Root xperia sp probleme
Bonsoir :)
Donc j'explique mon probleme directement , je comprend que dallllllll
Cela fait 2 jour que j'essaye de flash mon sony xperia sp (version 4.3 ) .201
mais cela ne marche pas , acheté nu .
Comment j'ai procdéder ?
bah j'ai tout suivis sur ce forum pour root mais sans résultat
La preuve :
j'ai  lancé flashtool , ensuite root force adbrestore .
04/019/2014 19:19:57 - INFO  - <- This level is successfully initialized
04/019/2014 19:19:57 - INFO  - Flashtool Version 0.9.15.0 built on 15-03-2014 23:00:00
04/020/2014 19:20:02 - INFO  - Device connected with USB debugging on
04/020/2014 19:20:04 - INFO  - Connected device : Sony Xperia SP
04/020/2014 19:20:04 - INFO  - Installed version of busybox : N/A
04/020/2014 19:20:04 - INFO  - Android version : 4.3 / kernel version : 3.4.0-perf-ga1d7493 / Build number : 12.1.A.1.201
04/020/2014 19:20:29 - INFO  - Pushing C:\Flashtool\.\devices\busybox\1.20.2\busybox to /data/local/tmp/busybox
04/020/2014 19:20:30 - INFO  - Pushing C:\Flashtool\custom\root\subin\Supersu\su to /data/local/tmp/su
04/020/2014 19:20:30 - INFO  - Pushing C:\Flashtool\custom\root\subin\Supersu\Superuser.apk to /data/local/tmp/Superuser.apk
04/020/2014 19:20:31 - INFO  - Pushing C:\Flashtool\custom\root\subin\Supersu\chattr to /data/local/tmp/chattr
04/020/2014 19:20:31 - INFO  - Pushing C:\Flashtool\custom\root\subin\Supersu\install-recovery.sh to /data/local/tmp/install-recovery.sh
04/020/2014 19:20:31 - INFO  - Pushing C:\Flashtool\custom\root\subin\Supersu\99SuperSUDaemon to /data/local/tmp/99SuperSUDaemon
04/020/2014 19:20:32 - INFO  - Pushing C:\Flashtool\custom\root\AdbRestore\RootMe.tar to /data/local/tmp/RootMe.tar
04/020/2014 19:20:33 - INFO  - Now open your device and restore "RootMe" backup. Waiting ...
04/020/2014 19:20:33 - INFO  - You have 60 seconds to follow the restore advice
04/020/2014 19:20:33 - INFO  - Running adbrestoreexploit
04/021/2014 19:21:34 - INFO  - Root hack did not work. Cleaning hack files
04/022/2014 19:22:32 - INFO  - Log written to C:\Flashtool\flashtool_2014-04-04_07-19-57.log
Bref SVPPP je suis perduuuu , je sais plus ce qu'il faut faire .... même les tutos j'i arrive pas , c'est très mal expliquer
driver installé , mode debuging activé ,source inconnue activ .
Salut
Je trouve le tuto du root sous 4.3 très bien expliqué mais si un passage te pose problème, dis-nous lequel et on essayera de t'aider à y voir plus clair ;)
rappel du lien du tuto
https://forum.frandroid.com/topic/183669-tuto-root-sous-jelly-bean-43-build-266-et-201-installation-cwm/
D'après ce que je vois, tu tentes de rooter ton téléphone avec flashtool. C'est pas ça qu'il faut faire. Avec flashtool il faut revenir à une version 4.1 ( flasher la rom stock suivante http://www.mediafire.com/download/2o0cnwj3oa86f4u/Xperia+SP_12.0.A.1.257_C5303.ftf ), ensuite suivre ce tuto pour rooter la version 4.1 https://forum.frandroid.com/topic/154425-tuto-root-sous-jelly-bean-41/ installer CWM, et depuis CWM intaller une rom prérootée puis installer supersu.
En gros flashtool n'est utilisé qu'une seule fois pour revenir à la version 4.1 et n'est jamais utilisé pour rooter.
Ok ok merci je vous contacte demain , je vais test ce soir puis si j'arrive pas je reposte ici .
je comprend pas trop enfaite ceci
Procédure si vous venez d'une rom 4.3 non rooté :
1) Flashez cette  rom stock 4.1.2 (12.0.A.1.257) : http://www.mediafire...1.257_C5303.ftf via flashtool
oué mais si je veux revenir en 4.1.2 je doit être root ...... non ?
Merci de vos réponses ;)
Bon étape 1 , 2 ,3 réussie OUFFFF
il s'avere que j'ai un autre probleme ^^
Voila je suis root mais je a partir d'ici je n'i arrive plus ...
C'est à dire a l'étape
'6) flashez la rom choisie et le supersu ensuite (que vous aurez copié sur votre carte SD au préalable)'
Je doit mettre quel rom dans ma carte sd ? car je veux mettre existenz 3.0.0
C'est juste a partir d'ici que je comprend vraiment plus rien enfaite ^^ .
Juste simple question étant donner que je suis root  en 4.1.2 , 12.0.A.1.257  (la rom du tuto)  je peux mettre directement existenz ? ou je doit continuer le tuto
merci à vous , suis perdu ..........
