configurer a2sd
qiper
bonjour à tous
j'ai installé la rom flb 1.1 qui contient a2sd. en suivant le tuto de ddavid, j'ai tapé "su" puis "a2sd check" dans terminal emulator et voilà ce qui est affiché:
[]Apps2SD is launching…
[]starting darktremor apps2sd
version 2.7.5 preview fix 4a
[]starting darktremor apps2sd in check mode
[]running apps2sd check program
[]searching for mount point…
[*]mount point /system/sd located
[]checking for ext partition
darktremor apps2sd status report
partition    -[*] mounted as ext
apps   -[]linked to sd card
[]file .noa2sd no found
[]programs run from sd card
to run from internal storage, type a2sd remove
private apps   -[]linked to sd card
[]private programs run from sd card
dalvik cache   -[]symbolically linked
[]file .dalvik cache found
[]dalvik tins from sd card
to run from internal storage, type a2sd nocache
to run from /cache partition, type a2sd cachepart
swap   -[]partition not present
[]swap does not start
zipalign   -[]not running at boot
dalvik heap (mb) -24m
(blanka is default value)
property patch   -[]file system ready property found
[]boot image init.rc patched
[]setting file system ready property to 1.
je pense que a2sd n'est pas actif ou pas bien configuré. que dois-je faire pour le rendre opérationnel?
merci d'avance.
ben si, il semble l'être justement
