Market Indigo Bean; CyanogenMod 5.0.8
Florent06
Non il faut que tu places les deux fichiers sur ta sd.
Va dans le recovery et fait "flash zip" et tu les flash un par un.
Ce soir je ferai un petit tuto francais pour allé dans le recovery sans ordi ;)
Je viens de tester l'accès au root sans pc...ca fonctionne parfaitement.
Voilà ce que j'ai trouvé :
1. Download 'fb-mms-tikl.zip and copy to your sdcard' (5kB) also for easy reflash of Indigo, make an copy of latest version and put on your sdcard root. It use to be found in /sdcard/clockworkmod/download/derhofbauer.at/android/downloads/roms/indigo-bean-x.x be sure to rename file to "indigo-bean-x.x.zip" so recovery finds it.
2. Uninstall Facebook if you have installed one
3. PowerOff, then Enter Fake-Flash recovery
4. Flash fb-mms-tikl.zip with 'No Assertion' because that patch is for HTC Hero
5. Reboot (No your phone will fake roaming and you cant use call or data)
6. Download Facebook from Market (via WLAN, 3G should not work in this time.)
7. Setting -> Sync will now be avalible
8. Flash latest 'Indigo' again WITHOUT WIPE to restore phone and roaming settings
9. Goto Settings / Wireless & networks / Mobile networks / Access Point Names
menu - Reset to default.
After a moment your provider will show and you can exit.
Mais je n'ai pas bien compris.
