[Android App] Change Net Hostname (Best Hostname Changer)
Description
Android geeks tool to change your device Net.Hostname in build.prop system configuration file easily. Please
note that your device must be (ROOTED) for the application to function properly.
Main Features:
- Change Net.Hostname
- Backup/Restore Net.Hostname
- Displays last modification date
- Displays the current Net.Hostname value before and after update
- Reboot upon request
Note: After changing Net.Hostname your device must be rebooted for the change to take effect.
Link
https://play.google.com/store/apps/details?id=geha.buildprop.com
FrAndroid est un forum francophone. Seuls les posts en français ou bilingues avec une traduction française compréhensible sont acceptés.
Vous avez 24h pour ajouter une traduction satisfaisante à votre message. Sinon, il sera supprimé
Hello,
FrAndroid is a french-speaking forum. Only posts written in french, or bilingual posts including an understandable french translation are accepted.
You have 24 hours to add such a translation to your post. If not, it will be deleted
