[ROM][10/12][Flo][4.4.2] - CleanROM 2.6 -★| Legendary Performance and Stability! |★-
  • CleanROM is an all inclusive ROM designed with you in mind!
  • CleanROM is based on the latest Google Stock KitKat 4.4.1 KOT49H ROM Base and is De-Odex!
  • CleanROM is targeted to the towards the user that wants a stock ROM experience that demand performance and expect stability!
  • Android KitKat 4.4.1 Build KOT49H!
  • Infused with Qualcom optimzaitions and run time libraries!
  • Pre-Rooted with Busybox binaries pre-installed!
  • Advanced Power Menu!
  • De-Odex'ed! (Dont do ART!)
  • init.d Support!
  • ADB Remount!
  • General performance and battery optimizations!
  • Removable Apps: Chrome, ES File Explorer, Gmail, Hangouts, Ad-Away, QuickOffice, YouTube
  • Stability that is nothing short of legendary!
Version 2.6 - 12/10/2013
  • Rebuild: Rebuilt on Official Google 4.4.2 (KOT49H)
  • All features and functions remain the same as 2.5. Just a version bump for the new Android release.
  • All new posts start HERE!
Version 2. 5- 12/8/2013
  • Rebuild: Rebuilt on Official Google 4.4.1 (KOT49E)
  • Added: Qualcomm Optimizations for enhanced performance
  • Changed: Made some apps removable (Chrome, ES File Explorer, Gmail, Hangouts, Ad-Away, QuickOffice, YouTube)
  • Updated: All Apps that required it
  • Chainfire, DSI XDA, MrJayDee
http://www.scottsroms.com/downloads.php?do=file&id=491
(cliquer sur le bouton DOWNLOAD de couleur bleu en haut à droite de la page
Additional Downloads
  1. KitKat Bootloader: You can download and flash HERE!
  2. Google Experience Launcher: Download and Flash from HERE!
  3. Wallpaper From Prior Versions: Can be downloaded from HERE!
  4. Wallpaper From Current Version: Can be downloaded from HERE!
Elle marche NICKEL !!
source : http://forum.xda-developers.com/showthread.php?t=2383146
Modifié par alienex
Bonsoir,
En effet très bonne ROM, je tourne dessus depuis 3 semaines sans problème.
Avec le kernel Elemental X 2.3--> http://forum.xda-developers.com/showthread.php?t=2389022  ça permet de pousser la tablette assez loin: CPU à 2.2Ghz et GPU 585Mhz c'est stable (même si ça chauffe à max 75°C) et ça permet de jouer à des jeux 3d comme Dead Trigger 2 avec effets Tegra de manière assez fluide (même si il y a quelques saccades)
On peut aussi privilégier l'autonomie dans ce cas CPU et GPU fréquences stock et undervolting de 100 mV.
Attention ne pas se fier qu'aux benchmark, j'ai observé des gains importants de perf en jeux mais pas en bench!
  • 5 months later...
Je viens d'installer la version CleanROM 3.0 R2 sous 4.4.3 mais j'ai un soucis.
Ma tablette n'as plus accès à l'USB en clé USB :(
Je pensais avoir mal installé (via les options) le Elemental X n7 2.13 mais même après l'avoir réinstallé avec TOUT en default, rien ne change :'(
Une idée? Merci :)
Modifié par Xenomorphys
