HTC One M8 Theme
bonjour
HTC One M8 Theme
**This theme is based on HTC One M8
Supports:
. Apex Launcher
. Nova Launcher
. Solo Launcher
. Go Launcher Ex
. ADW Launcher Ex
. Holo Launcher
. Atom Launcher
. Action Launcher
. Smart Launcher
. Mini Launcher
Features List:
. Dashboard
. HD Icons.
. Apex Launcher skin included.
. 20 HD Stock Wallpapers.
. HTC One M8 Wallpaper Gallery.
Notes:
. Credits to DesignRifts, The1dynasty and Kovdev for the template and help
. To set wallpapers from the theme goto Launcher options –> Wallpaper –> Wallpapers.
. If the icons do not appear for the above launchers then we recommend you to restart your launcher.
. It is also recommended not to move the theme app to SD Card.
If you liked our work then please try our other themes too, they are equally good.
Current Version : 1.1
Requires Android : 2.2 and up
download
merci
