[ROM] Roufianos Official 2.2 BUG-FREE |Rooted|A2SD|EXT3/4| SUPERFAST
un petit post pour savoir si certains d'entre vous ont déjà testé cette ROM et avoir quelques retours.
Est-elle vraiment SUPERFAST et BUG-FREE ? ^^
Je vous met les informations de la ROM pour ceux qui seraient interressés :
Roufianos.com Desire V5.1
NOW IS SUPERFAST...
Simple/Clean/Fast/Stable
ROOTED | A2SD+ | Full Deodoxed | Optimize Ram | SuperFast
Requirements:
Latest Radio 32.43.00.32U_5.09.00.20
For a best running of rom should do a Wipe Factory Reset and wipe at ext partirion
After the 1st boot make a reboot ITS IMPORTANT (before start installing your apps)
Not required:
Partition ext2/3/4 wiped (if not, you will not have a2sd)
What you Get:
Very fast, Clean & stable ROM
MOD ADDED HTC_IME
MOD ADDED Super Circle Battery MOD with % (Thanks to Fightspit)
MOD ADDED Wake Up with power button OR TrackBall
All APN LIST (Thanks @Bilias στον γείτονα απο τον Μαραθώνα)
Optimized *.APKs
Deodexed
APP2SD (require partition ext) thanks to AdamG
Apps Added: (in /Data/app (you can Uninstall and UPDATE it if you dont like)
Added Gallery 3D Nexus One
Added Spare Parts
Added Astro File Manager (With SMB Plugin, to access Windows Networks)
Added ModInstallLocation (choose where you want install)
Added Chrome To Phone
Added Rom Manager
Added Titanium BackUp
Added Google Maps in /Data/app to be possible Uninstall it.. (CANT UPDATE... Uninstall it And then Install New Version)
Added ES File Explorer
Added Home switcher (to change the launcher between Sense and Launcer2)
Added Market Enabler
Addedand the old Wireless Tether (Because Likes me)
Added SMS AND GMAIL Unread Count
Voice Search & Dialling
Google Car Home
WiFi N Patch
Supported Languages: Greek, English, Chinese, Arabic, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Japanese, Korean, Swedish, Danish, Portuguese, Finnish.
Based on LeeDroid
Installation:
-Enter to recovery, do a Wipe Factory reset, Wipe Cache, Wipe Dalvik, format/wipe partition Ext2/3/4.
-Flash my ROM (REQUIRES THE LASTEST RADIO IMAGE, See
-Run rom (First time takes some time to run)
Install Roufianos V5 WITH WIPE
Change Log:
V5 -> V5.1: (you need a FULL WIPE)
Wifi Teether Fixed
Ram Optimization ( xixixi, Now Im FULL AND SUPER FAST)
BugFixes/Tweaking/Totally optimization
New Google Maps
V4 -> V5:
A lot of tweaks
All Apns Added
A2SD FIXED
Wake Up Mod with TrackBall Or Power Button
Some Apps as request
V3 -> V4:
Built From Scratch (actually is a New Version Based on new sources)
Update in APN List
Added Some Requested Apps (look @ Rom Description
BootAnimation Changed (a nice Frozen Yogurt Added)
V2.6 -> V3:
All Included apps is in /System/app To make it possible to Unintall or update it.
Huge APN LIST (Thanks @Bilias στον γείτονα απο τον Μαραθώνα)
Fix The Camera Green Thing
Back to Official Media-Profiles Settings for Video Camcorder
Please Dont Make Mirrors
1- ROM Download: Get 5.1 HERE
Sujet d'origine : http://forum.xda-developers.com/showthread.php?t=742075
Je l'ai sur mon désire depuis hier et pas de bug a signaler. Par contre si tu utilise mod installLocation fourni avec la ROM il faut faire gaffe de ne pas installer les widget sur la carte SD sinon il ne fonctionnent plus!
J'y suis passé depuis que la rom Leedroid 1.7 et + bug sur le theteering...
A priori pour contrecarrer le problème, le dev. de la rom a viré les drivers wifi N...
Pour info tout marche correctement dans cette rom (enfin je l'ai depuis 24h), les seuls "bugs" que j'ai repéré sont :
- impossible de virer ou MAJ certaines applications (celles installé dans system) : Titanium et Rom Manger sont concernés mais pour l'instant c'est pas grave...on peut d'ailleurs y remédier en passant des commandes ADB qui vont bien..
- pas de Youtube mais on peut trouver l'apk sur le net (attention à bien prendre la derniere version, les anciennes plantent, il y a un lien dans le topic de la rom sur xda le donnant)
Concernant la batterie , RAS ça a l'air correct.
PS : rom très proche de la leedroid, notamment le wake-up du screen via le trackball (je peux plus m'en passer maintenant ^^)
Modifié par fx-18
Est-ce qu'il est possible de déverrouiller le lockscreen avec la touche 'menu'? (Je parle de passer l'écran avec le slide vers le bas, pas de sortir le téléphone de veille)
C'est un truc qui marche pas sur la LeeDroid et ca m'énerve! ^^
@fx-18 : moi je trouve ca pratique, ca permet de déverrouiler très rapidement :)
@Kameo : c'est uniquement pour sortir le téléphone de veille ca, non?
La rom utilise A2SD+ donc ca ne doit pas se produire , bizarre ...
non c'est normal. Si tu active le mod isntallLocation tu utilises le app2SD de froyo, donc tu retrouves les problèmes de widget
Je comprends rien avec ces histoire de A2SD+ et A2SD Froyo..
Sur leedroid il y a par défaut le modInstallLocation d'installé moi je l'avais laissé par défaut et ma rom interne et la partition ext3 se vidait au prorata à chaque fois que j'installais un programme..
exemple dans Quick System Info :
avec une 100ene d'applications installés :
stockage interne de base 148mo, libre 102 mo, stokage AS2D 457mo, libre 296mo...
avec environ 150 applications installés j'avais :
stockage interne de base 148mo, libre 75 mo, stokage AS2D 457mo, libre 250mo...
Donc les 2 espaces sont gérés en même temps...je trouve ça normal non?
La sur la rom Roufianos...pareil j'ai réinstallé Quick System Info et modInstallLocation (car pas présent dans la V6) et je constate le même phénome...si dans modInstallLocation je change le mod par défaut...je pers plus en espace de stockage interne même si je mets en mode 2 external....du coup j'ai laché l'affaire mais j'aimerai bien comprendre pour culture "générale"....
Désolé pour le hs...
