Agrimok Posté(e) 4 décembre 2013 Share Posté(e) 4 décembre 2013 (modifié) Star Wars Jedi Knight II Touch Description Play Store: FULL GAME DATA IS NOT INCLUDED! Please read the description before buying (No really, please read it :-) 'Jedi Knight II: Jedi Outcast' is a registered trademark of Raven Software. All trademarks are used under the terms of Fair Use. Screen shots are for demonstration purposes only. I am in no way connected with Raven Software. This is a GPL port of JK2 and fully complies with the GPL license. *** VERY IMPORTANT *** This version does NOT contain the full Jedi Knight II: Jedi Outcast game data! To play the full version, you need to have the JK2 game files and copy them to your Android device. These files are: assets0.pk3 assets1.pk3 Jedi Knight II: Jedi Outcast is available to buy from Steam - http://store.steampowered.com/app/6030/ Please do not ask me to send you the files, or links to the files, i can not help you with this, sorry. Please contact support if you're unclear as to the meaning of this. **** THE ABOVE TEXT IS VERY IMPORTANT **** NO RISK PURCHASE - As with all my apps, this has full money-back guarantee at ANY time - Note, you need to email me for this, I can not refund from comments. Adapted from Pandora port by ptitSeb which was adapted from xLAva port. This is the first port of Jedi Knight 2 : Outcast for Android. Check out the online reviews for details of the game: 9/10 - IGN 9/10 - Gamespot 89 / 100 Metacritic "The Legacy of Star Wars Dark Forces™ and Star Wars® Jedi Knight lives on in the intense first-person action of Jedi Outcast. As Kyle Katarn, agent of the New Republic, use your Lightsaber and the full power of the Force to combat a new evil plaguing the galaxy." This is the first release, please email if there are any issues, it's impossible to respond properly to comments! It features the best highly customisable controls available for any FPS. Fully customize touch screen controls: *Move all game buttons *Analog move and strafe *Resize all game buttons *Change sensitivity for all analog inputs *Mouse mode or Joystick mode to turn *Invert look up/down *Optional double tap to Jump/Shoot *Change controls transparency *Map volume buttons to any game action Gamepad support - customize all inputs and buttons, invert and change sensitivity. Confirmed to work with (so far): * XBOX 360 wired controller * Moga Pro * Moga Pocket * Snakebyte * Nyko Playpad * Sony PS3 controller with the Sixaxis app. It should work with most controllers, let me know if it works with yours! NOTE: *To change gamepad axis sensitivity, long press on the axis on the Gamepad tab. *To map the volume keys use the GAMEPAD tab. *You need a Google Play device using the account you use to purchase to run *Multiplayer it NOT yet supported *You can not select 'high' texture mode, it will crash on certain level otherwise (graphic memory overflow) Please contact support if you are experiencing ANY difficulties. Thank you. PERFORMANCE: This game requires a powerful device, at LEAST a dual core device. There will still be some slow down in large areas, but I have still found it to be well playable. If you find it does not run well enough on your device let me know and I will issue a full refund. Remember, you need to copy the JK2 files to: /sdcard/Beloko/JK2/FULL/base/ I will also port 'Jedi Knight 3 : Jedi Academy' depending on how popular this game is. Icon used under CC BY-SA 3.0 designed by firba1 from deviantart.com Mon test vidéo: Pour profiter de ce jeu dans sa version complête il vous faut : -Soit le télécharger sur la plates formes steam 8.99€ :http://store.steampowered.com/app/6030/ -Soit avoir le jeu d'epoque sur PC en version boîte -Acheter puis installer l'application sur le Play Store : https://play.google.com/store/apps/details?id=com.beloko.jk2 -Copier le dossier base comportant les fichiers assets.pk3 dans le dossier sdcard/Beloko/JK2/FULL/ -Enjoy Modifié 4 décembre 2013 par Agrimok Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
