Viktunee Posté(e) 29 mars 2014 Share Posté(e) 29 mars 2014 (modifié) Après l'avoir longuement essayer, je met a disposition une Rom dans un pure look stock, très performante et qui à une bonne autonomie. Nombreux utilisateurs doivent la connaitre sur le topic, c'est la SuperLuminal de Cmahendra du forum XDA : http://forum.xda-developers.com/showthread.php?t=2525542 Ce qu'elle contient : ( Pas de traduction, mais anglais transparent ; ) ) New Cool BootLogo and BootAnimation Completely Designed by me New Features a) AMAZING HIGH-GRAPHICS REALISTIC [color=red]koi[/color] Live Wallpaper. Now play in WATER without wetting your hands :D B) Flip Mute on Call c) Flip Mute on Alarm d) Three Launcher Themes (Style) e) Portable Hotspot WiFi f) NoteBook g) Torch Light h) Latest Stock Video Player with all needed features i) More Power Options with Reboot. Sim Toolkit Fixed & Working GPS Tweak, Ha ha ha! Now GPS Satellite Fix without EPO setup in 20 seconds even first time Based on NEW EXTENDED AOSP UPDATED Stock 4.2.1 rom of CELKON A119Q Fully Zip-aligned and signed This rom uses A116i Stock Kernel Pre-Rooted with updated SU Binaries. 12 MegaPixel CAMERA with 1088p Video Recording VERY FAST and STABLE AND LIGHT ROM (325MB ONLY) Lightly and carefully HEAVILY & INSANELY Tweaked, Tested OK. Init.d support -- Perfectly verified and working Loopy Smoothness Tweaks (touchscreen optimization) New Ram Optimization Tweaks (good for gaming) New SQLite Optimization Tweaks (for gaming) More Power Tweaks -- New Network Tweaks = STRONGER PHONE NETWORK -- New WiFi Tweaks = STRONGER WIFI NETWORK , go some more far and see. -- Faster Wi-Fi connection initialization -- New DHCP Tweaks = HALF SECOND WIFI CONNECT -- New TCP-Buffer Tweaks -- New Photo and Video Recording Tweaks -- New Streaming Media Tweaks -- New Photo & Video Recording Quality Tweaks. Beautiful Photos -- New Google DNS Tweak -- New Better Flash Tweak -- New Bravia Engine Tweak -- New Seeder Script -- LOUDEST SOUND AND CLEAR TOO Great quality sound in Speaker, Headphone and Bluetooth Headset. All 3 tested ok. -- Launcher forced in memory (Reboot if launcher is changed, for great results) -- Render UI with GPU to reduce CPU usage -- Deep Sleep tweaked -- Camera Sound forced to silent with double ways. -- Super-Responsive and Smooth Touchscreen Sensitivity Xposed Installer + Gravity Box works flawlessly (XPOSED TUTORIAL AND APK HERE) You can get FREE RAM between around 490 to 550 MB. With all required apps installed on my phone I have 500+ MB FREE RAM all the time. Fully Rooted ROM with SuperSU Pre-installed Lightweight "File Manager" & "ES File Explorer", so you can directly browse system areas/files. Immediately after flash you can start installing APKs, both from Internal and External SDcards. Good Battery Backup up to 2 Days. Depends on usage pattern. (Install Greenify , Recommended for more best results) As per user-report the Proximity Sensor responsiveness is improved and better than stock. Use with any Universal Language with this "tested ok" small app (not included in rom) Rebooter (small app pre-installed) for Reboot / Reboot to Recovery Option No need to swap storage default after flashing. USEFUL UPDATED APPS Added (Most uninstallable) -- Stock File Manager , ES File Explorer , Gmail , Greenify , -- Added Updated Google TTS -- Updated Google Play Store 4.6.17 and Google Play Services -- Added GREENIFY. (how to effectively use GREENIFY?) Restored 4.2 Stock Camera 1088p Video Recording (4.3 Flashable addon zip available below) Very Lite ROM. Only 283mb. Most other custom stock roms are 400 to 450+ version 1.0 = 279 MB :) v1.5-2 = 339 MB :) Sim Toolkit Fixed & Working Addons/Patches/Mods: ORIGINAL STOCK KERNEL: Download here FULL WIPE ZIP PATCH: If you are coming from other custom roms with different partition and may get bootloops, then do flash this FULL WIPE ZIP Patch which should re-format the required ext4 partitions perfectly. WARNING: It really formats system and other partition, so please take backup.*Totally Optional MemorySwap Fix: If you want SDCard memory mapping to be fixed or getting problems in restoring Titanium Backup data, then flash this patch. : Download and flash Patch & after that reset storage option. See FAQ section. (*Optional. Everyone else can ignore this patch.) AOSP Launcher REMOVED in 0.3F but If you still want it flash this (may refer this post ) *Optional Flash Stock 4.2 Camera: Download (if you need the original one) 1088p video recording.*Optional Flash Stock 4.3 Camera: Download (the one which is included in this rom)*Optional UPDATED KITKAT4 LAUNCHER COMBINATION by CMahendra for SLD Rom (Download and Install from here) (NEW) *Optional App. *Only launcher, no additional apps included. Live WallPaper and Live WallPaper Picker Add-on (all versions): Download *Totally Optional Nouveautés par rapport a la v1 : Always check MD5 Checksum before flashing: XDA Server code>>> 5f86905526ef4d1d4a4dfcca9b75c0b1-- Full Init.d support -- Perfectly verified and working.-- Loopy Smoothness Tweaks (touchscreen optimization)-- New Ram Optimization Tweaks (good for gaming)-- New SQLite Optimization Tweaks (for gaming)-- No need to swap storage default.-- Camera now saves photos in external sdcard-- All Apps Updated. Bhaarat Theme with Tricolor Flavoured Wallpapers == New Cool BootLogo and JB BootAnimation== Sim Toolkit Fixed & Working== New Seeder tweak by RemZej== GPS Tweak, Ha ha ha! Now GPS Satellite Fix without EPO setup in 20 seconds even first time== Some more things I forgot -- Loopy Smoothness Tweaks (touchscreen optimization)-- New Ram Optimization Tweaks (good for gaming)-- New SQLite Optimization Tweaks (for gaming)-- Few more tweaks-- No need to swap storage default.-- Camera now saves photos in external sdcard-- All Apps Updated.-- Facebook Discussion Téléchargement : http://d-h.st/u9e Télécharger more local pour la langue française sur le store ! ; ) Screenshots : Modifié 15 mai 2014 par Viktunee 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mcnicow Posté(e) 30 mars 2014 Share Posté(e) 30 mars 2014 salut !Boussole? GPS? 3G? Tout ça fonctionne ? :huh: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Viktunee Posté(e) 30 mars 2014 Auteur Share Posté(e) 30 mars 2014 (modifié) salut ! Boussole? GPS? 3G? Tout ça fonctionne ? :huh: Oui ! ^^ Modifié 30 mars 2014 par Viktunee Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mcnicow Posté(e) 31 mars 2014 Share Posté(e) 31 mars 2014 Eh bien que du bonheur je testerais tout ça :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
zappacostamarco Posté(e) 3 avril 2014 Share Posté(e) 3 avril 2014 Bonjour. La boussole ne fonctionne pas. Que faut-il faire pour l'activer ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mcnicow Posté(e) 5 avril 2014 Share Posté(e) 5 avril 2014 (modifié) Non la boussole ne fonctionne pas... Nous avons été trompé :D Et on ne peut pas l'activer sauf si tu veux te lancer dans la décompilation d'un certain boot.img :/ Modifié 5 avril 2014 par mcnicow Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mcnicow Posté(e) 7 avril 2014 Share Posté(e) 7 avril 2014 Savez vous comment changer l'animation d'extinction (shutdown animation/shutanimation) ? J'ai pas trouvé son emplacement :p Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
red65 Posté(e) 20 avril 2014 Share Posté(e) 20 avril 2014 http://forum.xda-developers.com/showthread.php?t=2525542 version V3 dispo.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Viktunee Posté(e) 21 avril 2014 Auteur Share Posté(e) 21 avril 2014 Je met a jour le topic tal ; ) il y a plus que la v3 même ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cabbes Posté(e) 15 mai 2014 Share Posté(e) 15 mai 2014 (modifié) faut-il remplacer le modem par celui du wiko, sur cette rom ? Edit : il n'y aurait pas un mélange entre la XLDR et la SLD, qui sont deux ROMs différentes, même si elles sont faites par la même personne ? Modifié 15 mai 2014 par cabbes Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Viktunee Posté(e) 15 mai 2014 Auteur Share Posté(e) 15 mai 2014 faut-il remplacer le modem par celui du wiko, sur cette rom ? Edit : il n'y aurait pas un mélange entre la XLDR et la SLD, qui sont deux ROMs différentes, même si elles sont faites par la même personne ? Oui toujours car les ROMS sont etrangère donc le modem.img pas optimisée pour le pays. Oui je pense que c'est une sorte de mélange, d'ailleurs je vais mettre a jour le topic . Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
