AlmanKh Posté(e) 14 avril 2014 Share Posté(e) 14 avril 2014 Brief Description◾ First ever Note 3 dual sim ROM ported, integrated with air command, customized and fixed for OMEGA HD 2.0 users. Not all features you will see in this ROM will work, this is just to imitate the user interface of the original Galaxy Note 3.Compatibility◾ Can be flashed on Also works on all MyPhone A919i, FLY IQ451, Wiko Cink-5, Qmobile A600, Stealth 4 and other Clones. Screenshots: A venir Videos of OHD 2.0 but better performance on A116 also:https://www.youtube.com/watch?v=8iJR...MSRbV8KqS_mZhghttps://www.youtube.com/watch?v=MtRa...MSRbV8KqS_mZhg Highlights ◾This rom uses A919i STOCK KERNEL and other kernels are not required. In case you try any kernel, please do not discuss in this thread. But still everyone is free to try anything on this rom (at their own risk/choice).◾Note 3 UI & features◾4.2.1 rom (Please ignore 4.3 shown in about phone, its hardcoded and wrongly left over by mistake. will be removed later. sorry for that)◾Invisible SUPERUSER (No prompt)◾8MP Rare Camera and 2MP front Camera (Camera Original Quality Recommended)◾13MP Rare and 5MP front option also available (5mp Front Camera Results)◾Face Detection perfect in both Cameras, even in Front Cam working fine◾Dual Sim, Dual Standby◾No 3G in second sim as inherited from HDC SM-9006.◾Swipe to Call and Swipe to Message◾Fully Deodexed & Zipaligned◾Init.d support◾Busybox◾Pre-Rooted◾No air gestures◾No smart scroll◾Added working Multi Window feature◾Added air command feature◾Clear photo and video capture◾New lockscreen effect◾New and clean quick setting buttons◾Messaging counter notification◾and many more ROM Tools.◾Added GREENIFY. (how to effectively use GREENIFY?) Quote: Instructions to flash via CWM/TWRP1. Download zip file and Put into external/internal sd card3. Open Recovery mode (TWRP/CWM)4. Format System Partition (cwm>mount storage>format system) (twrp>AdvancedWipe)5. Wipe with Data/factory Reset6. Wipe Cache Partition and Dalvik Cache.7. Flash the rom zip file8. Fix Permissions if you are on TWRP and Reboot your device9. Open Greenify (app included) and hibernate all apps for double/better battery backup.10. Important: Charge phone to 100%, Calibrate battery (app included) and remove cable. Important Things to Remember:◾This rom uses A919i STOCK KERNEL and other kernels are not required. In case you try any kernel, please do not discuss in this thread. But still everyone is free to try anything on this rom (at their own risk/choice).◾Long Press Menu (Left) Button to open AIR COMMAND◾Long Press Home (Middle) Button to open Recent Apps in HTC Style◾Long Press Back (Right) Button to open/close SideBar◾Do not uninstall any existing apps else some features will not work.Bugs: (if you are not ok with these minor bugs, please do not download)NO MAJOR BUGS: Rom useable as daily driver. Please report in BUGS section. 1) Low-Sound Volume (Make her scream with this small sound fix)2) Led Notifications for SMS not working. Fix Coming Soon3)SystemUI FC Error due to Xposed: This error is related to conflict of home key in XposedFW +GravityBox. A user adityagulavani have suggested a quick-tip to solve this problem. Setup this option in GB and error is gone.GravityBox>>>Navigation_Keys-Actions >>> HomeKey+LongPressActions >>> Show_Recent_App*******DOWNLOAD PATCHES FROM DOWNLOAD SECTION IN 2ND POST BELOW.Disclaimer◾ I will not be responsible if you brick your device or any problems whatsoever..... Flash at your own risk.Download Link : In 3rd third post below :)Addons and Patches: 1) Low Sound Volume? Make her scream with this Fix Download2) Download S-Voice.APK if anyone need this Samsung app, can install it from here.Full Credits goes to © REMZEJ. for Full Rom and Research and help for porting and initial bugs.Original Thread REMZEJ who ported, modded, customized and for fixed this ROM for XOLO Q1000 / Cherry Mobile OMEGA HD 2.0 Other Credits:- Needrom for ROM sources- HDC for the Note 3 stock ROM- Dekdroid for uploading the stock ROM- XDA for the knowledge it gave me- Cherry Mobile for the phone- OMEGA HD 2.0 Official and MOD section group for continuous support.- Users of my ported ROM for appreciating my work.- To all others not mentioned but contributed to my work.- Saurabh Chauhan for testing and sending Front Camera Photos.- Me for BASE ROM of Philippines MyPhone A919i Stock Rom ROM Version 3.7B: http://d-h.st/qFl 13MGP CAMERA: http://forum.xda-developers.com/devdb/project/dl/?id=5274 Source: http://forum.xda-developers.com/showthread.php?t=2701135 Je vous conseille très fortement ce rom, il est vraiment très fluide et fait marcher les jeux de haute qualité tel que Modern Combat 4 parfaitement. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 14 avril 2014 Share Posté(e) 14 avril 2014 Tres bonne ROM. Deja testé. Mise à jour, patchs très rapide. Au TOP ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
cabbes Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 tout marche dessus (genre boussole ?) Est-ce qu'elle est en français ? merci pour les réponses ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Viktunee Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 Oui elle est en français pour ce qui est de la boussole [color=red][b]sa[/b][/color] m'etonnerais vu que la base c'est le a116 ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
halxium Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 elle a l'air super bien mais mon tel refuse categoriquement d'en accepter une , a chaque fois moi appareil photo plante . alors que su d'autre rom pas de soucie j'ai tout tester touts les wipes, reinstaller plusieur fois la rom etccc . je ne comprend pas Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 Il y a un patch dispo pour ça : http://forum.xda-developers.com/showthread.php?t=2701135 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
halxium Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 (modifié) c bien sa ? CAMERA_8MP_FM_PATCH_CNT_3x_C.zip car j'ai installer le patch 13 megapx mais rien Modifié 15 avril 2014 par halxium Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
julienwiko22 Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 Salut a tous je ne trouve pas le lien de téléchargement de la rom :/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Viktunee Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 (modifié) http://d-h.st/qFl Je le dit meilleur que la samflare de mon post. ( pour l'instant ) Modifié 15 avril 2014 par Viktunee Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
julienwiko22 Posté(e) 15 avril 2014 Share Posté(e) 15 avril 2014 mercii c'est mon pc qui bugaii ^^comment avoir les apps sur le lockscreen ? car cu une des video on vois un avec des apps sur le lock Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Viktunee Posté(e) 16 avril 2014 Share Posté(e) 16 avril 2014 Je ne sais pas - mais ta un lockscreen alternatif ou tu peux les ajouter : https://play.google.com/store/apps/details?id=com.lockscreen.galaxy Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
