[KERNEL] [3.4.10][CC4.7.4 - A15][AOSP/CM11] [04/08] [stable v.020 - nightly v.0xx] - AK
AK KERNELS
ONEPLUS ONE SERIES
[ CM11/AOSP ] [ 4.4.4 ]
Official SIte:
ak.hiddenbytes.org
I am not responsible for any damage to your phone.
Read before downloading or posting in the thread:
Proceed with caution if you have no experience.
[ CARACTERISTIQUES ]
Compilé avec Toolchain 4.7.3
Linux 3.4.0
Dernier patch CM 11 pour le OnepOne
Table des fréquences: 268Mhz <-> 2880Mhz
XZ Kernel Compression
Deadline, Row, Cfq Optimized
Désactivation de l'IO Stats
Slim Governor
Conservative Gpu Governor
KCAL Control
Voltage Control
Sound Control
Cpuboost Enabled
Mpd Hotplug
Intelli Hotplug
Aes and Sha1 Optimized
[ FONCTIONNE SUR CES ROMS ]
pa
slim
madhi
crdroid
cm11 nightly
nb: Ne pas flasher sur la rom stock CM11S
[ KERNEL v.011 - STABLE ]
A kernel based on CAF CM11 Bacon branch.
cm11/aosp: ak.011.onepone
[ KERNEL v.xxx - NIGHTLY ]
cm11/aosp: ak.xxx.onepone
[ INSTALL STEP-BY-STEP ]
- aller dans le recovery
- flasher le kernel stock de votre rom
- flasher le ak kernel
- reboot
- enjoy ak
- finish
[ THANKS ]
Merci à tous les devs de XDA
[ Changelog v.020b2 - nightly ]
ak.020b2.onepone
small:
Compiled with Toolchain 4.7.4 A15 Optimized
Linux 3.4.5
Latest CM11 Bacon patches - date 01/08 - changelog link
Freqs Table: 268Mhz <-> 2880Mhz
cfq default
updated conservative cpu governor
ntfs r/w support
all tcp congestions adv added
westwood tcp congestion default
added ak changelog script
a lot of fixes for linaro toolchain
added linaro kernel flags optimizations
enabled -O3 into kernel makefile
[ Changelog v.011 ]
ak.011.onepone
small:
Compiled with Toolchain 4.7.3
Linux 3.4.0
Disabled IO Stats
Slim Governor
KCAL Control
Voltage Control
Sound Control
Cpuboost Enabled
Mpd Hotplug
Intelli Hotplug
[sYNAPSE FOR AK KERNEL CONTROL]
Universal Kernel Manager (UKM) is:
Dynamic scripting and control designed and developed for Synapse app.
I have to thank you @apb_axel from the heart for the fantastic support and for the nice words expense.
Xda Link
Synapse is:
Dynamic ConfigBuilder type utility for ROMs and Kernels.
by @AndreiLux
GooglePlay Link
@AndreiLux
@Nephilim
@wisefreakz
@Grarak
@aosp
@osm0sis
@metalspring
@Hetalk
@apb_axel
[ KERNEL SETTINGS EXAMPLES ]
[ battery profile ]
intelliplug
max screen off frequency 726Mhz
cpu boost disabled
touch boost disabled
conservative gpu governor
[ performance profile ]
mpd
cpu boost enabled
slim cpu governor
msm-andreno gpu governor
XDA:DevDB Information
AK CAF Kernel for AOSP and CM11 Roms, Kernel for the ONEPLUS ONE
Contributors
ak
Kernel Special Features:
Version Information
Status: Stable
Created 2014-07-29
Last Updated 2014-07-31
Source
Modifié par Ornadyx
Par contre pourquoi il fonctionne sur cm11 et pas sur la 11s ?
Aussi le titre, c'est peut être pas nécessaire de mettre "opo" ? ni la version de kernel et de compilateur, je pense que la plupart ne savent meme pas à quoi ça correspond. Tant qu'on sait sur quelle rom et quelle version ca s'installe :)
Prochainement :
fastcharge = merged
kexec = merged
cm11 last = merged
sound control = updated
linux 3.4.10 = merged
.... next hours probably a new test kernel will be out ... and if all is ok wil be a stable release.
stay tuned
ak
La maj a l'air super !
Envoyé de mon One
Modifié par Ornadyx
[ Changelog v.020 - stable ]
ak.020.onepone
small:
Linux 3.4.10
-O3 Optimized
Universal Kernel Control Support
Synapse Enabled
Disabled IO Stats
Slim Governor
KCAL Control
Voltage Control
Sound Control
Cpuboost Enabled
Mpd Hotplug
Intelli Hotplug
Fast Charge
Kexec Hardboot - Multirom
Ntfs Support
full:[HIDE]Project name: AK KERNEL
anarkia1976 - Kernel Version: ak.020.onepone
anarkia1976 - Kernel Version: ak.020b4.onepone
anarkia1976 - ak_bacon_defconfig: enable KEXEC_HARDBOOT
KINGbabasula - oneplusone: Implement kexec-hardboot
Greg Kroah-Hartman - Linux 3.4.6 - 3.4.10
Steve Kondik - Revert "slim_msm: support non-blocking writes from slimbus MSM controller"
Ethan Chen - Revert "ASoC: wcd9xxx: Use Oppo headset detection code"
anarkia1976 - Kernel Version: ak.020b3.onepone
anarkia1976 - ak_bacon_defconfig: enable FORCE_FAST_CHARGE
anarkia1976 - ak_bacon_defconfig: fix typo related to CFQ
anarkia1976 - fastcharge: backported and adapted for OnePlus One
anarkia1976 - Sound Control: update to last Faux123 source - v3.5
Paul Reioux - Sound Control: separate locking mechanism for recording and playback
Paul Reioux - Sound Control: let register lock be dependent on different HW revisions
Paul Reioux - Sound Control: Misc clean up for newer WCD9xxx SOCs
Paul Reioux - Sound Control: expose direct register manipulations to userspace
anarkia1976 - Kernel Version: ak.020b2.onepone
anarkia1976 - ak_bacon_defconfig: set default CFQ
anarkia1976 - Revert "linux: mm: set readahead 256kb, 16kb"
anarkia1976 - Kernel Version: ak.020b1.onepone
anarkia1976 - ak_bacon_defconfig: enable NTFS Support
anarkia1976 - ak-bacon-build: compile with 4.7.4 A15 Optimized
anarkia1976 - Kernel Version: ak.014.onepone
anarkia1976 - cpufreq: conservative: set default min_sample_rate to 50mS
Amit Daniel Kachhap - cpufreq: conservative: Initialise the cpu field during conservative governor start
Michal Pecio - cpufreq: conservative: update frequency when limits are relaxed
anarkia1976 - cpufreq: conservative: convert cputime64_t to u64
anarkia1976 - cpufreq: conservative: introduced micro frequencies sync
Xiaoguang Chen - cpufreq: conservative: fix requested_freq reduction issue
Stratos Karafotis - cpufreq: conservative: First check if we can further reduce the freq
Stratos Karafotis - cpufreq: conservative: Update CPU utilization
stratosk - cpufreq: conservative: Use an inline function to evaluate freq_target
stratosk - cpufreq: conservative: Fix the logic in frequency decrease checking
stratosk - cpufreq: conservative: Fix sampling_down_factor functionality
stratosk - cpufreq: conservative: Fix typos in comments
anarkia1976 - ak_bacon_defconfig: enable all TCP_CONG_ADVANCED
anarkia1976 - Kernel Version: ak.013.onepone
Lars Greiss - toolchain: linaro: Fix a bunch of warnings and errors II
anarkia1976 - ak_bacon_defconfig: enable CC_OPTIMIZE_MORE
anarkia1976 - Kernel Version: ak.012.onepone
anarkia1976 - ak_bacon_defconfig: enable CC_OPTIMIZE_DEFAULT
anarkia1976 - Makefile: add Linaro goddess optimizations
Greg Kroah-Hartman - Linux 3.4.1 - 3.4.5
Ken Zhang - msm: display: set up vsync_retire_handler in commit thread
Jeevan Shriram - mdss: mdp: fix incorrect programming of scalar enable
Ajay Singh Parmar - msm: mdss: decouple clk ctrl and bw ctrl
Jayant Shekhar - msm: mdss: Add debug message to profile rotator times
Sagar Dharia - slim_msm: support non-blocking writes from slimbus MSM controller
anarkia1976 - Added ak-changelog.sh script
anarkia1976 - Added ak-changelog.sh script[/HIDE]
Envoyé de mon One
