startup error flashtool
Teddy Du 84
Le problème vient de la je pense , il y a un passage intéressant sur l'installation de flashtool :
In the unzipped folder, run Emma.exe. During the installation, make sure you remember the installation path:
Default path in Windows 64 bit is: “C:\Program Files (x86)\Sony Mobile\Emma\”
Default path in Windows 32 bit is: “C:\Program Files\Sony Mobile\Emma\”
Le lien : http://developer.sonymobile.com/services/flash-tool/how-to-download-and-install-the-flash-tool/
