Manuel Stephan Posté(e) 28 décembre 2013 Share Posté(e) 28 décembre 2013 (modifié) Voici une petite liste des kernel disponibles pour notre I9192. A ce jour il n'y a pas de custom rom (aokp, CM,...) disponible il s'agit donc de kernel stock recompilés et optimisés. >> XDA c0bain : http://forum.xda-developers.com/showthread.php?t=2567442 Changelog: 2014.01.06 - CM 10.2 & MK4 based. Fix WIFI MAC address. SuperSU 1.86. 2013.12.25 - Bug fixes from MK4. SuperSU 1.85, rooting more aggressive. Features:- rooted (disabled root prevention security system; SELinux Permissive; adb shell root support; auto install SuperSU) - reduce battery usage: RCU_FAST_NO_HZ = ON; "msm8930: modify power collapse seq for kraitv3 " patch; enable Krait Retention CPU power state. - BLN support. thanks @junkyde (for more info read http://forum.xda-developers.com/show....php?t=2545244) - SIO as default I/O Scheduler. Support ROW I/O Scheduler. - busybox armv7l 1.21.1 (from http://www.busybox.net/downloads/binaries/) - USB FastCharge support (you can enable it, for example, with Faux123 tool, or "echo 1 > /sys/kernel/fast_charge/force_fast_charge") - Undervolting support. (my result is successful decrease CPU voltage for 100mv with Faux123 tool) - Compiling with linaro GCC 4.8, cflags = -Os -mcpu=cortex-a9 -mtune=cortex-a15 -marm -march=armv7-a -mfpu=neon-vfpv4 - all drivers/modules included in kernel image. you can use this kernel with any modem and ROM version.Known Bugs: wifi MAC adress will change random reboots if use in case with magnet >> XDA Amestris : http://forum.xda-developers.com/showthread.php?t=2431953 Version 2.7 (13/03/2014) - logger: Added sysfs interface to Enable / Disable Android Logger - switching done via /sys/kernel/logger_mode interface default is 0 (off), thanks to AndiP. - O3 compilation and NEON cflags - Optimized on Size - set selinux to permissive from kernel. - ext4: speed up truncate/unlink by not using bforget() unless needed - msm: Add support for ION Flushing without virtual address - gpu: ion: Use correct type for variables - lowmemorykiller: Use upstream version instead of Samsung's one. - samsung: msm8930: Add sleep status device - samsung: msm8930: modify power collapse seq for kraitv3 - fix exfat support - updated to version 1.2.5 - default governors is Ondemand, for changing governors and cpu freqeuncy, use latest version of SetCpu app Version 2.5 2nd March 2014 - Optimized KSM - Tweaked cpu voltages and clocks , undervolted freq to 192Mhz [Default=384Mhz] - Added many Governors so avalables are: badass, smartassH3, smartassV2, Asswax, dancedance, wheatley, smartmax, interactive, userspace, powersave, lionheart, adaptive, ondemand, performance Version 2.4 Changelog 5th January 2014 New configuration based on fluid script FauxSound V 3.1 thanks to f4ktion USB Fastcharging Support thanks to f4ktion Version 2.3 Changelog 1-Enabled Voltage Control 2-Disabled BLN Wakelocks 3-Dynamic fsync v1.0 [credit to faux123] 4-changed kernel compression to LZO 5-tweaked ondemand cpu overnor for better battery usage, you may will get lower scores on benchmark apps, you can change the governorse to default if you want more power. [lower parameters than v2.1] 6-increased entropy values [4 x default] 7-increased read-ahead values. 8- revert the new ROW IO schedulers algorithm. >> XDA SilviuMik : http://forum.xda-developers.com/showthread.php?t=2592308 - Compiled from GT-I9192_JB_Opensource_Update1.zip MK4 from http://opensource.samsung.com/ - Compiled with Linaro GCC 4.6.4-2013.05 Toolchain - MK5/ML1 ramdisk ( SeLinux Permisive , Insecure status ) - Battery drain patches included signed by Venkat Devarasetty <vdevaras@codeaurora.org> - Ondemand Cpu governor as default ( Stock Kernel have Performance governor ) - No-Op I/O Scheduler as default ( Stock Kernel have CFQ I/O ) - CONFIG_RCU_FAST_NO_HZ=y - No root, no drivers changing ( U keep your Wifi MAC ) - No Overclock/Undeclock/Undervolt/Overvolt/Bln/ etc . As close to stock as posible Changelog: v1 - I9192-Custom-Kernel-Silviu-26122013.tar - MK5 Ramdisk v2 - I9192-Custom-Kernel-Silviu-31122013.tar - ML1 Ramdisk v3 - I9192-Custom-Kernel-Silviu-01012014.tar - ML2 Ramdisk - Nothing changed only new 01/01/2014 fancy build date :) Je vais essayer de tenir à jour ce post, je ne garanti rien ;) Modifié 13 mars 2014 par Wildfear 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
guims78 Posté(e) 7 janvier 2014 Share Posté(e) 7 janvier 2014 Une question de noob : comment on met à jour un kernel ? via ODIN ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Manuel Stephan Posté(e) 7 janvier 2014 Auteur Share Posté(e) 7 janvier 2014 Avec Odin ou avec un Custom Recovery (CWM, TWRP) selon ce que fourni le développeur ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Manuel Stephan Posté(e) 3 mars 2014 Auteur Share Posté(e) 3 mars 2014 Update le 03/03/2014. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Manuel Stephan Posté(e) 13 mars 2014 Auteur Share Posté(e) 13 mars 2014 Update le 13/03/2014 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
