ornadyx Posté(e) 20 juillet 2014 Share Posté(e) 20 juillet 2014 (modifié) Code: Your warranty is now void. JK, this is OnePlus no voided warranties here!I am not responsible for bricked devices, dead SD cards,thermonuclear war, or you getting fired because the alarm app failed. Pleasedo some research if you have any concerns about features included in this ROMbefore flashing it! YOU are choosing to make these modifications, and ifyou point the finger at me for messing up your device, I will laugh at you.A lot. Download Link HEREMD5 f5701eb363094f6e081ce7ff7da26a44GAPPs HERE Do NOT use PA 0 Day STOCK Gapps (it will break things you want to work)Mahdi Theme: HEREInstallation instructionsInstalling Mahdi-Rom for the first time, or coming from another ROM:- Make sure you're running a proper working Team Win Recovery Project HERE- Copy Gapps and ROM ZIP to your SDCard- Boot into Recovery- Factory Reset- Wipe Cache- Wipe System- Wipe Dalvik- Flash Mahdi-Rom zip from SDCard- Flash Gapps zip from SDCard- Reboot- Don't restore system data using Titanium Backup!Upgrading from an earlier version: (not recommended)- Copy the ROM ZIP to your SDCard- Boot into Recovery- Flash the ROM zip from SDCard- RebootSettings menuSound- DSP Manager (Music Effects)- Quiet hours- Ascending ringtone- Volume panel timeout- Less frequent notification sounds- Control volume adjust sound- Launch music app on headset connect- Control safe headset volume- Power connect notification control- Apollo as Default Music App- Volume steps- Volume rocker music controls- Volume default- Volume adjust sound- Reorient volume buttons- Safe headset volume- Power soundsDisplay- Advanced auto brightness control- Advanced wallpaper control- Full rotation control including lockscreen- Screen record with audio- Notification LED Control- Battery LED Control- Wake up device on plugin/unplug- Double-tap to wake- Adaptive backlight- Screen colorSecurity- Variable size pattern unlock- Pin keypad shuffler- Lock before unlock- Privacy guard- BlacklistLanguages & input- Auto keyboard rotation- Disable fullscreen keyboard- Selector notification- Volume key cursor controlDeveloper options- Advanced reboot- Enable Quickboot mode- ADB over network- Development shortcut in recent apps list- Show cpu info- Change device hostnameThemes- Dark-UI- CM11 theme engineCustomization menuNavigation- Hardware button options- Disable hardware buttons- Pie Navigation- Navbar OptionsStatus bar- Clock and date customisation- Battery customisation- Battery bar- Show battery status percent- Notification count- Network speed indicator- Statusbar brightness control- Double tap to sleep options- Immersive modePanel settings- Notification drawer options- Background style options- Quick pulldaown- Smart pulldown- Show smaller tiles- Flip tiles- Tiles and layout options- Dynamic tilesNotifications- Heads up- Enable notification reminder- Lock screen notification options- PeekMultitasking- AOSP recents- Slim recentsPower menu- Profile switcher- Immersive mode- Screenshot- Screen record- On-The-Go ModeLock screen- Targets customisation- Battery level on lock ring- Slider Torch- See through settings- Style customizations- Maximize widgets optionAnimation control- Screen off- Toast- System- Listview- Scrolling- Keyboard- Progress barsShake Events- Shake sensitivity- KeyguardDriving mode- Incoming call- Read new message- Battery full indicator- Connect charger- Disconnect charger- Clock- Date- Music Track- Notification- Read new notifications- Included apps- Less frequent speak notificatons-HERE-HERE- Mahdi-Rom (Mahdi786) Without this awesome DEV we would not have what you see here! Make sure that any donations go to this DEV!- dr87 for everything!- Manelscout4life For building the ROM and teach me how to as well!- dsmitty166 for OTA and helping build this amazing ROM!- Damir Franc for his awesome ROM review HERE- TechXero for letting us use his server!- Cyanogenmod- Paranoid Android- Slim ROM- Omni ROM- ChameleonOS Source Enjoy ! :) Modifié 23 juillet 2014 par Ornadyx Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Pap0ose Posté(e) 20 juillet 2014 Share Posté(e) 20 juillet 2014 Merci à toi .. ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ornadyx Posté(e) 20 juillet 2014 Auteur Share Posté(e) 20 juillet 2014 De rien ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gro95qg Posté(e) 20 juillet 2014 Share Posté(e) 20 juillet 2014 Merci de la presentation J ai utiliser un peu cette rom sur mon s4 c'etait pas mal a l époque déjà Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ornadyx Posté(e) 20 juillet 2014 Auteur Share Posté(e) 20 juillet 2014 C'est une des meilleures rom que j'ai pu utiliser sur mon Nexus 4 ! Envoyé de mon One Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gro95qg Posté(e) 20 juillet 2014 Share Posté(e) 20 juillet 2014 Tu pourrais y faire une petite traduction des chose en Anglais Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
JustinR Posté(e) 20 juillet 2014 Share Posté(e) 20 juillet 2014 Avec screenshots des homes/des principales ajout proposer par la roms par rapport a la rom stock. Ca serais nickel B) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ornadyx Posté(e) 21 juillet 2014 Auteur Share Posté(e) 21 juillet 2014 J'essaierai de faire ça le week-end prochain car en semaine j'ai pas le temps du tout. :-) Envoyé de mon One 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Gro95qg Posté(e) 21 juillet 2014 Share Posté(e) 21 juillet 2014 No prob :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ornadyx Posté(e) 23 juillet 2014 Auteur Share Posté(e) 23 juillet 2014 Version du 23 disponible. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
jim777 Posté(e) 24 juillet 2014 Share Posté(e) 24 juillet 2014 sur mon nexus etait vraiment bien!!!sur le one pareil? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
