel patch ?
J'avais vu un thread sur xda, une sorte des bourse au patchs... mais je suis incapable de le retrouver.
Salut c'est quoi ce patch quel est son utilité ? Envoyé de mon GT-N7000 en utilisant Tapatalk
A respecté ta vie privée.
Il permet de géré les autorisations des appli.
J'avais fait un post sur le forum si tu veux plus d'explication.
Il fonctionne avec l'appli https://play.google.com/store/apps/details?id=net.digitalfeed.pdroidalternative&hl=fr
Ok merci je vais aller y jeter un œil
Slimkat arrive bientôt sur le n7000 :)
A bon c'est pour quand ?
