shangalisto Posté(e) 30 mars 2014 Share Posté(e) 30 mars 2014 Features : Insecured Persistent ADB Neon optimizations Compiled using GCC 4.6 Merged Latest Linux Upstream Commits i.e. 3.4.82 XZ compression for kernel. Size 4.2MB ==> 2.7 MB Activated many Governors : Interactive , Conservative Reduced Logbuffer shift KSM for Page Merging Activated and tweaked conservative governor Dynamic Filesync Control 2.0 Dynamic Management of Dirty page writeback Lock initial TCP window size to 64k (Improves network ping and output) Faster NOATIME and NODIRATIME mounting flags Disabled Gentle Fair Sleepers Enabled ARCH_POWER Asynchronous I/O latency to a solid-state disk greatly increased Activated and tweaked conservative governor Patches to prevent depleting Entropies Frandom driver - Fast Kernel Number Generator Optimized git implementation for SHA1 Optimized glibc version of string Enabled SWAP support Optimized AES and SHA1 routines Optimized apply_slack() method for size and speed Various EXT4 Filesystem patches from android_kernel_common Enabled 5 new TCP Congestion controls viz. Westwood, Veno, BIC, Reno, HTCP Set westood as default from cubic. Optimized memcopy and memmove algorithm Tweaked SLUB allocator Increase READ_AHEAD size to 1024kb Cleancache enabled Ability to change IO-Schedulers without need of root Optimizations to SLUB memory allocator Optimized VM dirty ratios Optimized CFQ scheduler-you really don't need any other IO scheduler Added FIOPS IO scheduler which is much better than CFQ and set to default Optimized FIOPS IO Scheduler with many tweaks merged with it Hotplug CPU Governor will remain default as it is best for MTK phones NTFS Filesystem support for USB OTG (WIP) Added config.gz support CIFS Support Added in form of Module Support for X-Box 360 Gamepad and other gamepads (WIP) Added cdrom option to UMS-lun-devices (you can now use this app: Link And many more changes A voir ce qu'il vaut face au Kashkernel mais remarquez que le kernel est en 3.4.82 là où jusqu'à maintenant, on était limité au 3.4.5. Donc surement des optimisations en vue ! P'tit fail ici, topic à supprimer si un modo passe, merci :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
