Skip to content
Archos 3.2, un nouvel archos sous Android
A voir chez un revendeur américain
http://www.jr.com/archos/pe/AHS_501570/#productTabDetails
Android 2.1 Eclair / 802.11n WiFi / Bluetooth / Built-in camera & microphone / Accelerometer / Multiple audio & video formats / Surf web & download Apps
The ARCHOS 32 is an exciting 3.2" touch screen Android device. Smaller than a pack of gum the ARCHOS 32 is able to play multiple Video and Music formats, Download applications to fit your lifestyle, connect to the Internet and shoot videos with its built-in camera.
# Get an excellent media player - The ARCHOS 32 features music, video and photo applications that allow users to browse through the album covers to locate and instantly access their media. Plus, the ARCHOS 32 is able to play a variety of music, photo and video formats.
# Android's APPS available for Download - The AppsLib store is an Android application market place where you can download multiple apps while connected to a WiFi network. You decide what your product should do for you by choosing among the thousands of Apps available. Social media, entertainment, weather, traffic, news and games are now just a click away.
# Make memories with the built-in video camera - With a built in video camera you can easily Record video or take pictures. Within minutes, you can Upload and share your Personal memories on your social networks.
# Surf the Internet right from your hand - Using a WiFi connection, you can surf the Web as efficiently as you do on your Computer thanks to the speedy processor. You can easily Zoom in and out by double-tapping on the screen or by rotating the product horizontally.
# Package includes: ARCHOS 32, earphones, Standard USB cable, Quick Start Guide (QSG)
# Display: 3.2'' TFT LCD, 16M colors, WQVGA (400x240), Touch screen
# Application Framework: Android 2.1 Eclair (upgradable to Android 2.2 Froyo when released)
# Processor: 800 MHz Arm Cortex A8 with DSP
# Graphical accelerator: 3D OpenGL
# Video playback: MPEG-4 HD (up to 720p, 24fps@12Mbps) / MPEG-42 (ASP@L5 AVI, up to DVD resolution, 24fps@12Mbps) / H.264 HD (HP@L3.1 up to 720p, 24fps@7Mbps) / WMV9/VC1 (AP up to 720p 24fps@10Mbps) / MJPG (Motion JPEG) in VGA resolution (With Optional plug-in: Cinema: MPEG2 (up to DVD resolution MP/D1, 30fps@15Mbps) / With the above codecs, the device can play video files with the following extensions: AVI, MP4, MOV, 3GP, MPG, PS, TS, VOB, MKV, FLV, RM, RMVB, ASF, WMV
# Audio Playback: MP3 CBR & VBR / WMA, WMA-Pro 5.1 / WAV (PCM/ADPCM) / AAC, AAC+ 5.13 / OGG Vorbis / FLAC (With optional Software plug-in: AC3 5.1)
# Photo viewer: JPEG, BMP, PNG, GIF
# Subtitles: .srt, .ssa, .smi, .sub formats supported
# Video Recording & picture taking: Camcorder: records in MPEG-4 (.avi) and in VGA resolution (640x480) / Camera: JPG in VGA resolution
# Connections: USB 2.0 Device / USB 2.0 Host & Composite video Output (optional cables)
# Communication protocols: WiFi (802.11 b/g/n) / Bluetooth 2.1 + EDR
# Power source: Internal: Lithium Polymer Battery / USB charging
# System Requirements: Windows XP/Vista/7; Mac & Linux / USB 2.0
# Dimensions: 4.13 x 2.16 x 0.35 in.
# Weight: 2.54 oz.
http://www.archoslounge.net/Scoop-Archos-32-premier-baladeur-Gen8,9478.html (pour l'info de base)
Edited by cajl
C'est moi qui voit pas où ils n'indiquent pas la quantité de mémoire (RAM) disponible ?
Si Android 2.1 et ensuite 2.2 fonctionne sur cet appareil, ça devrait aussi aller sur l'Archos 5, les spécification techniques semblent similaires, non ?
Bah au contraire l'Archos 5 IT est plus puissant vu qu'il a un processeur de 1GHz et l'accélération matérielle est possible vu que c'est le cas avec les derniers firmwares en 2.x, d'ailleurs ça marche très bien :)
Vraiment si Archos met à jour également le 5 IT (qui pour l'instant est la plus puissante de leurs tablettes ainsi que la plus populaire) en Android 2.1 ou 2.2, tout le monde sera fou de joie et aimera d'autant plus Archos, et donnera pourquoi pas envie de continuer à acheter des tablettes chez Archos.
Par contre le cas échéant si Archos n'assure plus aucun support de sa tablette fétiche, beaucoup seront déçus et c'est un peu bête quand même :(
Une danse pour motiver les gars de chez Archos, allez ! _o/* *\o/* *\o_
Archos 5 IT :
Unité Centrale :
* Processeur principal : ARM CortexTM-A8, processeur 32 bit à double cœur superscalaire, fréquence d’horloge 800 MHz
* Processeur additionnel : DSP 32 bit, fréquence d’horloge 430 MHz
Ah, j'ai toujours cru que c'était du 1GHz...
Mais en additionnant 800MHz + 430MHz ça fait quand même 1,2GHz :rolleyes:
Puis le processeur principal est un ARM Cortex A8, comme l'Archos 32 ;)
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
Search
Search
