RafMax Posté(e) 14 décembre 2013 Share Posté(e) 14 décembre 2013 Bonjour à tous, Comment dire ... j'ai fais de la m**** ! J'ai redemarré en mode TRWP -> Wipe Advanced data -> Wipe Dalvk Cache + Cache + data + Internal Storage + System Du coup, lors du rebbot, mon tel reste sur le logo LG. J'ai essayé d'envoyer une ROM Cyano sur la SD Card pour l'installer via une commande adb et voici ce que cmd me dit : C:\adb>adb push c:\cm-11-20131213-NIGHTLY-d802\sdcard\ Android Debug Bridge version 1.0.26 -d - directs command to the only connected USB devic e returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is r unning. -s <serial number> - directs command to the USB device or emulator w ith the given serial number. Overrides ANDROID_SERI AL environment variable. -p <product name or path> - simple product name like 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'. If -p is not specified, the ANDROID_PRODUCT_OUT environment variable is used, which must be an absolute path. devices - list all connected devices connect <host>[:<port>] - connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [<host>[:<port>]] - disconnect from a TCP/IP device. Port 5555 is used by default if no port number is specified. Using this command with no additional arguments will disconnect from all connected TCP/IP devic es. device commands: adb push <local> <remote> - copy file/dir to device adb pull <remote> [<local>] - copy file/dir from device adb sync [ <directory> ] - copy host->device only if changed (-l means list but don't copy) (see 'adb help all') adb shell - run remote shell interactively adb shell <command> - run remote shell command adb emu <command> - run emulator console command adb logcat [ <filter-spec> ] - View device log adb forward <local> <remote> - forward socket connections forward specs are one of: tcp:<port> localabstract:<unix domain socket name> localreserved:<unix domain socket name> localfilesystem:<unix domain socket name> dev:<character device name> jdwp:<process pid> (remote only) adb jdwp - list PIDs of processes hosting a JDWP transport adb install [-l] [-r] [-s] <file> - push this package file to the device and i nstall it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data ) ('-s' means install on SD card instead of inter nal storage) adb uninstall [-k] <package> - remove this app package from the device ('-k' means keep the data and cache directories ) adb bugreport - return all information from the device that should be included in a bug report. adb help - show this help message adb version - show version num DATAOPTS: (no option) - don't touch the data partition -w - wipe the data partition -d - flash the data partition scripting: adb wait-for-device - block until device is online adb start-server - ensure that there is a server running adb kill-server - kill the server if it is running adb get-state - prints: offline | bootloader | device adb get-serialno - prints: <serial-number> adb status-window - continuously print device status for a specifie d device adb remount - remounts the /system partition on the device re ad-write adb reboot [bootloader|recovery] - reboots the device, optionally into the boo tloader or recovery program adb reboot-bootloader - reboots the device into the bootloader adb root - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip <port> - restarts the adbd daemon listening on TCP on th e specified port networking: adb ppp <tty> [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns adb sync notes: adb sync [ <directory> ] <localdir> can be interpreted in several ways: - If <directory> is not specified, both /system and /data partitions will be u pdated. - If it is "system" or "data", only the corresponding partition is updated. environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync , sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes prior ity over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these de bug tags are printed. C:\adb>adb devices List of devices attached 019daa8f53d8c350 recovery Du coup, je ne recupère pas le fichier zip pour l'installer dans SD Card. Est ce que quelqu'un peut m'aider SVP ? Que dois je faire ? Merci de votre aide. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lannig Posté(e) 14 décembre 2013 Share Posté(e) 14 décembre 2013 Adb prend deux arguments après "push". Le premier argument doit être un nom de fichier (sur le PC), pas de dossier Et le deuxième doit être un nom de dossier sur l'Android (donc avec des / à la mode Linux) Exemple : adb push c:\cm-11-20131213-NIGHTLY-d802\update.zip /mnt/sdcard Lien vers le commentaire Partager sur d’autres sites More sharing options...
