Inversion de carte SD
CaptPicard
Bonjour cher Andronaute.
Je déterre mon vieux E320.
J'ai flashé une rom russe trouvé sur acer-club.ru (http://acer-club.ru/files/file/486-%D0%BD%D0%B5%D0%BE%D1%84%D0%B8%D1%86%D0%B8%D0%B0%D0%BB%D1%8C%D0%BD%D0%B0%D1%8F-%D0%BF%D1%80%D0%BE%D1%88%D0%B8%D0%B2%D0%BA%D0%B0-acefirmware-liquid-express-e320-v2/) plutot génial avec recovery + root , bref le top. (2.3.4 )
Cependant
Je souffre comme beaucoup du manque de place sur la SD interne vite saturé, je souhaitais donc comme fait sur un Acer E2 inverser logiciellement les cartes SD interne/externe. (via un CWM_SDCard_Switch par exemple / modification du fichier Vold)
Sauf que celui ci sur le E320 est plutôt "light" !
Pas moyen d'y arriver,
Mon fichier Vold.fstab se compose comme suis :
# Copyright © 2010, Code Aurora Forum. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are
# met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above
# copyright notice, this list of conditions and the following
# disclaimer in the documentation and/or other materials provided
# with the distribution.
# * Neither the name of Code Aurora Forum, Inc. nor the names of its
# contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED
# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
# MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT
# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
# BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
# BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
# OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
# IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
dev_mount sdcard /mnt/sdcard auto /devices/platform/msm_sdcc.1/mmc_host
Quelqu'un serait il bidouiller pour faire la manip que je souhaite obtenir ?
Ou une solution alternative pour retailler la partition interne sur l'externe ?
Je sais que c'est un peu complexe mais je pose la question,  peut être qu'un débrouillard sera m'aider ?
Merci d'avance pour votre aide
A voir ce vold.fstab, il semble que ce smartphone n'ait pas de "SD interne" comme le E2 (une partition de la flash interne qui est gérée comme une SD).
Ca veut dire qu'ici, les applis déplacées vers la SD depuis le gestionnaire d'applis doivent partir directement sur la SD.
Ca ne suffit pas à libérer assez de place ?
En tous cas pas d'inversion possible puisqu'il n'y a rien à inverser.
L'autre approche c'est le root + un programme type Link2SD (il y en a d'autres) qui permet de déporter des dossiers de /data vers la SD, à condition qu'elle soit partitionnée en 2.
  • 1 year later...
Oui c'est ce que j'ai finis par faire, j'ai préparé ma carte sd ajouté une partition EXT4 au debut de ma carte, le reste en FAT32 (déplacé du coup sans wipe) +
Mounts2SD - Storage & Memory qui a fait le necessaire pour le parametrage.
Reussi
Je précise qu'un wipe data/cache/factory est quand meme bien plus fonctionnel pour qu'il prenne en compte la nouvelle taille de mémoire (sachant que dans les parametres il vous indiquera que la taille n'est pas la) alors que si ^^ la taille est bien présente, suffit d'installer 100 appli pour s'en rendre compte ^^ (je plaisante)
Merci en tout cas, telephone de secours de nouveau fonctionnel et qui dépanne bien !
