Tweak du build.prop : demande conseils svp
wakiza01
Salut tous le monde !
Pensez vous que ce tweak du build.prop comporte des risques pour l'integrité physique Peax2 ?
# Networks
ro.ril.hsxpa=2
ro.ril.gprsclass=10
ro.ril.hep=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=10
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=14449
ro.ril.hsupa.category=5
# Faster Streaming
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
media.stagefright.enable-record=false
# Better Image & Audio Quality
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
af.resampler.quality=255
ro.somc.clearphase.supported=true
ro.semc.xloud.supported=true
ro.somc.sforce.supported=true
ro.media.enc.jpeg.quality=100
persist.sys.use_dithering=1
ro.audio.samplerate=48000
persist.af.resampler.quality=255
persist.audio.samplerate=48000
persist.af.resample=52000
ro.audio.pcm.samplerate=48000
persist.dev.pm.dyn_samplingrate=1
# Net Speed Tweaks
net.tcp.buffersize.default=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,16384,256960
net.tcp.buffersize.hspa=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.lte=524288,1048576,2097152,524288,1048576,2097152
net.tcp.buffersize.hspda=4096,87380,256960,4096,16 384,256960
net.tcp.buffersize.evdo_b=6144,87380,1048576,6144,87380,1048576
# No Delay In Making Call
ro.telephony.call_ring.delay=0
ring.delay=0
# Battery Tweaks
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
ro.ril.fast.dormancy.rule=0
# Proximity Tweaks
ro.lge.proximity.delay=25
mot.proximity.delay=25
# Frees More RAM
persist.sys.purgeable_assets=1
# Better Responsiveness & Speed
windowsmgr.max_events_per_sec=90
ro.max.fling_velocity=12000
ro.min.fling_velocity=8000
# Wifi
wifi.supplicant_scan_interval=160
persist.wifi_scan_interval=160
# Google DNS Tweak
net.rmnet0.dns1=8.8.8.8
net.rmnet0.dns2=8.8.4.4
net.dns1=8.8.8.8
net.dns2=8.8.4.4
# Other Tweaks
ro.media.dec.aud.wma.enabled=1
ro.media.dec.vid.wmv.enabled=1
ro.mot.eri.losalert.delay=1000
dalvik.vm.execution-mode=int:jit
ro.config.hwfeature_wakeupkey=0
ro.kernel.android.checkjni=0
ro.kernel.checkjni=0
persist.adb.notify=0
vm.stat_interval=1
persist.android.strictmode=0
profiler.force_disable_err_rpt=1
profiler.force_disable_ulog=1
ro.config.nocheckin=1
Trouvé dans une ROM Micromax Canvas HD A116
Merci !
C'est un peu le souk là dedans ^^ perso je modifie chaque ligne que la ta un build prop direct a copier ... Par ce que tu compte remplacer celui du wiki par celui la ?????
Envoyé de mon XT1032 en utilisant Tapatalk
Pour le moment, j'ai ajouté ces 3 tweak à la fin du "build.prop" et pas de bug constaté :
# Faster Streaming
# Net Speed Tweaks
Je ne sais pas si cela viens de mon "super smartphone" ou des tweaks, mais au travail, les pages web se chargent une vitesse impressionnante en 3G en utilisant Tint Browser, les vidéos Youtube démarrent sans attendre.
Pour les images et le son, impossible à dire...
