Abdelkrim Leneguer Posté(e) 19 juillet 2014 Share Posté(e) 19 juillet 2014 bonjour je viens d'aquerrir une tablette sans nom, pourriez vous m'aider a connaitre samarque ou autr chose dont voici les caracteritiques Manufacturer rockchipModel 10.1-T2Android version 4.1.1; 20130604.134931; SDK16CPU 2 cores; ARMv7 Processor rev 0 (v7l) rk30xx; Max: 1512,0 MHz; Min: 252,0 MHzDisplay 1280 x 800; DPI: 160; Evaluated Size: 9,4"Touch screen Multitouch 5 pointsGPU Mali-400 MP; ARM; OpenGL ES-CM 1.1; OpenGL ES 2.0RAM 892 MBFlash 16 GB Build-in (15.320 GB actual)CommunicationsPhone NoneWiFi wlanUSB Host YesBluetooth noGPS YesAdvanced FeaturesFront camera Photo: 1.9 MP; Max: 1600x1200; Focus: fixed; No flashBack camera Photo: 0.3 MP; Max size: 640x480; Focus: fixed; No flashSensors MMA8452Q 3-axis Accelerometer (Freescale Semiconductor); range: 0...39,24; resolution: 0,153 (0,391%); power: 0,2mA;AK8975 3-axis Magnetic field sensor (Asahi Kasei); range: 0...2000; resolution: 0,062 (0,003%); power: 6,8mA;Corrected Gyroscope Sensor (Google Inc.); range: 0...34,907; resolution: 0,001 (0,004%); power: 13,1mA;AL3006Proximity sensor (Dyna Image Corporation); range: 0...9; resolution: 9 (100%); power: 0,5mA;AL3006 light sensor (Dyna Image Corporation); range: 0...10240; resolution: 1 (0,01%); power: 0,5mA;Rotation Vector Sensor (Google Inc.); range: 0...1; resolution: 0 (0%); power: 13,1mA;Gravity Sensor (Google Inc.); range: 0...19,613; resolution: 0,153 (0,782%); power: 13,1mA;Linear Acceleration Sensor (Google Inc.); range: 0...19,613; resolution: 0,153 (0,782%); power: 13,1mA;Vibrator YesSupported languages 47; Afrikaans; Amharic; Arabic; Belarusian; Bulgarian; Catalan; Czech; Danish; German; Greek; English; Spanish; Estonian; Persian; Finnish; Filipino; French; Hebrew; Hindi; Croatian; Hungarian; Indonesian; Italian; Japanese; Korean; Lithuanian; Latvian; Malay; Norwegian; Dutch; Polish; Pashto; Portuguese; Romansh; Romanian; Russian; Slovak; Slovenian; Serbian; Swedish; Swahili; Thai; Turkish; Ukrainian; Vietnamese; Chinese; ZuluBattery Technology: Li-ion; Voltage: 7Owner's comment: robusteSD Version: 1.1 5 Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 20 juillet 2014 Share Posté(e) 20 juillet 2014 Bonjour, Que cherches-tu à savoir au juste ? Si c'est une tablette no-name, c'est qu'il n'y a justement pas de marque. Et tu nous donnes toi-même sa fiche technique copiée de quelque part manifestement. :huh: En outre, merci de bien vouloir mettre le titre du sujet au format indiqué dans : >>>>>>> A LIRE AVANT DE POSTER <<<<<<<. En l'occurrence, rajouter [Générique 10.1-T2] à gauche dans le titre, par exemple. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Abdelkrim Leneguer Posté(e) 20 juillet 2014 Auteur Share Posté(e) 20 juillet 2014 tout d'abord merci ce que je cherche a savoir entre autre, si c'est un clone de quoi exactement, parce que voyez vous cette tablette est commercialisé sous la marque robuste en Algérie, le site du revendeur ne donne aucune information. depuis peu elle s'etteint toute seule après l'avoir chargé a 100%, des qu'elle atteint 70% Impossible alors de la faire demmarer sauf si je branche le chargeur. elle demmarre alors en indiquant 35%, ou 60% ça dépend. si je l'étteint après l'avoir chargé a 100% et je rallume elle indique 88% de charge sur les conseil d'un ami j'ai fait le factory reset (réglage usine) a deux reprises, mais le problème est toujours le même. auriez vous une solution a ce problème???? Lien vers le commentaire Partager sur d’autres sites More sharing options...
zrt22 Posté(e) 21 juillet 2014 Share Posté(e) 21 juillet 2014 Un retour SAV est sûrement la meilleure solution dans ce cas. La recherche d'une tablette clone n'est pas évidente et encore faudrait-il qu'elle ait un firmware à disposition et que la cause du soucis ne soit pas hardware... Lien vers le commentaire Partager sur d’autres sites More sharing options...
