[ROM | 5830i] SGS III V5.0 MàJ - 07.07.2013
La ROM n'est pas de moi, voici le topic original : http://forum.xda-developers.com/showthread.php?t=2203244
je n'ai casiment rien traduis.
What is SGS3 ROM ?
Just when you read its name you can easily mind it. SGS3 ROM is a stock-based ROM whose purpose is to
give Galaxy Ace GT-S5830i users the best Samsung Galaxy S3 experience they have ever had.
The ROM has almost every SGS3 possible features. Every thing is designed on S3 Style.
F.A.Q :
  • No battery Icon on V4 Beta1 ? - Because of OGBatteryMod. Double click on the battery place and choose "AEON" style.( SGS3 )
  • Black on blue text on some places ? - Yes , will fix them in the future.
  • Battery force close on Settings ? - Unfortunately Yes. Gonna make a patch soon.
  • 4 Icons on the dock ? - Go on app drawer , click menu button , edit and drag an Icon to the dock ( Internet most preferred )
  • Auto button isn't working on Brighntess slider - It's just for decoration because we don't have ambient light sensor.
  • My phone reboots randomly sometimes crying.gif - If the RAM consumption will be more than 245 - 250 mb the device will reboot because it can't handle it.
Features :
  • SGS3 Dialer
  • SGS3 Bootanimation
  • SGS3 Full Sounds ( Including bootanimation )
  • SGS3 StatusBar
  • SGS3 Themed Messaging app
  • SGS3 Lockscreen
  • SGS3 Icons
  • Modded Touchwiz Launcher like SGS3
  • SGS3 Music player
  • SGS3 Battery + StatusBar Icons
  • SGS3 Weather & clock widget
  • SGS2 Calculator
  • SGS3 Video app
  • SGS3 Memo app
  • SGS3 Settings
  • OG Battery Mod
  • SGS3 USB Connection mode
  • ICS Task Switcher
  • Clock aligned on center on Lockscreen
  • Google search widget - Transparet
  • Swipe nofication on SB
  • Customized Voice Record app
  • 15 Toggles on SB
  • Gallery themed Blue
  • Quick Seetings on SB
  • Rooted + Deodexed + Deleted unnecessary apps
  • Latest Playstore
  • AMazing Framework and UI
  • Rafael.Baugis Kernel
  • ICS Pattern lock style
  • JellyBean Transition Animations
  • And so many others ....
Installation :
Installation depuis la ROM Stock :
  • Se rendre dans le CWM Recovery
  • Faites Clear/Wipe Data
  • Puis Clear/Wipe Cache
  • Puis Advanced > Clear/Wipe Dalvik cache
  • Install zip from sd card > Choisissez la ROM
  • Redemmarrez
  • Attendez, le 1er demarrage est souvent long! Et voilà :)
Installation depuis une ROM Custom :
Il est très fortement recommander de flasher la ROM depuis la ROM Stock. (Personellement j'ai brick en essayant, j'ai donc recommencer depuis la ROM Stock)
  • Puis Mounts and Storage > Format /system
  • Puis Mounts and Storage > Mount /system
  • Install ZIP from SD Card > Choisissez la ROM
  • Redemmarrez
Installation un patch :
  • Mount /system
  • IInstall ZIP from SD Card > Choisissez le patch
  • Redemmarrez
Liens :
SGS III V4 : http://www.mediafire.com/?7e9qkcupt0zq7ia
Patch pour passer a la V5 : http://www.mediafire.com/?i4bf1jhka95kp3n
Toutes les versions : http://www.mediafire.com/#amr92fxsa787g
ScreenShots :
Credits :
Rafael.Baugis - Kernel
MindCr - Gallery3D
SpaceCaker - Lots of Guides + TW3 as reference
SpaceCaker - So many helps , most of his ROM's framework pngs and 4.2.2 SB.
MindCr - Thanks for Settings.apk + Lidroid-Parts.apk as base apks.
Mohd Azman ( Friend , not on XDA ) - Ultimate Dialer.
Alucard1989pl - 15 Toggles + Polish Translation.
NaTHaN_GT5830 - Some framework png-s + FM Radio and Contacts
Vishnu pv - Shutdown Animation and several helps and supports.
Vishnu pv - Awesome ported SGS3 pngs. Also themer of ROM.
iamareebjamal - Many helps on different matters
iamareebjamal - ICS thickness guide + Cosmic Mods
Galaxy Y website - Widget Weather
b16h22 - Package installer
Abh922 - Helps in Lidroid Parts and many other things
Modifié par LeVoyageurNu
