cobalt80 Posté(e) 24 avril 2014 Share Posté(e) 24 avril 2014 bonjour/bonsoir j'aimerai savoire si il est possible d'inverser la memoire interne est externe sur un netbook dust epc-du1032x si sa peut vous aider je peut vous passer mon vold.fstab si dessous merci d'avance de votre reponse ## Vold 2.0 Generic fstab ## - San Mehat (san@android.com) ## ####################### ## Regular device mount ## ## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...> ## label - Label for the volume ## mount_point - Where the volume will be mounted ## part - Partition # (1 based), or 'auto' for first usable partition. ## <sysfs_path> - List of sysfs paths to source devices ###################### #wmt sd dev_mount sdcard /storage/sdcard1 auto /devices/platform/sdmmc.0 #dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc1.0 #dev_mount sdcard /mnt/sdcard auto /devices/platform/sdmmc2.0 #wmt usb dev_mount udisk /storage/udisk auto /devices/pci0000:00/0000:00 #wmt localdisk #dev_mount sdcard /sdcard auto /devices/virtual/block/loop0 ## Example of a standard sdcard mount for the emulator / Dream # Mounts the first usable partition of the specified device #dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1 ## Example of a dual card setup # dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1 # dev_mount right_sdcard /sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1 ## Example of specifying a specific partition for mounts # dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
