création fichier sur serveur distant
Chlock
Bonjour, au lieu de créer un fichier sur ma sdcard de mon emulateur android comme je fais ci dessous:
public WritableWorkbook createWorkbook(String fileName){
    //exports must use a temp file while writing to avoid memory hogging
    WorkbookSettings wbSettings = new WorkbookSettings();
    wbSettings.setUseTemporaryFileDuringWrite(true);
    //get the sdcard's directory
    File sdCard = Environment.getExternalStorageDirectory();
    //add on the your app's path
    File dir = new File(sdCard.getAbsolutePath() + "/JExcelApiTest");
    //make them in case they're not there
    dir.mkdirs();
    //create a standard java.io.File object for the Workbook to use
    File wbfile = new File(dir,fileName);
    WritableWorkbook wb = null;
    try{
	//create a new WritableWorkbook using the java.io.File and
	//WorkbookSettings from above
	wb = Workbook.createWorkbook(wbfile,wbSettings);
    }catch(IOException ex){
	Log.e(TAG,ex.getStackTrace().toString());
	Log.e(TAG, ex.getMessage());
    return wb;
je voudrais le creer et sur mon pc ou repertoire serveur du genre:
wb = Workbook.createWorkbook(new File("F:\\exemple2.xls"));
Une idée les amis
merci à tous
