amans Posté(e) 26 août 2009 Share Posté(e) 26 août 2009 nonjour à tous ! je ne parviens pas à faire fonctionner le wifi chez moi ! (je n'ai pas encore pu tester autre part...). mon routeur fait access point wifi, avec du WEP et en ip statique ! je parviens parfaitement à me connecter au routeur, par contre pas de navigation, rien ! si je ping mon tel à partir de mon routeur il lutte pour répondre zarathoustra# ping 192.168.200.8 PING 192.168.200.8 (192.168.200.8): 56 data bytes 64 bytes from 192.168.200.8: icmp_seq=16 ttl=64 time=2057.936 ms 64 bytes from 192.168.200.8: icmp_seq=17 ttl=64 time=1048.952 ms 64 bytes from 192.168.200.8: icmp_seq=24 ttl=64 time=14.909 ms 64 bytes from 192.168.200.8: icmp_seq=30 ttl=64 time=7.732 ms 64 bytes from 192.168.200.8: icmp_seq=31 ttl=64 time=9.402 ms 64 bytes from 192.168.200.8: icmp_seq=32 ttl=64 time=29.486 ms 64 bytes from 192.168.200.8: icmp_seq=38 ttl=64 time=15.062 ms 64 bytes from 192.168.200.8: icmp_seq=39 ttl=64 time=24.120 ms 64 bytes from 192.168.200.8: icmp_seq=46 ttl=64 time=15.850 ms 64 bytes from 192.168.200.8: icmp_seq=61 ttl=64 time=20.616 ms 64 bytes from 192.168.200.8: icmp_seq=68 ttl=64 time=16.430 ms 64 bytes from 192.168.200.8: icmp_seq=89 ttl=64 time=15.244 ms 64 bytes from 192.168.200.8: icmp_seq=90 ttl=64 time=19.136 ms 64 bytes from 192.168.200.8: icmp_seq=141 ttl=64 time=23.699 ms 64 bytes from 192.168.200.8: icmp_seq=148 ttl=64 time=19.770 ms 64 bytes from 192.168.200.8: icmp_seq=149 ttl=64 time=33.929 ms 64 bytes from 192.168.200.8: icmp_seq=156 ttl=64 time=29.486 ms 64 bytes from 192.168.200.8: icmp_seq=160 ttl=64 time=13.482 ms 64 bytes from 192.168.200.8: icmp_seq=163 ttl=64 time=25.117 ms 64 bytes from 192.168.200.8: icmp_seq=170 ttl=64 time=20.990 ms 64 bytes from 192.168.200.8: icmp_seq=185 ttl=64 time=1048.155 ms 64 bytes from 192.168.200.8: icmp_seq=186 ttl=64 time=39.081 ms 64 bytes from 192.168.200.8: icmp_seq=192 ttl=64 time=20.391 ms 64 bytes from 192.168.200.8: icmp_seq=193 ttl=64 time=39.642 ms 64 bytes from 192.168.200.8: icmp_seq=199 ttl=64 time=22.946 ms 64 bytes from 192.168.200.8: icmp_seq=200 ttl=64 time=38.317 ms 64 bytes from 192.168.200.8: icmp_seq=207 ttl=64 time=21.890 ms 64 bytes from 192.168.200.8: icmp_seq=214 ttl=64 time=27.460 ms 64 bytes from 192.168.200.8: icmp_seq=221 ttl=64 time=23.453 ms 64 bytes from 192.168.200.8: icmp_seq=222 ttl=64 time=37.824 ms 64 bytes from 192.168.200.8: icmp_seq=229 ttl=64 time=32.901 ms 64 bytes from 192.168.200.8: icmp_seq=236 ttl=64 time=23.062 ms 64 bytes from 192.168.200.8: icmp_seq=244 ttl=64 time=38.634 ms 64 bytes from 192.168.200.8: icmp_seq=251 ttl=64 time=35.818 ms 64 bytes from 192.168.200.8: icmp_seq=258 ttl=64 time=30.908 ms --- 192.168.200.8 ping statistics --- 315 packets transmitted, 45 packets received, 85.7% packet loss round-trip min/avg/max/std-dev = 7.732/161.558/2074.244/461.677 ms on voit qu'il est loin de répondre à chaque demande et que les temps sont plus que long.... si j'essai avec un ordinateur portable de faire la même connexion wifi (même ip, même dns), tout fonctionne parfaitement ! je comprends pas.......une idée ? merci de votre aide edit : ah oui, j'oubliais....la réception est évidemment parfaite ! c'est un ping sous openbsd (mon routeur) donc quand je dis qu'il ne répond pas à chaque fois il faut regarder le "icmp_seq" ! quand cela ne répond pas il n'affiche pas comme sur d'autre un time out.... Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 personne n'a rencontré ce genre de problème ?? Lien vers le commentaire Partager sur d’autres sites More sharing options...
20Syl Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Nan, mais je peux te dire que le wifi et le Hero c'est pas encore au point à mon avis... Lien vers le commentaire Partager sur d’autres sites More sharing options...
destri Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Nan, mais je peux te dire que le wifi et le Hero c'est pas encore au point à mon avis... Heu ? :/ Je n'ai aucun problème de connexion wifi à la maison avec ma bbox. Je me suis déjà connecté sans soucis sur des spots gratuits dans des starbucks, quick et à la gare de lyon... Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 bon jvais aller essayer dans la rue.... mais je comprends quand même pas pourquoi les pc n'ont pas de souci pour se connecter à mon routeur mais mon hero oui :/ bizarre Lien vers le commentaire Partager sur d’autres sites More sharing options...
20Syl Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Heu ? :/ Aucun problème avec ma dartybox non plus, mais avec l'APN du wifi ça passe une fois sur 20 Alors que j'ai pas de problème avec le reste (PC, iPhone...) Lien vers le commentaire Partager sur d’autres sites More sharing options...
JeP Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Sans tenter de connexion pour l'instant, as-tu testé avec des applis du genre scan de wifi genre Wifi Analyser pour voir si matériellement ton tél n'a pas de souci ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
EtienneM Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Nan, mais je peux te dire que le wifi et le Hero c'est pas encore au point à mon avis... Ah bon ??? :rolleyes: Je surf de partout sans problème. J'utlise l'application Wefi, qui permet de se conneecter automatiquement au premier wifi non protégé, sans page de login. Dès lors, synchronisation des mails auto, c'est parfait. J'ai même pu tester SIPdroid dans la rue. Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 Sans tenter de connexion pour l'instant, as-tu testé avec des applis du genre scan de wifi genre Wifi Analyser pour voir si matériellement ton tél n'a pas de souci ? je viens de l'installer... en AP List : il m'affiche bien mon réseau avec 2462MHz et entre -20 et 50 dBm (tout dépend de la distance entre le téléphone et l'antenne wifi.... -20 étant quand le tel est posé pratiquement à côté) Lien vers le commentaire Partager sur d’autres sites More sharing options...
madev Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Nan, mais je peux te dire que le wifi et le Hero c'est pas encore au point à mon avis... J'utilise le wifi avec ma freebox sans soucis, et sur les hotspot pareil ... Je n'ai rencontré aucun problème de wifi avec le hero. Peut être des téléphones défaillants ? En tout cas je ne pense pas qu'on puisse généraliser. Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 bon le channel où j'étais était pas le meilleur selon wifi analyser.... donc j'ai changé pour le meilleur conseillé...... idem :/ edit : pour info j'ai installé également whatismyip, et celle-ci est bien la bonne... Lien vers le commentaire Partager sur d’autres sites More sharing options...
JeP Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Au pire tu as la possibilité d'essayer le wifi Hero chez un pote ou un voisin ? Sait-on jamais, un problème avec ton routeur... Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 Au pire tu as la possibilité d'essayer le wifi Hero chez un pote ou un voisin ?Sait-on jamais, un problème avec ton routeur... ouai va bien falloir que j'aille tester autre part.... je comprends quand même pas pourquoi avec les ordinateurs portables (testé avec 2) tout fonctionne.... Lien vers le commentaire Partager sur d’autres sites More sharing options...
20Syl Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Chez moi le wifi marche donc ne généralisons pas J'ai des problèmes avec certains réseaux wifi, amans à des problèmes avec son réseau wifi, y a des retours de gens qui ont des problèmes. Je pense pas que ce soit vraiment des problèmes isolés. Chez vous, ça marche, c'est super. A mon avis, y a un truc qui est pas au point. C'est mon avis, je généralise pas, hein ? Maintenant faut le trouver, ou trouver une solution. amans tu peux pinger ton routeur depuis ton téléphone ? et ping google.com ? C'est pas un problème de passerelle ? Sinon ça marche mieux après un reboot ? un passage en mode avion ? un reset usine ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
destri Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 ouai va bien falloir que j'aille tester autre part.... je comprends quand même pas pourquoi avec les ordinateurs portables (testé avec 2) tout fonctionne.... Tu es chez quel fournisseur internet ? Le test intéressant serait aussi de trouver quelqu'un qui a un Hero dont le wifi ne pose pas de problème et de voir s'il arrive à se connecter sur ta box. Je pense à un truc, alors que tout fonctionnait bien en wifi à la maison, dimanche matin, impossible d'aller sur internet avec le Hero... Je trifouille tous les paramètres sur le Hero tout était normal, bien connecté en wifi, mais pas de surf ! Groumpf me dis-je ! C'est quoi cette m...e ! Tout fonctionnait jusque là... Je vais sur la console de ma bbox, je fouille partout et ... au bout d'un moment je m'aperçois que mon Hero apparait deux fois dans la partie wifi : (même adresse mac) une fois connecté, l'autre deconnecté.... !!??? :rolleyes: :rolleyes: A tout hasard, je supprime la session deconectée et .... Le Hero se connecte aussitôt à Internet .... Tout fonctionne de nouveau Une piste à creuser peut être pour toi ...? Lien vers le commentaire Partager sur d’autres sites More sharing options...
madev Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Nan, mais je peux te dire que le wifi et le Hero c'est pas encore au point à mon avis... Chez vous, ça marche, c'est super. A mon avis, y a un truc qui est pas au point. C'est mon avis, je généralise pas, hein ? Maintenant faut le trouver, ou trouver une solution. Uhuh ... chercher l'erreur :rolleyes: Bref, tout ça pour dire qu'il est possible qu'il y ait des lacunes, j'apporte juste ma contribution en précisant que je n'ai pas de soucis, et donc qu'il faut voir plus loin que le bout de son nez et dire que le wifi et le héro c'est pas au point. Il y a surement des problèmes (pas forcément dus au hero), et on ne peut pas généraliser Lien vers le commentaire Partager sur d’autres sites More sharing options...
20Syl Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Uhuh ... chercher l'erreur :rolleyes: Il n'y a pas d'erreur. C'est mon avis. Lien vers le commentaire Partager sur d’autres sites More sharing options...
cyberneo Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 pour avoir essayer le hero sur plusieurs bornes wifi je peux dire qu'il déconne pas mal sur les freebox a trois antennes, sur les toutes nouvelles ça marche parfaitement. Sinon sur les autres point d'accès wifi j'ai pas eu de soucis. mais je pense que c'est pas une histoire matériel mais logiciel. en faite j'ai un ordinateur dell et quand je l'ai acheté la carte wifi était en N mais quand je me connecté à ma freebox j'étais déconnecté toutes les 5 minutes (sous windows) quand j'allais sous linux pas de soucis aucune déconnexion donc je me suis dit problème de driver. il n'y avait pas de nouveaux driver pour cette carte wifi donc j'ai appelé dell et je leur ai demandé de men changer ma carte wifi par une autre (d'une autre marque bien sur !!). Ce qu'ils ont fait et depuis plus de soucis de déconnexion. (cette histoire date d'il y a 1 ans et demi). c'est pour ça que je pense que c'est un problème de driver sur le hero aussi. est ce que le composant gérant le wifi sur le hero est le même que celui du magic ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
JeP Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 Ça me rappelle la couche wifi de l'Axim x51 (WinMo de Dell), avec Odyssey (catastrophe) et le gestionnaire par défaut (bien malgré tout :) ). Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 amans tu peux pinger ton routeur depuis ton téléphone ? et ping google.com ?C'est pas un problème de passerelle ? Sinon ça marche mieux après un reboot ? un passage en mode avion ? un reset usine ? ya un utilitaire sur le hero pour faire des ping ? j'ai fais dans l'autre sens, ping du hero à partir du routeur...cf. 1er post ! idem après reboot et reset usine.... jamais testé le mode avion Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 Tu es chez quel fournisseur internet ? Le test intéressant serait aussi de trouver quelqu'un qui a un Hero dont le wifi ne pose pas de problème et de voir s'il arrive à se connecter sur ta box. Une piste à creuser peut être pour toi ...? mon access point wifi est sur mon routeur et non sur une box ! mon routeur est un pc sous openbsd.... sinon mon fai est free mais aucun rapport avec le wifi que j'utilise sinon j'ai déjà vérifié qu'il n'y ai pas de connexion fantome sur le routeur.... il a meme eu droit à un ptit reboot, chose qui ne lui était pas arrivé depuis des années ;) Lien vers le commentaire Partager sur d’autres sites More sharing options...
20Syl Posté(e) 27 août 2009 Share Posté(e) 27 août 2009 amans tu peux pinger ton routeur depuis ton téléphone ? et ping google.com ?C'est pas un problème de passerelle ? Sinon ça marche mieux après un reboot ? un passage en mode avion ? un reset usine ? ya un utilitaire sur le hero pour faire des ping ? j'ai fais dans l'autre sens' date=' ping du hero à partir du routeur...cf. 1er post ! idem après reboot et reset usine.... jamais testé le mode avion[/quote'] Connectbot ping :) Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 27 août 2009 Auteur Share Posté(e) 27 août 2009 je viens de tester après être passé en mode avion.....idem sinon avec connectbot, j'ai une m**** avec le clavier.... j'arrive pas à passer en numérique, donc pour rentrer l'ip c'est pas pratique surtout que si je fais un appui long sur le "a" pour avoir le "1" il m'écrit "a1" j'ai quand même fait un ping de www.google.com, et j'ai absolument rien, pas de timeout, rien ne s'affiche ! j'ai connecté le tel au pc et avec adb shell, j'ai fait un ping : PING 192.168.200.10 (192.168.200.10) 56(84) bytes of data. 64 bytes from 192.168.200.10: icmp_seq=1 ttl=255 time=55.2 ms 64 bytes from 192.168.200.10: icmp_seq=2 ttl=255 time=27.8 ms 64 bytes from 192.168.200.10: icmp_seq=4 ttl=255 time=13.3 ms 64 bytes from 192.168.200.10: icmp_seq=8 ttl=255 time=13.1 ms 64 bytes from 192.168.200.10: icmp_seq=9 ttl=255 time=12.8 ms 64 bytes from 192.168.200.10: icmp_seq=10 ttl=255 time=11.4 ms 64 bytes from 192.168.200.10: icmp_seq=12 ttl=255 time=13.1 ms 64 bytes from 192.168.200.10: icmp_seq=13 ttl=255 time=11.9 ms 64 bytes from 192.168.200.10: icmp_seq=14 ttl=255 time=12.2 ms donc ya quelques pertes de packets mais beaucoup moins que quand j'avais fait le test dans l'autre sens.... Lien vers le commentaire Partager sur d’autres sites More sharing options...
amans Posté(e) 3 septembre 2009 Auteur Share Posté(e) 3 septembre 2009 juste pour info, le problème a l'air d'être connu : http://code.google.com/p/android/issues/detail?id=1937 Lien vers le commentaire Partager sur d’autres sites More sharing options...
