CrDroid B12 [Hover,Halo,Pie]
CrDroid
CrDroid est une Rom Custom basé sur CaynogenMod. Très stable et quasiment sans bug (inconnue de CM du moins). Voici ces différentes avantages
PA's Halo;
PA's Hover;
Hover exclude low priority notifications;
Hover exclude non-clearable notifications;
Hover require full screen mode;
Hover notification time;
Hover exclude topmost app;
Hover exclude from insecure lockscreen;
Screenshot quick trash;
Power menu QS tile (simple press to go into power dialog or long press to go into reboot dialog);
Power menu added in navring targets;
Last app added in navring targets;
Incoming call in background;
Navigation bar dimensions;
Enable or disable navigation bar;
Low battery warning options;
Lockscreen PIN keypad shuffler;
Lock before unlock (Show sliders before secure unlock);
Notification drawer custom background and transparency;
Notifications row transparency;
Custom clear all recents button (place it in any corner of the screen);
RAM bar;
Option to hide app's status bar notification icons;
Status bar clock and date customization;
Open source Google dialer;
Volume panel configurable timeout;
Screen recorder;
Wakelock blocker;
Media Scanner behavior on boot;
Notification reminder;
Notification reminder flip interval;
Smart Pulldown;
SlimRoms recent panel;
Slim recent with option to show in left side and switch sizes (100, 85 and 70%);
Slim recent add favorite mode (click on app icon in recent panel to choose as favorite);
Slim recent developer shortcuts;
Slim recent floating mode;
Slim recent add blacklist interface;
Ability to switch between recent panel styles (Stock or SlimRoms);
Improved scrolling cache;
Ability to Enable/Disable Smart Wake covers;
Ability to disable hardware keys via nav bar settings (Only visible in devices with hardware keys and enable through overlay);
Keyboard: toggle to enable/disable full screen on landscape;
Keyboard: force auto rotation on IME;
Keyboard: force to show always enter key;
Live volume steps;
Custom navbar recent long press (none, last app, screenshot, kill app, notifications panel, QS panel, power menu);
Long press back to kill configurable timeout;
People lookup settings;
Option to enable notifications with screen on;
SlimRoms Location tile with addition of labels for all states;
Brightness slider in expanded notifications panel;
Option to disable widgets frames on lockscreen;
Lockscreen notifications;
Telo Radio (Connection manager);
Smart call;
QS extended options (tiles per row - 3, 4 or 5 -- custom background color, custom text color, custom background pressed color, transparency);
Gesture lockscreen;
Pause, resume or stop downloads from notification area;
DSP Manager: Center frequency param to bassboost;
DSP Manager: Stereo widener effect;
PA PEEK;
PEEK: Beautify bridging layers code
PEEK configurable pickup timeout;
PEEK configurable wake timeout;
Blacklist from PEEK;
Appbar by ChameleonOS;
Launch floating window from notification (long click);
Launch floating window from recents panel (long click);
Blacklist from floating mode
Option to enable/disable hepatic feedback on tiles pressing;
Flip to Mute/Reject Call;
Gestures anywhere;
Lien de Dl:http://www.mediafire.com/download/glcablc524kk4t1/crDroid-b12-20140804-falcon.zip
Bugs Connus: L'application Appollo (et ses dérivés) (Il y a un fix apparemment mais je ne sais pas où)
Ma participation personnel à ce forum, ça fait quelques jours que j'utilise cette Rom et je dois avouer en être plutôt content. Les différents ajouts par rapport à la CM de base sont vraiment les bienvenus. Je vous la conseil à tous et à toutes ^-^
Pour les screens:
post-183328-0-33898100-1406036536_thumb.
post-183328-0-72566000-1406036535_thumb.
post-183328-0-15235900-1406036534_thumb.
post-183328-0-83543700-1406036534_thumb.
post-183328-0-93059500-1406036532_thumb.
post-183328-0-84429300-1406036531_thumb.
post-183328-0-84026300-1406036530_thumb.
post-183328-0-87957200-1406036529_thumb.
post-183328-0-91539200-1406036528_thumb.
Modifié par Daestraz
@@Couzben Désolé, je les avais mis mais ils ne sont visiblement pas passer :/
@ C'est le lien original, sauf que je l'ai raccourci. Mais j'essyerai de mettre le lien normal si tu insistes
Edit: les changements ont été faits ;)
Je n'ai aucun problème pour les appels. Pour la musique, le seul problème est qu'Appollo réagit très hasardeusement mais il existe un fix pour ça (de plus utiliser une autre application du genre PowerAmp, Google Musique évite ce problème). Sinon, je ne vois pas de quoi tu parles
Salut , bon alors j ai testé cette rom et mes bugs ne correspondent pas aux votres ... En effet pratiquement tout le temps quand je déverrouille mon appareil ca me met une erreur , la barre de navigation et les notifications en haut s en vont pour revenir et verrouiller mon appareil . Lorsque je déverrouille mon appareil, tout redeviens normal .
Je dois dire que c est assez saoulant, j ai essayé de redemarrer, ca ne marche pas .
Il y a aussi un autre désavantage sur cette rom , c est qu on ne peut pas controler la barre de navigation en bas, concernant la taille , les icones ect .. Quoi que si , en passant par un theme cm11 ( mais c est beaucoup moin complet que la rom mokee OS)
Salut j'utilise cette rom depuis quelques jours, suite au bug son survenu sur la cm11.
Alors pour mon utilisation elles est parfaite, enfin presque.
Apollo ne fonctionne pas correctement (mais ca je le savait mais sur la dernière cm j'avais déjà ce pb), j'ai donc essayé d'installer google music mais ca ne passe pas (est ce que l'install que j'ai fait, de la rom, est bonne? je ne sais pas normalement oui).
Sinon coté autonomie que dire a part wahou! En effet mon moto G a tenu 1j21h avant que je le mette en charge a 14%, autonomie obtenue avec mon utilisation n'est donc pas forcement représentative (pas de jeu, un peu de tel, du wifi avec fb, tapatalk, mail, journal). Est ce que c'est du au fait que la batterie ne se soit pas recalibrée après l’installe de la rom (pour un autre tel c'est une explication qui m'avait été donné).
Petite question pour les mise a jour de la rom, ca marche en OTA? Ou faut il passé par le téléchargement du zip et l'install par le recovery (donc installation manuelle).
Sinon good job au(x) dev, et merci a celui qui a poster la rom ici :D
@ De rien, je la trouvais aussi super bonne donc je l'ai posté ici ;) Pour l'OTA, il y en a pas malheureusement... et pour ton problème d'install, ben je sais pas si t'as fais les manips habituelles donc:
- Install dans le CWM
- Wipe cache
- Wipe Data/ Factory Reset
- Wipe Dalvik Cache (au cas où)
- Reboot
ça devrait aller. J'ai eu aucun soucis à installer PowerAmp en tout cas ^^
Nouvelle version !
Changelog:
- Switch to SlimRoms Heads Up;
- Heads up content:
* Launch in floating window
* Option to show always expanded
* Show updates from pending background apps
* Show at bottom of the screen
* Snooze time
* Notification time out
* dismissing to right keeps notifications in notif panel and to left dismiss notifications from all
- No more heads up switch to enable/disable and instead of this you need to go into Settings -> Apps and choose an app that you want to receive notifications from Heads up!
- Long pressing an app from notification drawer also show an option to receive notifications from Head up!
