[ROM] [4.4] [6.Dec 2013] CyanogenMod 11.0 PREVIEW | KitKANG | PRE-ALPHA | v0.2
Je me demandais si quelqu'un avait installé cette ROM basé sous Kitkat et l'avait essayé ?
Moi je l'ai installé mais pas moyen de démarrer la ROM, blocage au niveau du logo Cyano. Impossible d'avoir le menu pourtant, j'ai laissé tourner un moment...
Merci par avance
Ci-dessous la ROM :
KitKANG [PRE-ALPHA]
CyanogenMod 11.0 PREVIEW for HTC Desire (GSM)
This is my personal ROM which I have source build by kanging from CyanogenMod and by taking over some portions from Evervolv (device tree, kernel, etc.). Furthermore I have cooked it a little by adding fancy Kitkat stuff from N5 like GEL, QuickSearchBar, and the latest Gapps. I take my hat off to pioneers like CM, Nikez and members of Evervolv! The motivation for making this ROM is for me to get familiar in building, to learn working with github and to learn about Android developments.
You may download the ROM and flash it and use it for your own experiments without asking for my permission -- just give proper credits in your thread. Please keep in mind that this is a pre-alpha release. If you rely on your device because it's your primary phone I would not recommend to flash it. If you decide to flash this rom, you do it at your own risk, blah blah blah..
Quote:
Requirements:
- ROM version 0.1: Stock hboot (250/40/147)
- ROM version 0.2: Alpha Jelly (250/5/182)
- SD-ext with 1GB EXT4
- Internal/external swap (Optional)
Quote:
Major features:
- Google Experience Launcher slimmed for Desire
- CM apps (CMAccount, CMFileManager, a few CM wallpapers)
- Core Gapps, GalleryGoogle, Gmail2, Keep, Maps, QuickOffice, QuickSearchBar, Street
- Pre-installed apps: GravityBox 2.7.6, XposedInstaller 2.4-beta2
- Tweaks for better scrolling performance
- SELinux disabled
- Use only with Dalvik ON
Quote:
Known issues:
- All bugs present in CM11 and Evervolv's KK, e.g.: graphic glitches
- Settings / Apps / Properties -> FC
- Settings / Security -> FC
CM File Manager / enter settings -> FC
Please let me know if you find further bugs. However, let's see if I can fix any of them...
Quote:
Very special thanks:
- CyanogenMod Team
- Nikez and all members of Evervolv Team
- Nbsss for Slim Gapps and Moto X dalvik patches
- Chromium_ for a crash course in using git and github
- All xda members who give constructive feedback (don't forget to attach a logcat!)
Download Version 0.1 (int2ext):
KitKANG v0.1
Download Version 0.2 (a2sd):
KitKANG v0.2 (CM flavoured preview)
md5 a8b396b659a3f0a2e45ddd8303c8efa8
Quote:
-> incl. CM Wallpapers / Launcher 3
-> CM bootanimation
-> incl. full Gapps package
KitKANG v0.2 (cooked with N5 ingredients)
md5 0c01041dca523a8ccc0b4fbb6adfe060
Quote:
-> incl. GEL, GoogleQuickSearchBar
-> KK bootanimation
-> removed CMWallpapers
-> incl. slim Gapps package
How to enable A2SD
Quote:
1) run Terminal Emulator
2) type 'su' and press enter
3) allow root access in the popup query
4) type 'a2sd install' and press enter
5) reply to questions in this order
--> y n y (dalvik to card - yes, data to card - no, reboot - yes)
6) that's it
Lien XDA : http://forum.xda-developers.com/showthread.php?t=2549776
Bon wipe ! :)
NOn je n'ai pas essayé quand j'ai vu que ça parlait de FC, de plus c'est aussi basé entre autre sur evervolv, donc du coups je me demande s'il y a un intérêt. Au pire je peux tenter de l'installer pour vous dire si elle boot, après je n'utilise pas mon desire alors vos mieux quelqu'un qui l'utilise pour faire des remontés.
Apparemment pour la version 0.1 il est noté qu'il faut le hboot stock et pour la 0.2 le hboot jelly bean
Bon ben avec mon Hboot j'ai booté sans problème sur la 0.1, c'est assez jolie y a pas mal d'appli, j'ai due juste passer en français après dans les paramètres
Donc à mon avis scooby c'est ton Hboot qui ne va pas.
Faudrait que je test la V0.2, sauf que moi je vais mettre INT et pas a2sd, donc faut que je la modifie
Modifié par DMBFR
Voilà j'ai installé la v0.2 M5 j'ai ajouté INT2EXT4, elle boot, deux fc pendant le paramétrage au début.
Mieux que celle d'evervolv ?
Esthétiquement, plus jolie, après faut voir à l'usage. On a le clavier android normal, mieux que celui de l'évervolv.
pour le moment j'ai l'impression que la 0.1 est plus stable, sur la 0.2 déjà deux fc, alors bon y a le play store qui est en train de metre les applis à jour y a t'il un rapport??
Modifié par DMBFR
  • 1 year later...
Salut
J'ai actuellement sur mon HTC desire la rom CyanogenMOd 10 (android 4.1.2)
je souhaite mettre la Rom KitKang 1.2 (android 4.4.4 ) sur mon htc desire.
Sur le lien présentant ou il y a la rom KitKang 1.2 (android 4.4.4 ), il a une liste des prérequis suivant :
- Rooted
- Hboot with at least 400mb on system. Get it HERE (420/5/12)
- 1gb - 4gb EXT4 partition on your sdcard. Use this guide.
- Use this modified 4EXT Touch Recovery ONLY. (credits madmaxx82 & walter79)
- Full wipe
- Flash ROM
Cependant je ne comprend pas ce que je doit faire par rapport à ces deux prérequis :
Quelqu'un pourrait il m'aider ?  :(
