El Kholti Imad Posté(e) 5 décembre 2013 Share Posté(e) 5 décembre 2013 With apkDownloader you can download any free Google play store application from you pc .with single simple click .if you found that the version of the specified app is out of date you can try it with checked option "forced" to forced to download the new versionthis way you can always get the last version .this app is free ,completely free without any ads.How to use :in the text zone you have to put the links of the application (copy the link of your app from play store of Google and paste it there)then check the check-box "forced" if you sure that there is out dated version and then click the start button .Waite for about 5 secondsand you'll see the info of this app and the download button . click it and congratulation !!! as you can see all in formations is here.NOW the download links : DOWNLOAD Lien vers le commentaire Partager sur d’autres sites More sharing options...
