Elreydelaplaya Posté(e) 14 septembre 2014 Share Posté(e) 14 septembre 2014 (modifié) Do a NANDROID BACKUP of your current ROM first!Please disable Xposed completely before installing the ROM.Install over firmware Stock Retail EU to avoid problems unrelated to the ROM.Features - Based JB 4.1.2 Retail EU- Kernel Omar-Avelar (M9) Source here- Debloated APKs- Deodex- ZipAlign- Pre-Rooted with SuperSU v2.01 of Chainfire- BusyBox v1.20.2- RAM Optimized- Tweaks Wifi y 3G- Tweaks to Kernel- Tweaks Battery Saver- Blocker ads (hosts file)- GPS optimized- News Aplications Installed Automatic ZipAlign (better use RAM)- Curves of low screen brightness (In automatic, for battery saver)- Status bar style Lollipop- Curtain Notifications style Lollipop- Navegation bar smaller (38 dpi)- Circle Battery mod with % and animation (style CyanogenMod)- Lockscreen (style Lollipop)- Keys Volumen change song- Power Menú Extended (Reboot and Recovery)- APN's updated (if one does not work or missing please post the settings for it to be fixed in a future release)- Notification LED blinks faster- Nova Launcher (Default)- Galery (Modified)- Camera Stock (Modified aesthetics, by default is activated by long press the dedicated button)- Phone and Contacts (aesthetically modified)- Mensajería SMS/MMS Stock (Modified aesthetically and limit messages by conversation 9998)- Google Keyboard with Material Desing (Google Keyboard Settings -> Appearance & layouts -> Theme -> Material Dark)- Emojis fully functional- Calendar Google- Clock/Alarm 4.4 (aesthetically modified)- Calculator CyanogenMod (aesthetically modified)- Sound Recorder (includes shortcut)- Movie Studio- DLNA 100% funtional- Google Play Music + EQ (Customizable)- Browser Stock (aesthetically modified)- Flash Player 11.1.115.20- E-mail client with Exchange (replacing Gmail)- Play Store (Last version)- YouTube (Last version, share with Chromecast y Smart TV)- ES File Explorer- QuickOffice- Maps- Trickster MOD (if you do not know how to use it, only use the cpu to control states and temperatures)- Greenify (applications to hibernate and not left in the background consuming battery / cpu)- Fonts Android Lollipop- Bootanimation Android Wear (better than Lollipop)- Sounds KitKat + CM11 + Lollipop- And many things more...-------------------------------------------------------------------------------------------------------------------------------------Useful InformationIf you have any problems with the Play Store, erase data for the following applications: * Google Play Store* Google Services Framework* Google Play ServicesChange Keyboard to Material Desing:Google Keyboard Settings -> Advanced settings -> Color scheme -> Material-------------------------------------------------------------------------------------------------------------------------------------Screenshots KTR-ROM v2.5 Screenshots (KTR-ROM v2.5 + TogglesKTR v2.5) ------------------------------------------------------------------------------------------------------------------------------------- Quote: Important- Before installation, it is recommended to make a nandroid (backup).- We recommend using TWRP (2.8.0.1), which is used to test the ROM and Flasheables. Guide first Installation of ROM - Download ROM and copy to sd- Enter in TWRP or CWM- Wipes required: data, system, cache y dalvik*In CWM mount system must format before (Mount and storage -> Mount system)- Install KTR-ROM-v2.x.zip- Reboot- Configure, wait 2 o 3 minutes, power off y power on- Enjoy! Quote: Recommendation on first startup and configuration of the ROM- In the first startup configuration if I want to use wifi, I recommend you do the first 2 quick steps before you connect 3g, which appears to them to connect to wifi. Tilden "Show Advanced Options" and put IP settings "Automatic" so that they are properly connected wifi (if left on DHCP you may tell them "unstable Connection Disabled ....") and can continue normally configured with your account gmail.All this shows that no back buttons, Start ...- Back in the "Desktop" still leave a cell 5min. to stabilize the ROM, I restarted and it can be used normally. Installation Guide if you already have the ROM (can be installed above the v1.xx) - Download ROM and copy to sd- Enter in TWRP or CWM- Wipes required: system, cache y dalvik*In CWM mount system must format before (Mount and storage -> Mount system)- Install KTR-ROM-v2.x.zip- Reboot- After the ROM started, leave 2 to 3 minutes at rest, power off y power on- Enjoy!Installation Guide of TogglesOnly after starting to install the ROM at least once, otherwise it'll not notice and navigation bar will appear.- Download Toggles and copy to sd- Enter in TWRP or CWM- Wipes required: cache y dalvik- Install TogglesKTR-v2.x.zip- Reboot- Enjoy!- Your configuration is done from the TogglesKTR application.-------------------------------------------------------------------------------------------------------------------------------------Downloads KTR-ROM v2.5: http://www.mediafire.com/download/9v...R-ROM-v2.5.zipMD5: 089CB17FA91B450F4942ED0B5347F6E6SHA-1: E722B7302CA520EB5F3E04252CD0D12DB08E052ETogglesKTR v2.5: http://www.mediafire.com/download/7j...esKTR-v2.5.zipMD5: BFDD52AE1DE60A424786AB5874101DCFSHA-1: B55878EE01E5B4BB7C4D186E5AB019F290B1B067 * Please check the MD5 of the zip to verify that it has been downloaded correctly and avoid problems outside the ROM.They can use the MultiHasher tool to check. -------------------------------------------------------------------------------------------------------------------------------------Changelog KTR-ROM v2.5 - Nov-26-2014: Revert Messenger to SMS Stock. Updated APKs (Google Services Play, Play Music, Maps). KTR-ROM v2.4 - Nov-20-2014: Small tweaks to design. Updated APKs (Greenify, Play Store, Youtube, ES File Explorer, Trickster MOD, Google Keyboard, Calendar, Google Services Play, Play Music). Apk SMS Stock replaced by Messenger of Google. Encoding SMS Fix (only apk Stock).TogglesKTR v2.5 - Nov-20-2014: Updated some icons. KTR-ROM v2.3 - Oct-25-2014: Updated more icons Android Lollipop. Tweaks to the design of some APKs (Contacts, Phone, Clock, Camera, etc). Updated APKs (Google Play Music, Nova Launcher, Maps, Google Search, Google Play Services). Keyboard reverted to the previous version (now not crash to put it in horizontal). Updated sounds of system. GPS Settings optimized and generic.KTR-ROM v2.2 - Oct-19-2014: Kernel M9 Omar-Avelar. Updated APKs (New Keyboard Android Lolillop, ES File Explorer, Greenify, Play Store, Google Play Services, Maps, etc). Added APK Street View. More modifications to the kernel and Tweaks. Some fix in design. New Wallpaper Android Lollilop for default. Fix APK Sound Recorder.TogglesKTR v2.4 - Oct-06-2014: Fix position of text "EMERGENCY CALLS ONLY".KTR-ROM v2.1 - Sep-23-2014: New Kernel Omar-Avelar Sep-22-2014. Updated APKs (Greenify, etc). More modifications to the kernel and Tweaks. Some fix in design.TogglesKTR v2.3 - Sep-23-2014: Littles fixes in desing.TogglesKTR v2.2 - Sep-22-2014: Updated some icons. Design changes. Need more work...TogglesKTR v2.1 - Sep-20-2014: Little fixes in desing. Slider for manual brightness. Need more work, no have time.KTR-ROM v2.0 - Sep-13-2014: First Version.TogglesKTR v2.0 - Sep-13-2014: First Version.-------------------------------------------------------------------------------------------------------------------------------------Credits Omar-AvelarChainfireFourOne82arman68hypophysisshaftenbergHazouHip HopLinux CommunityUsers (Grupo Android, Google+, XDA)Beta Testers of Google+ Community-------------------------------------------------------------------------------------------------------------------------------------Spanish Support on the official post: http://www.grupoandroid.com/topic/10...ptiembre-2014/Comunnity Google+ in Spanish: https://plus.google.com/u/0/b/100201...81501008883785------------------------------------------------------------------------------------------------------------------------------------- Optional ModsWe recommend using TWRP v2.8.0.1Before installation, it is recommended to make a nandroid (backup).Mods for KTR-ROM Stock Motorola Screen brightness: http://www.mediafire.com/download/y2...k-v2.5-KTR.zipLow Brightness Screen (Default KTR-ROM v2.5): http://www.mediafire.com/download/x3...d-v2.5-KTR.zipMusic Widget LockScreen with background of the cover disk (type Stock): http://www.mediafire.com/download/o4...K-v2.5-KTR.zipWidget LockScreen Music Transparent (Default KTR-ROM v2.5): http://www.mediafire.com/download/h7...D-v2.5-KTR.zip * Instructions: Wipe cache/dalvik, Flash and restart. -------------------------------------------------------------------------------------------------------------------------------------Recoverys TWRP v2.6.1.1: http://www.mediafire.com/download/8f...-RepackKTR.zipTWRP v2.6.3.0: http://www.mediafire.com/download/4w...-RepackKTR.zip Vey slow, Recommended if you have a problem with other versions.TWRP v2.8.0.1: http://www.mediafire.com/download/l5...-RepackKTR.zip Recommended!CWM (No Touch) v6.0.3.6: http://www.mediafire.com/download/pb...-RepackKTR.zipCWM (Touch) v6.0.1.9: http://www.mediafire.com/download/6f...-RepackKTR.zipCWM (No Touch) v6.0.5.0: http://www.mediafire.com/download/vz...-RepackKTR.zipCWM (No Touch) v6.0.5.1: http://www.mediafire.com/download/nb...-RepackKTR.zip * Instructions: Wipe cache/dalvik, Flash and restart.If you have any problems with the zip can install via fastboot: http://forum.xda-developers.com/show....php?t=2281224 -------------------------------------------------------------------------------------------------------------------------------------Kernels M7 Omar-Avelar (Default KTR-ROM v1.0.0 to v1.0.4): http://www.mediafire.com/download/ce...-RepackKTR.zipM9 Omar-Avelar (Default in KTR-ROM v1.0.8, v1.0.9, v1.11, v1.14, v2.0, v2.2 and v2.3): http://www.mediafire.com/download/cr...-RepackKTR.zip04-May-2014 Omar-Avelar (Default in KTR-ROM v1.0.5 and v1.0.6): http://www.mediafire.com/download/26...-RepackKTR.zip12-May-2014 Omar-Avelar: http://www.mediafire.com/download/d9...-RepackKTR.zip14-May-2014 Omar-Avelar: http://www.mediafire.com/download/wm...-RepackKTR.zip21-May-2014 Omar-Avelar (Default in KTR-ROM v1.0.7): http://www.mediafire.com/download/tc...-RepackKTR.zip03-Jun-2014 Omar-Avelar: http://www.mediafire.com/download/ax...-RepackKTR.zip10-Jun-2014 Omar-Avelar: http://www.mediafire.com/download/59...-RepackKTR.zip11-Jul-2014 Omar-Avelar: http://www.mediafire.com/download/yd...-RepackKTR.zip16-Jul-2014 Omar-Avelar (Default in KTR-ROM v1.10): http://www.mediafire.com/download/h4...-RepackKTR.zip16-Sep-2014 Omar-Avelar: http://www.mediafire.com/download/cc...-RepackKTR.zip17-Sep-2014 Omar-Avelar: http://www.mediafire.com/download/iv...-RepackKTR.zip22-Sep-2014 Omar-Avelar (Default in KTR-ROM v2.1): http://www.mediafire.com/download/c7...-RepackKTR.zip * Instructions: Wipe cache/dalvik, Flash and restart. -------------------------------------------------------------------------------------------------------------------------------------Bootanimations Moto X: http://www.mediafire.com/download/wl...-RepackKTR.zipGoogle Edition (Nexus): http://www.mediafire.com/download/1a...-RepackKTR.zipDroid DNA (with sound): http://www.mediafire.com/download/mb...-RepackKTR.zipDroid ULTRA (with sound): http://www.mediafire.com/download/m8...-RepackKTR.zipStock RAZR i: http://www.mediafire.com/download/ye...-RepackKTR.zipMotorola World Cup 2014: http://www.mediafire.com/download/d3...Cup2014KTR.zipAndroid L Preview: http://www.mediafire.com/download/rd...ndroidLKTR.zip * Instructions: Wipe cache/dalvik, Flash and restart. -------------------------------------------------------------------------------------------------------------------------------------Changelog Nov-26-2014: Added Mods for KTR-ROM v2.5. Nov-20-2014: Added Mods for KTR-ROM v2.4. Added CWM 6.0.5.1. Oct-20-2014: Added Mods for KTR-ROM v2.2.Sep-28-2014: Fixed Mod "Music Widget" LockScreen with background of the cover disk (type Stock).Sep-23-2014: Added Mods for KTR-ROM v2.1. New Kernels. New Recoverys. ------------------------------------------------------------------------------------------------------------------------------------ Source : XDA forum Modifié 26 novembre 2014 par Elreydelaplaya Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alexcisse10 Posté(e) 20 septembre 2014 Share Posté(e) 20 septembre 2014 (modifié) KTR est vraiment la ROM la plus fluide et esthétique sur Razr i ! Mais il y a quelques trucs qui ne sont pas traduits en français mais bon. Modifié 20 septembre 2014 par alexcisse10 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elreydelaplaya Posté(e) 20 septembre 2014 Auteur Share Posté(e) 20 septembre 2014 Celle la est vraiment très réussie ! Je tourne avec depuis sa sortie et c est de la bombe . J ai juste dû installer le clavier Android L car il n était pas dans la ROM ( oubli de la part de kreator ou bug ? ). Bref je la recommande a tout le monde : stable, fluide et belle ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le_Poilu Posté(e) 22 septembre 2014 Share Posté(e) 22 septembre 2014 Est-ce qu'on peut appliquer un SD swap sur cette ROM ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elreydelaplaya Posté(e) 22 septembre 2014 Auteur Share Posté(e) 22 septembre 2014 Salut , Je n'ai pas teste car je me sers de foldermount qui permet de linker les dossiers de ton choix de la sd interne vers l'externe. Après ça vaux le coup de demander a kreator sur le topic de la ROM sur xda Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Le_Poilu Posté(e) 22 septembre 2014 Share Posté(e) 22 septembre 2014 C'est ce que j'ai fait. Foldermount ça compense mais c'est pas aussi efficace. Et ça ne permet pas de récupérer le contenu de la SDinterne comme mémoire interne du téléphone. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elreydelaplaya Posté(e) 22 septembre 2014 Auteur Share Posté(e) 22 septembre 2014 Entièrement d'accord ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Green Posté(e) 23 septembre 2014 Share Posté(e) 23 septembre 2014 Salut, je reviens vers mon vieux RAZRI..mais petit soucis, la data ne fonctionne plus (j'ai vérifier les APN c'est bon). Je suis sous KTR-ROM. Je pense que j'ai merdé il y quelque temps en repassant en ICS. Bref... J'aurai besoin d'un nandroid backup pour être sur qu'il ne s'agisse pas d'un problème HARDWARE (genre puce 3G morte)... Quelqu'un aurait la gentillesse de me fournir ca ? (attention à vos données perso: si possible faire un data/fact reset avant le nandroid) Ca demande un peu de temps je le sais (faire une sauvegarde, faire un reset, une autre sauvegarde et me l'uploader)... Mais je pense que c'est ma solution !! Merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alexcisse10 Posté(e) 23 septembre 2014 Share Posté(e) 23 septembre 2014 Moi je me sert de celle-là mais je ne sais pas si tu cherches quelque chose du genre ? : https://play.google.com/store/apps/details?id=mobi.infolife.appbackup Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elreydelaplaya Posté(e) 21 octobre 2014 Auteur Share Posté(e) 21 octobre 2014 Salut, Nouvelle version 2.2 de cette superbe ROM. Corrige les petits pb de la 2.0 et pour l'instant, je n'ai eu aucuns soucis ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ghost25320 Posté(e) 30 octobre 2014 Share Posté(e) 30 octobre 2014 Salut, j'ai essayé de l'installé mais je trouve pas la Rom sur la carte sd dans CMW, est ce que c'est parce que quand je la télécharge c'est pas un fichier zip alors que dans les instructions je dois install un zip ?Merci d'avance Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Elreydelaplaya Posté(e) 30 octobre 2014 Auteur Share Posté(e) 30 octobre 2014 (modifié) Comment tu fais pour ne pas la télécharger en .zip ??? Vu que dans les liens c'est du format .zip ?? Sinon version 2.3 qui est la version finale dispo sur le 1er post. Les nouvelles releases seront a base de kitkat normalement. Modifié 30 octobre 2014 par Elreydelaplaya Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ghost25320 Posté(e) 30 octobre 2014 Share Posté(e) 30 octobre 2014 Ok je test avec la 2.3 ;) Hm je sais pas ça m'a téléchargé un fichier nommé KTR-ROMv2.2-IS-OLD-PLEASE-DOWNLOAD-v2 et le type de fichier est "Fichier 3" bizarre Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ghost25320 Posté(e) 30 octobre 2014 Share Posté(e) 30 octobre 2014 Niquel installée sans soucis, je vais tester tout ça ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nolaanj Posté(e) 23 novembre 2014 Share Posté(e) 23 novembre 2014 Sujet à édit: la 2.4 est sortie le 20, peu de modifs, mais bon, je pense que c'est quand même nécessaire ! http://forum.xda-developers.com/razr-i/development/jellymaterial-ktr-rom-v2-0-togglesktr-t2875716 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
hazote Posté(e) 18 juillet 2015 Share Posté(e) 18 juillet 2015 (modifié) salut, petit deterrage: je viens d'installer la rom, suis sous free et j'ai pas internet ! :/ ca vous le fait ? bon j'ai reglé manuellement, ca a l'air de marcher. de ce que je vois, pour l'instant ca ma l'air encore plus fluide que ATOM Modifié 18 juillet 2015 par hazote Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Burn2 Posté(e) 20 juillet 2015 Share Posté(e) 20 juillet 2015 Bonjour, vu que cette rom est sous android 4.1, tu aurais plutôt intérêt d'essayer les roms sous android 4.4.... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
