Posté(e) 25 août 201412 a ★★★ Welcome To DroidKang ★★★Rom Features base is CyanogenMod 11 and CM11s PIE HOVER HALO; Ability to choose from floating window or normal window on halo notifications click; Screenshot quick trash; Power menu QS tile (simple press to go into power dialog or long press to go into reboot dialog); Power menu added in navring targets; Last app added in navring targets; Incoming call in bakground; Navigation bar dimensions; Enable or disable navigation bar; Low battery warning options; Lockscreen PIN keypad shuffler; Lock before unlock (Show sliders before secure unlock); Notification drawer custom background and transparency; Notifications row transparency; Custom clear all recents button (place it in any corner of the screen); RAM bar; Option to hide app's status bar notification icons; Status bar clock and date customization; Open source Google dialer; Volume panel configurable timeout; Screen recorder; Wakelock blocker; Media Scanner behavior on boot; Notification reminder; Notification reminder flip interval; Smart Pulldown; SlimRoms recent panel; Slim recent with option to show in left side and switch sizes (100, 85 and 70%); Slim recent add favorite mode (click on app icon in recent panel to choose as favorite); Ability to switch between recent panel styles (Stock or SlimRoms); Improved scrolling cache; Ability to Enable/Disable Smart Wake covers; Ability to disable hardware keys via nav bar settings (Only visible in devices with hardware keys and enable through overlay); Keyboard: toggle to enable/disable full screen on landscape; Keyboard: force auto rotation on IME; Keyboard: force to show always enter key; Live volume steps; Custom navbar recent long press (none, last app, screenshot, kill app, notifications panel, QS panel, power menu); Long press back to kill configurable timeout; People lookup settings; Option to enable notifications with screen on; SlimRoms Location tile with addition of labels for all states; Brightness slider in expanded notifications panel; Option to disable widgets frames on lockscreen; Lockscreen notifications; Telo Radio (Connection manager); Smart call; QS extended options (tiles per row - 3, 4 or 5 -- custom background color, custom text color, custom background pressed color, transparency); Gesture lockscreen; Pause, resume or stop downloads from notification area; DSP Manager: Center frequency param to bassboost; DSP Manager: Stereo widener effect; PA PEEK; PEEK configurable pickup timeout; PEEK configurable wake timeout; Appbar by ChameleonOS; Launch floating window from notification (long click); Launch floating window from recents panel (long click); Option to enable/disable hepatic feedback on tiles pressing; and much more ... ==============================================Installation crDroidPremière installation de la ROM crDroid:-télécharger la rom et les Gapps-booter en recovery-appliquer un Fullwipe (attention à ne pas faire un wipe de l'internal storage, vous perdrez toutes vos donnés)-flasher la Rom-flasher les Gapps- Finish!!!Mettre à jour:-télécharger la rom et les GAPPS-booter recovery-flasher la Rom-flasher les Gapps- wipe cache/dalvik cache- Finish!!!==============================================Download DroidKng RomDroidKang V6==============================================Download latest full modular PA Gapps KK 4.4.4PA 4.4.4 Gapps==============================================Changelog DroidKang v6.0initial release of DroidKang...- too much changes explore yourself :D- synced with latest CM repos- disabled scrolling cache by user requestcrDroid v5.6Added "Lockscreen Blur" under settings/lockscreenAdded Screencast app from CM11s OTA 33RKernel: mmc: core: Optimize entering HS400 modeKernel: Revert "qseecom: Add support to handle multiple app load & unload"Remove old SlimRoms smartcover wake and re-enable new CyanogenMod codesMms: fixup a extra semicolon . (android_packages_apps_Mms)Add uses-sdk tag and set min and target to 19 (android_packages_themes_Template)Add kernel version and extra label if it's a non-CM kernel (android_packages_apps_CMBugreport)InCallUI: Add initial smart cover support (android_packages_apps_InCallUI)policy: respect FLAG_TURN_SCREEN_ON flag with device flip covers (android_frameworks_base)Keyguard: add smart cover support (android_frameworks_base)audio_policy: Prevent dumping string NULL termination (android_hardware_libhardware_legacy)New BIONIC_L(Android-L) has own support for STPCPY (android_external_busybox)apns-conf.xml: add Tiscali Mobile (Italy) APNs (android_vendor_cm)Trebuchet: fix expanded desktop with GEL integration (android_packages_apps_Trebuchet)Small code-cleanup. (android_packages_apps_CMUpdater)Rename two variables to make it clear what's stored inside them. (android_packages_apps_CMUpdater)Fixed downloading incremental updates. (android_packages_apps_CMUpdater)crDroid v5.5Add support for sunlight readability enhancement (settings/display&led)msm8974: Melt faces off (android_device_oppo_msm8974-common)cmhw: Add stubs for SRE support (android_frameworks_opt_hardware)SystemUI: NavbarEditor: Fix saveKeys logic (android_frameworks_base)SystemUI: enable equalizer for Wifi display (android_frameworks_base)Add APN for Telenet when internationally roaming (MNC=206 MCC=01) (android_vendor_cm)Don't choke if IPv6 rules fail. (android_system_netd)Add ART vs Dalvik label to reports (android_packages_apps_CMBugreport)Themes: Avoid NPE when setting text in TickerView (android_frameworks_base)wifi: remove local nl80211 header (android_hardware_libhardware_legacy)New call-in/-back functions for Controller to do vendor-specific shutdown (android_hardware_ti_wpan)netd: Don't reload fw if a single fw is supported (android_system_netd)Squashed revert of SoftapControllerTI changes (android_system_netd)Revert "wpa_supplicant_8 - Hostapd: Android related changes for sockets" (android_external_wpa_supplicant_8)Add TIGO and VOX for Paraguay (android_vendor_cm)tether: tethering chooses wrong upstream when mobile_dun is required (android_frameworks_base)Use hidden API to validate APK chains (android_frameworks_base)Settings: fix Wifi/WifiAP tile inconsistency (android_packages_apps_Settings)DeskClock: restore vibrations after screen is turned off (android_packages_apps_DeskClock)SystemUI: don't show eq tile while casting (android_frameworks_base)frameworks: add ongoing notification while collecting bug report (android_frameworks_base)Settings: use ActivityManager method for requesting bug report (android_packages_apps_Settings)frameworks: allow LockPatternView to be rotated (android_frameworks_base)apns-conf: Fix Elisa EE MMS port. (android_vendor_cm)Move idmap to frameworks/base [2/2] (android_frameworks_base)Move idmap to frameworks/base [1/2] (android_frameworks_native)Lycamobile (MNC04) considered non-roaming on Vodafone (MNC01) (android_frameworks_base)Vectone/Delight (MNC07) considered non-roaming on NOS (MNC03) (android_frameworks_base)Themes: Load missing style attributes from original style (android_frameworks_base)crDroid v5.4fixed turn off HW keys completelyvideo: mdss: Sunlight readability enhancement support (supports a postprocessing mode which improves readbility in bright sunlight)updated all CM11s apps to match OTA 33Rasoc: msm: MBHC tunings forever!Themes: Load missing style attributes from original style (android_frameworks_base)Themes: Fix blurry composed icons (android_frameworks_base)Revert "vendor/cm: add CMBugReport" (android_vendor_cm)Revert "Settings: update default expanded desktop style" (android_packages_apps_Settings)Settings: remove Expanded Desktop from Power Menu if unavailable (android_packages_apps_Settings)Revert "frameworks: set default expanded desktop style" (android_frameworks_base)CMBugReport: move config parameters to xml file (android_packages_apps_CMBugreport)Refactor cards so that API card extends a base Card. (external_cyanogen_cmhomeapi)Fix bugs related to deleting CardDataImage rows. (external_cyanogen_cmhomeapi)Update README.md to include an sdk tutorial. (external_cyanogen_cmhomeapi)Add Javadocs for SDK. (external_cyanogen_cmhomeapi)Implement onDestroy handling for providers. (external_cyanogen_cmhomeapi)Monitor for any API package changes. (external_cyanogen_cmhomeapi)Add to dialer stats: track actions in the dialer to actually initiate a call (android_packages_apps_Dialer)msm8974: Disable multiple offload support (android_device_oppo_msm8974-common)frameworks:base: SystemUI: cleanup a duplicate permission (android_frameworks_base)[x86] Add missing libpci includes (android_external_powertop)Fix build for x86. Remove duplicate mcmchr from Android.mk. Other implemented in arch-x86/x86.mk (android_bionic)move the ro.buildid to a custom field on jira (android_packages_apps_CMBugreport)bluetooth: avrcp - Respond to PDU 0x16 correctly (android_packages_apps_Bluetooth)CMUpdater: Fetch changelogs for updates only if explicitly requested. (android_packages_apps_CMUpdater)CMUpdater: Switch all network requests to utilize Volley. (android_packages_apps_CMUpdater)Revert "Fix decoder EOS handling" (android_frameworks_av)audioflinger: only exchange AUDIO_SOURCE_HOTWORD when using pre-kitkat audio-policy (android_frameworks_av)Settings: Update a string. (android_packages_apps_Settings)New folder icons (ic_fso_folder.png) for CMFileManager. These new icons are meant to fit the new color scheme for the app better. Also added a much needed xxhdpi version. Change-Id: I3ef13303d3a8651d69d13826ed5c271a2799b973 (android_packages_apps_CMFileManager)ShutdownThread: set soft reboot trigger accordingly (android_frameworks_base)crDroid v5.3added Brightness control for Hardware Buttonsadden option to disable HW Buttons completely (still WIP)New folder icons for CMFileManageradvanced reboot: add soft reboot option (android_frameworks_base)bacon: Enable CONFIG_HID_SONY (Allows to use PS3 controller through OTG)fixed Headset problems hopefullyShutdownThread: set soft reboot trigger accordingly (android_frameworks_base)Fix HideIcon behavior in Folders (android_packages_apps_Trebuchet)msm8974-common: Remove unused liblisten entries (android_device_oppo_msm8974-common)msm8974-common: Sort makefile targets (android_device_oppo_msm8974-common)msm8974-common: Add Widevine proprietary libs (android_device_oppo_msm8974-common)CMBugReport: disable reporting if Xposed is installed (android_packages_apps_CMBugreport)Revert "audio:Avoid AudioTrackThread if Track creation fails" (android_frameworks_av)apns-conf.xml: update verizon apns (android_vendor_cm)msm8974: [HACK] Restore combined primary audio path (android_device_oppo_msm8974-common)hal: allow msm8610 to use same functions as msm8226/msm8974 (android_hardware_qcom_audio-caf)Themes: Make sure composed icon info is meaningful (android_frameworks_base)Themes: Fix icon filters clamping to wrong values (android_frameworks_base)CMUpdater: Create builder for UpdateInfo. Simplify codebase. (android_packages_apps_CMUpdater)CMUpdater: Handle download complete in background thread. (android_packages_apps_CMUpdater)CMUpdater: Create DownloadNotifier, simplify DownloadReceiver logic. (android_packages_apps_CMUpdater)Add back/home action to Subscription Settings Action Bar (MultiSIM) (android_packages_services_Telephony)mm-core: Remove obsolete msm7x30 OMX code (android_hardware_qcom_media-caf)hwc: rotator is not supported on msm7x27a (android_hardware_qcom_display-caf)libstagefright: Add support for custom LPA buffer size in legacy LPAPlayer (android_frameworks_av)libstagefright: Enable meta mode for 7x27a video encoder (android_frameworks_av)libstagefright: refactor Legacy LPA makefile (android_frameworks_av)display: Cover NO_IOMMU for msm7x30/msm7x27a too (android_hardware_qcom_display-caf)overlay: Allocate from MM heap as a fallback (android_hardware_qcom_display-caf)mm-video: Use multimedia heap on MSM7x30 (720p) too. (android_hardware_qcom_media-caf)media-caf: Fix building for msm7x27a (android_hardware_qcom_media-caf)Dialer: Blacklist call recording for Australia. (android_packages_apps_Dialer)Revert "bacon: use camera interface for torch" (android_device_oneplus_bacon)Added a label to the issues 'user' for user-generated bug reports 'crash' for stacktraces (android_packages_apps_CMBugreport)Wifi Country code (android_packages_apps_Settings)Added APN for Tal Iceland, ref CYAN-5026. Note that I am not on that network myself so I have not been able to verify the settings. However, they are taken from the official support site. (android_vendor_cm)Fix keyboard opening on pattern entry. (android_packages_apps_Settings)Add proximity wake flag (android_device_oppo_msm8974-common)Revert "Bacon : Add proximity check support" (android_device_oneplus_bacon)Fix NPE in dock mode. (android_packages_apps_InCallUI)ProtectedApps pattern lock for landscape mode. (android_packages_apps_Settings)Fix: Even when the list is entirely unchecked there may still be components which are still protected and need to cleared when Reset is triggered. (android_packages_apps_Settings)stagefright: Set bit_width if ENABLE_AV_ENHANCEMENTS is defined (android_frameworks_av)Fix: Sort apps before opening AppDrawer to reflect the most recent counts. (android_packages_apps_Trebuchet)SystemUI: make long pressing recent switch to last app (android_frameworks_base)Revert "QuickSettings : Register/unregister cast tile one time" (android_frameworks_base)su: Don't forcefully add the bin symlink to the installed packages (Superuser)Build fix. (android_packages_apps_Apollo)Apollo: fix a race condition when two fingers are on the screen (android_packages_apps_Apollo)Apollo: Correctly handle opening invalid files. (android_packages_apps_Apollo)crDroid v5.2input: touchscreen: Updated Touchscreen firmwareRevert "Revert "Revert "input: touch: synaptics: Reset the device when blanking display"""drivers: video: Updated support for the truly panelssu: Don't forcefully add the bin symlink to the installed packagesremoved CM11s lockscreen we try it laterfixed lockscreen notificationsfixed ARTApollo: Correctly handle opening invalid files (JIRA: BUGDUMP-1050)Apollo: fix a race condition when two fingers are on the screen (JIRA: BUGDUMP-820)crDroid v5.1Fixed CM11s Lockscreen from latest OTA 30O (Now we have a complete CM11s build with latest updates and more tweaks)added latest blobs from OTA 30OcrDroid v5Fixed "Ghost Touches and reboots"Settings: Slimrecents added ability to change background color && transparencyUpdated all CM11s apps from OTA XNPH30O (Hexo Theme, Camera "ClearImage")Fixed Battery drain due proximity sensorHOVER: A few improvementsBoardConfig.mk.template: Add TARGET_CPU_SMP (android_build)CMBugReport: more aggressive data scrubbing (android_packages_apps_CMBugreport)When reloading dynamic grid, reload restore page first. (android_packages_apps_Trebuchet)Follow normal lock screen convention - allow user to retry when creating pattern lock (android_packages_apps_Settings)sr: Use in-memory files for SOD and EOD (android_bootable_recovery-cm)libtar: Add methods for in-memory files (android_external_libtar)Fix spacing issues on devices with/without nav-bar in overview settings panel (android_packages_apps_Trebuchet)Themes: Add ability to apply color filters to composed icons (android_frameworks_base)CMBugReport: improve notifications (android_packages_apps_CMBugreport)Fix for workspace showing outline after live settings changes (android_packages_apps_Trebuchet)Fix AppInfo drop target getting cut off when search bar is off. (android_packages_apps_Trebuchet)Settings adapter should use the position and partition values (android_packages_apps_Trebuchet)Make sure ThemeConfig is non-null when loading resources (android_frameworks_base)Revert "libstagefright: Keep LOOPING/AUTO_LOOPING flag during teardown" (android_frameworks_av)Settings : Make proximity opt-in (android_packages_apps_Settings)blacklist call recording for US/EU mccs, remove sysprop flag for enabling (android_packages_apps_Dialer)Fix BOARD_RECOVERY_BLDRMSG_OFFSET CFLAG (android_bootable_recovery)Bacon : Add proximity check support (android_device_oneplus_bacon)PowerManager : Make proximity check opt-in (android_frameworks_base)Revert "msm8974: Offload all the things!" (android_device_oppo_msm8974-common)Fix for shadow folders. (android_packages_apps_Trebuchet)Fix ressource leak in getFileCrC (android_frameworks_base)Use getThemedResourcesForApplication for icons (android_packages_apps_ThemeChooser)build: Handle boot images with custom makefile properly (android_build)Fix camera usage tracking. (android_frameworks_base)Fix display of 'Dialing (waiting...)' state. (android_packages_apps_InCallUI)Handle CALL_IS_WAITING MO notification. (android_packages_services_Telephony)Themes: setUserRequired(false) when updating audibles (android_frameworks_base)Themes: Allow clearing the wallpaper and ls wallpaper (android_frameworks_base)SettingsProvider: add default overlay entry for SEND_ACTION_APP_ERROR (android_frameworks_base)vendor/cm: add CMBugReport (android_vendor_cm)Add CMBugreport to manifest (android)build: Store no_separate_recovery flag in misc_info (android_build)sr: Force format /data when wipe_media option is given (android_bootable_recovery-cm)sr: Only use overlay for MDP 5.x and cleanup a bit (android_bootable_recovery-cm)msm8974: Add debug logging services (android_device_oppo_msm8974-common)Add an option in the InCall UI to perform call recording (android_packages_apps_InCallUI)Call recording service implementation, show recordings and allow playback in call history (android_packages_apps_Dialer)Pass creation time in Call interface so that we can uniquely identify calls in call log (android_packages_services_Telephony)Clean up MSimMobileNetworkSubSettings (android_packages_services_Telephony)Port enabled network mode selection menu to MSIM classes (android_packages_services_Telephony)CMBugReport: clean up AnroidManifest.xml (android_packages_apps_CMBugreport)CMBugReport: update app name case (android_packages_apps_CMBugreport)CMBugReport: scrub device serial number and IMEI (android_packages_apps_CMBugreport)CMBugReport: update LOCAL_PACKAGE_NAME case (android_packages_apps_CMBugreport)CMBugReport: add system bug crash reporter (android_packages_apps_CMBugreport)Themes: Pass resource IDs instead of bitmaps [1/2] (android_frameworks_base)Themes: Build icon cache when applying icons (android_frameworks_base)Themes: Pass resource IDs instead of bitmaps [2/2] (android_packages_apps_ThemeChooser)audioflinger: exchange AUDIO_SOURCE_HOTWORD with AUDIO_SOURCE_VOICE_RECOGNITION for pre-kitkat blobs. (android_frameworks_av)dmesg: rework color feature, compat. with more (android_external_busybox)Specify -mcpu=cortex-a15 for krait CPU variants. (android_build)Set the card ID if updating from DataCard. (external_cyanogen_cmhomeapi)Avert confusion by renaming DataCard to CardData. (external_cyanogen_cmhomeapi)Add constructor to DataCardImage without DataCard. (external_cyanogen_cmhomeapi)Tell vold to use the fstype defined in fstab when formatting (android_bootable_recovery)fix unnecessarily slow writing of EMMC partitions (android_bootable_recovery)Touch: slot and tracking updates (android_bootable_recovery)MSimNetworkController: Quiet logspam (android_frameworks_base)MSimNetworkController: disable CHATTY logs (android_frameworks_base)Rename allow and deny strings. (Superuser)Telephony: fix tdsdma asu invalid value (android_frameworks_base)CMBugReport: add data scrubbing (android_packages_apps_CMBugreport)Revert "CardsLib : Set layer type to software when doing operations" (android_external_cardslib)ffmpeg: Add support for high resolution audio (android_external_stagefright-plugins)media: Move sample format tag to framework (android_hardware_qcom_media-caf-new)media: Move sample format tag to framework (android_hardware_qcom_media)media: Move sample format tag to framework (android_hardware_qcom_media-caf)stagefright: Improve 24-bit support (android_frameworks_av)msm8974: Don't use the motion accelerometer (android_device_oppo_msm8974-common)msm8974: Update audio policy (android_device_oppo_msm8974-common)CmHome : Make api cards unpublish on swipe (external_cyanogen_cmhomeapi)sr: Fix overlay harder (android_bootable_recovery-cm)Android: clean only objects, not the folders (android_external_busybox)hwc: don't vsync after swap in omap3_hwc_set() (android_hardware_ti_omap3)hwc: bring sanity to vsync loop code (android_hardware_ti_omap3)hwc: Fix truncation errors in scaling decision (android_hardware_ti_omap3)hwc: use proper scaler limits for OMAP3 (android_hardware_ti_omap3)hwc: Disable mdp comp if mDownscaleMode is set for external (android_hardware_qcom_display-caf)hwc: For FB target check RGB pi** availability before VG pi** (android_hardware_qcom_display-caf)Improve notification spam filter code. (android_packages_apps_Settings)Filter Notifications : Adjust string (android_frameworks_base)themechooser: decode inSampleSize prior to load wallpaper bitmap (android_packages_apps_ThemeChooser)CardsLib : Set layer type to software when doing operations (android_external_cardslib)Support a broadcast when cards are deleted. (external_cyanogen_cmhomeapi)stagefright: Fix offload fallback for 24bit (android_frameworks_av)Add undo listener parameter for if undo occurred. (1/2) (android_external_cardslib)Add undo listener parameter for if undo occurred. (2/2) (android_packages_apps_CMHome)Fix DataCard publish and unpublish issues. (external_cyanogen_cmhomeapi)libtar: Fix hardlink extract (android_external_libtar)libtar: Various bug fixes and enhancements (android_external_libtar)Keyguard: Add option to scramble pin layout when unlocking (2/2). (android_frameworks_base)Add scramble pin layout global setting. (android_frameworks_base)Settings: Add option to scramble pin layout when unlocking (1/2). (android_packages_apps_Settings)Move stream close into it's own try/catch. (external_cyanogen_cmhomeapi)CmHome : Add updates for apiCard (external_cyanogen_cmhomeapi)Cache images using MD5 hash instead of random UUID (external_cyanogen_cmhomeapi)Fix bug so new cards are built with builder. (external_cyanogen_cmhomeapi)Settings: Fix the failing strings (android_packages_apps_Settings)properties: RIL sends only one RIL_UNSOL_CALL_RING, so set call_ring.multiple to false (android_device_oppo_msm8974-common)Ion : Add ability to disable transform cache (ion)Renamed output zip file; use apps cache dir; delete file once uploaded. Better error handling and file/stream cleanup. (android_packages_apps_CMBugreport)Dialer: Handle "Unknown" and null numbers when adding to blacklist. (android_packages_apps_Dialer)Add column for tracking when a theme was installed (android_frameworks_base)SysUI: Fix QS tiles cutting off in the ribbon (android_frameworks_base)hal: Add/remove speaker protection usecase to/from global list (android_hardware_qcom_audio-caf)hal: Speaker protection pre-emption fixes (android_hardware_qcom_audio-caf)hal: add the stream to uc_info for speaker protection enablement (android_hardware_qcom_audio-caf)libstagefright: Decrease reference count before deleting AudioPlayer (android_frameworks_av)RTSP: Correct the data type in the check (android_frameworks_av)midi audio: allow midi restart even upon stop state (android_frameworks_av)HLS: Queue discontinuity only for the first block (android_frameworks_av)hwc: Configure MDP with updated crop and whf for PTOR layers (android_hardware_qcom_display-caf-new)hwc: Enable PTOR feature for split display (android_hardware_qcom_display-caf-new)msm8974: Use the normal speaker output (android_device_oppo_msm8974-common)msm8974: Improve thermal mitigation (android_device_oppo_msm8974-common)msm8974: Audio tunings (android_device_oppo_msm8974-common)frameworks: base: grammar fixes (android_frameworks_base)BluetoothExt: Fix BluetoothFtpService shutdown (android_packages_apps_BluetoothExt)bacon: Remove duplicate mixer path defaults (android_device_oneplus_bacon)icu4c: Add Luxembourgish ICU files (converted from CLDR v26) (android_external_icu4c)icu4c: Refactor additional locales (android_external_icu4c) Sources: XDA Modifié 1 septembre 201412 a par DroidO
Posté(e) 29 août 201412 a version 5.6 en ligne. crDroid v5.6Added "Lockscreen Blur" under settings/lockscreenAdded Screencast app from CM11s OTA 33RKernel: mmc: core: Optimize entering HS400 modeKernel: Revert "qseecom: Add support to handle multiple app load & unload"Remove old SlimRoms smartcover wake and re-enable new CyanogenMod codesMms: fixup a extra semicolon . (android_packages_apps_Mms)Add uses-sdk tag and set min and target to 19 (android_packages_themes_Template)Add kernel version and extra label if it's a non-CM kernel (android_packages_apps_CMBugreport)InCallUI: Add initial smart cover support (android_packages_apps_InCallUI)policy: respect FLAG_TURN_SCREEN_ON flag with device flip covers (android_frameworks_base)Keyguard: add smart cover support (android_frameworks_base)audio_policy: Prevent dumping string NULL termination (android_hardware_libhardware_legacy)New BIONIC_L(Android-L) has own support for STPCPY (android_external_busybox)apns-conf.xml: add Tiscali Mobile (Italy) APNs (android_vendor_cm)Trebuchet: fix expanded desktop with GEL integration (android_packages_apps_Trebuchet)Small code-cleanup. (android_packages_apps_CMUpdater)Rename two variables to make it clear what's stored inside them. (android_packages_apps_CMUpdater)Fixed downloading incremental updates. (android_packages_apps_CMUpdater)
Posté(e) 30 août 201412 a Nouvelle build [ROM][KK4.4.4][HALO][PIE][CM11s] ★★★ DroidKang v6.0 ★★★ [HOVER][PEEK][30/08][CM11] Changelog DroidKang v6.0initial release of DroidKang...- too much changes explore yourself :D- synced with latest CM repos- disabled scrolling cache by user request
Posté(e) 1 septembre 201412 a Auteur Merci a toi, topic mis a jour! La rom s'est fait peau neuve, ta tester?
