Mouskitoo Posté(e) 20 octobre 2014 Share Posté(e) 20 octobre 2014 (modifié) The Unified Android Toolkit brings together all the Nexus and Samsung Toolkits and supports a multitude of Nexus and Samsung devices. There is also an option at startup to run a Basic Android Toolkit which any Android device can use to install drivers, make app backups, install apk files, reboot the device into different modes and run a command prompt for manual input. Quote: SUPPORTED MODELSINTERNATIONAL MODEL GSM [sM-G900H]INTERNATIONAL MODEL LTE [sM-G900F]INTERNATIONAL MODEL LTE-A [sM-G900M]US SPRINT LTE MODEL [sM-G900P]US TMOBILE LTE MODEL [sM-G900T]CANADA LTE MODEL [sM-G900W8] FUNCTIONS OF UNIFIED ANDROID TOOLKIT* Install correct adb/fastboot drivers automatically on Windows xp/vista/7/8 32bit+64bit* Backup/Restore a single package or all apps, user data and Internal Storage* Backup your data from selectable folders [internal or external storage] to your PC for a Full Safe backup of data* Unlock/Re-Lock your Bootloader [Nexus modules]* Various Root options using insecure boot image or custom recovery* 1-Click For All to Unlock, Root, Rename the Restore Files and install busybox [Nexus modules]* ALLINONE to flash custom Recovery Root, Rename the Restore Files and install busybox [samsung modules]* Fix “Superuser/SuperSU has stopped” message after rooting [samsung modules]* Perform a FULL NANDROID Backup of your system (Boot, Cache, Data, Recovery and System) via adb and save in Custom Recovery format on your PC which can be Restored via CWM Recovery [if insecure boot image available]* Pull /data and /system folders, compress to a .tar file and save to your PC [if insecure boot image available]* Dump selected Phone Partitions, compress to a .zip file with md5 and save to your PC [if insecure boot image available]* Install BusyBox on your device * Install Samsung Knox notification disabler on your device [samsung modules]* Install Root checker on your device [to be added to the Nexus modules]* Extras, Tips and Tricks section with downloadable device user guide * Auto Update ToolKit to latest available version at startup [PRO ONLY FEATURE]* Check for latest versions of Superuser [root] and custom Recovery images [PRO ONLY FEATURE]* Program up to 10 Quickpick slots and run them very quickly [PRO ONLY FEATURE]* Mods section to automatically perform certain tasks on your phone* Download Stock Firmware Image for extracting and flashing* Check md5 of stock image to make sure downloaded file isn’t corrupted before flashing [Nexus modules]* Flash Custom Recovery or Stock Firmware Image to device* Rename the Recovery Restore File present on some Stock Roms* Boot into CWM Touch, TWRP or Stock Recovery without Flashing it [Nexus modules]* Boot or Flash .img Files directly from your PC [Nexus modules]* Install a single apk or multiple apk’s to your device* Push Files from your PC to your device* Pull Files from your device to your PC* Dump selected LogCat buffers to your PC* Dump BugReport to your PC* Set Files Permissions on your device* Open new Command Prompt for manual input* Reboot device to various Modes automatically* Display Important Information about your device* Display various Help and Information screens and save a screenshot to your pc/send to default printer* Many many more features————————————————————–Supported devices and latest supported builds *HERE* ————————————————————–--------------------------------------------------------------DOWNLOAD THE SKIPSOFT UNIFIED ANDROID TOOLKIT *HERE* (FROM SKIPSOFT.NET)NOTE2: As the exe files are not Digitally Signed with a Microsoft Certificate they ‘may’ get picked up as potentially harmful by Antivirus Programs and deleted on first run. If this happens restore the file and exclude it from future scans to use it. This seems to happen mostly on AVG Free and Norton which is why I switched to BitDefender which is much better.Credits: ChainsDD for Superuser, Chainfire for SuperSU, koush and the clockworkmod team for cwm and the universal driver pack, 1wayjonny for the adb/fastboot driver pack, Adam Lange for all his support and help with the insecure kernels, Viperboy for the Knox Disabler app, Stephen Erickson for the BusyBox installer app, BurrowsApps for the Root Checker app, fOmey for TWRP for the Galaxy Gear--------------------------------------------------------------WHAT IS THE DIFFERENCE BETWEEN PUBLIC (FREE) AND PROFESSIONAL (DONATE) VERSIONS?THE PUBLIC VERSION OF THE TOOLKIT INCLUDES EVERYTHING YOU COULD NEED TO MANIPULATE YOUR DEVICE. NO MAIN FUNCTIONS ARE RESTRICTED.ACTIVATING THE PROFESSIONAL VERSION ADDS THE MOST USEFUL FUNCTION IN THE TOOLKIT, THE ABILITY TO CHECK FOR ‘AUTO UPDATES’ DIRECTLY VIA THE TOOLKIT AND HAVE THEM PUSHED TO YOUR PC RIGHT AWAY AS SOON AS THEY ARE UPLOADED WITHOUT NEEDING TO DOWNLOAD THE WHOLE TOOLKIT EVERY TIME. YOU WILL ALWAYS HAVE THE LATEST VERSION AS SOON AS IT IS MADE AVAILABLE. THIS MEANS SMALLER UPDATES CAN BE SENT OUT MORE FREQUENTLY, SUCH AS ADDING A SINGLE FUNCTION, FIXING A BUG OR ADDING COMPATIBILITY FOR A SINGLE CARRIER. THE SMALLER UPDATES WILL BE COMPILED AND RELEASED TO THE XDA COMMUNITY AS A FULL (PUBLIC) DOWNLOAD VERSION SO PROFESSIONAL VERSIONS ARE ALWAYS UPDATED SOONER.THE PRO VERSION ALSO ADDS THE ABILITY TO CHECK FOR THE LATEST VERSION OF SUPERUSER AND RECOVERY FILES AND DOWNLOAD THEM DIRECTLY TO THE TOOLKIT.THE ‘QUICK PICKS’ SECTION[/b] ALLOWS YOU TO PROGRAM UPTO 10 SLOTS WITH TASKS THAT YOU MAY PERFORM ON A REGULAR BASIS OR JUST WANT TO KEEP A SET OF TASKS IN 1 PLACE. THEN JUST SELECT THE SLOT AND IT WILL REMEMBER ALL YOUR SETTINGS FOR THAT TASK AND RUN IT.IF YOU FIND THIS PROGRAM USEFUL PLEASE CONSIDER DONATING TO YOUR CHOSEN DEVICE TO GET AN ACTIVATION CODE FOR THE PRO VERSION. YOU WILL FIND THE PRO FEATURES VERY USEFUL, GET UPDATES DIRECTLY FROM THE PROGRAM AND SUPPORT FUTURE DEVELOPMENT. WITHOUT DONATIONS DEVELOPMENT WILL NOT BE ABLE TO CONTINUE.AUTO REPLY LINKS FOR PAYPAL TO GET A CODE INSTANTLY CAN BE FOUND AT http://goo.gl/nyGqv--------------------------------------------------------------2. USING THE UNIFIED ANDROID TOOLKITWhen starting the Toolkit you will first be asked which device you want to work with. The basic Toolkit files are included in the full install package but if you select a device then the working folders will be created and the device files downloaded. Once the files have been extracted the Toolkit will ask if you want to check if an Update is available (for pro users to download/install). If you type ‘no’ then you will be taken to the Model/Build selection screen where you can do a number of things:Type ’00' to enter your activation code and enable pro features, ‘i’ will take you to the Information and Help Section, ‘a’ will give you information on how to add support for a new build, ’99' will take you to the Basic Toolkit for quick use or if you do not have a supported device and want to perform general android tasks.Supported builds are listed in the Model/Build selection screen and typing the associated number (i.e. 11) will download needed boot and recovery files (stock and custom recovery) then check for and download the latest custom recovery and superuser files available (pro versions only), verify all the files and start the Main Menu. You can now use all the functions and tools the Android Toolkit offers.The Information section which you can get to from the Model Selection screen or from the Main Menu has a wealth of help and frequently asked questions. If you need help then please look there first before asking questions in the thread.--------------------------------------------------------------USEFUL INFORMATIONEnable Developer options for usb debuggingGo to Settings, System section, About device and tap on 'Build number' 7 times until it says you are now a developer. You can now go to Settings, System section, Developer options and enable USB debug.How to get into Recovery Mode1. Unplug the USB cable.2. Shut down the phone.3. Hold down the 'HOME' + 'VOLUME UP' buttons and press the 'POWER' button for about 5 seconds to enter Recovery Mode.How to get into Download Mode (For Odin)1. Unplug the USB cable.2. Shut down the phone.3. Hold down the 'HOME' + 'VOLUME DOWN' buttons and press the 'POWER' button for about 2 seconds until a WARNING! Screen appears. Press the 'VOLUME UP' button to enter Download Mode.--------------------------------------------------------------ChangeLogUnified Android ToolKit v1.2.7 [Galaxy S5 V1.0.0] 16th April 2014+First version of Samsung Galaxy S5 ToolKit Module released -------------------------------------------------------------- *DISCLAIMER*I take no responsibility for any fault or damage caused by any procedures within this guide. No warranties of any kind are given. Modifié 20 octobre 2014 par Kidseb12 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
ichigogreg Posté(e) 23 octobre 2014 Share Posté(e) 23 octobre 2014 Hey salut, sans paraître rabat joie, en Français ça me semblerais mieux, on est quand même en France et beaucoup de gens ne comprenne rien à l'Anglais... 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MuayX10 Posté(e) 24 octobre 2014 Share Posté(e) 24 octobre 2014 Bonjour Kidseb12 En phase avec ichigogreg, surtout que cela a l'air d'être sympa, mais quand même complexe Essaye de traduire avec google traduction(ce sera toujours mieux B), que tout en anglais) Merci pour ton poste interressant Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
MuayX10 Posté(e) 30 octobre 2014 Share Posté(e) 30 octobre 2014 (modifié) :P Merci Google Traduction :P La boîte à outils Android unifié regroupe l'ensemble des Nexus et Samsung Outils et prend en charge une multitude de dispositifs Nexus et Samsung. Il ya aussi une option au démarrage pour lancer une boîte à outils Android de base qui tout dispositif Android peut utiliser pour installer les pilotes, assurez-app sauvegardes, installer des fichiers APK, redémarrez l'appareil dans différents modes et exécuter une invite de commande pour la saisie manuelle. Citation: Modèles pris en charge INTERNATIONAL Modèle GSM [sM-G900H] INTERNATIONAL Modèle LTE [sM-G900F] INTERNATIONAL Modèle LTE-A [sM-G900M] Américain Sprint LTE MODÈLE [sM-G900P] US TMOBILE LTE MODÈLE [sM-G900T] CANADA LTE MODÈLE [sM-G900W8] FONCTIONS DES OUTILS ANDROID UNIFIED * Installez les pilotes corrects adb / fastboot automatiquement sur XP / Vista / 7/8 32 bits de Windows 64 bits + * Backup / Restore un seul paquet ou toutes les applications, les données de l'utilisateur et de stockage interne * Sauvegardez vos données à partir des dossiers sélectionnés [de stockage interne ou externe] sur votre PC pour une sauvegarde complète sécurité des données * Unlock / Re-Verrouillez votre Bootloader [modules Nexus] * Diverses options de root en utilisant l'image de démarrage d'insécurité ou de récupération personnalisée * 1-Click For All to Unlock, Root, renommer les fichiers de restauration et installer busybox [modules Nexus] * ALLINONE à clignoter coutume récupération Root, renommer les fichiers de restauration et installer busybox [modules Samsung] * Fix "super-utilisateur / SuperSU a cessé de" message après l'enracinement [modules Samsung] * Effectuer une sauvegarde complète de votre système Nandroid (Boot, cache, données, la récupération et système) via adb et enregistrer au format de récupération personnalisé sur votre PC qui peuvent être restaurées via CWM Recovery [si l'image de démarrage insécurité disponible] * Pull / données et / dossiers système, compresser dans un fichier .tar et l'enregistrer sur votre PC [si l'image de démarrage insécurité disponible] * Dump choisi partitions téléphoniques, compresser un fichier .zip avec md5 et enregistrer sur votre PC [si l'image de démarrage insécurité disponible] * Installez BusyBox sur votre appareil * Installez Samsung Knox notification neutralisation sur votre appareil [modules Samsung] * Installez racine pion sur votre appareil [à ajouter aux modules de Nexus] * Section Extras, Trucs et astuces avec guide d'utilisation de l'appareil téléchargeable * Mise à jour automatique ToolKit à la dernière version disponible au démarrage [fonction uniquement PRO] * Vérifiez les dernières versions de super-utilisateur [root] et images de récupération personnalisé [MÉTRAGES SEULEMENT PRO] * Programmez jusqu'à 10 emplacements Quickpick et de les exécuter très rapidement [DOSSIER Pro uniquement] * Section Mods pour effectuer automatiquement certaines tâches sur votre téléphone * Télécharger firmware stock sur la photo pour l'extraction et le clignotant * Vérifiez md5 image de assurer fichier téléchargé est corrompu pas avant de flasher [modules Nexus] * Récupération flash standard ou sur mesure Firmware image de dispositif * Renommez le Recovery Restaurer le fichier présent sur certaines Stock Roms * Boot dans CWM Touch, TWRP ou reconstitution des stocks sans clignotant il [modules Nexus] * Boot ou des fichiers flash directement à partir de votre PC [modules Nexus] * Installation d'une apk ou plusieurs apk de votre appareil * Poussez les fichiers de votre PC vers votre appareil * Tirer des fichiers de votre appareil vers votre PC * Dump choisi logcat tampons sur votre PC * Dump BugReport à votre PC * Définir les permissions des fichiers sur votre appareil * Ouvrir un invite de commande pour la saisie manuelle * Dispositif de redémarrage à différents modes automatiquement * Affichage des informations importantes concernant votre appareil * Affichage de plusieurs écrans d'aide et d'information et de sauver une capture d'écran pour votre PC / envoyer à l'imprimante par défaut * Beaucoup de beaucoup plus de fonctionnalités --------------------- Périphériques pris en charge et dernière version supportée construit * ICI * --------------------- -------------------------------------------------- ------------ TELECHARGER LA SKIPSOFT ANDROID Unified OUTILS * ICI * (DE SKIPSOFT.NET) NOTE 2: Les fichiers exe ne sont pas signés numériquement avec un certificat Microsoft ils «peuvent» se ramassé comme potentiellement dangereux par les programmes antivirus et supprimé lors de la première course. Si cela se produit restaurer le fichier et l'exclure des analyses futures de l'utiliser. Cela semble se produire principalement sur AVG Free et Norton qui est pourquoi je suis passé à BitDefender qui est beaucoup mieux. Crédits: ChainsDD pour super-utilisateur, Chainfire pour SuperSU, Koush et l'équipe ClockworkMod pour MCG et le pack de pilotes universel, 1wayjonny pour le pack de pilotes adb / fastboot, Adam Lange pour tout son soutien et aider avec les noyaux d'insécurité, Viperboy pour la Knox Disabler application, Stephen Erickson pour la BusyBox installateur app, BurrowsApps pour l'application racine Checker, fOmey pour TWRP pour la vitesse Galaxy -------------------------------------------------- ------------ Quelle est la différence entre le public (FREE) et professionnelle (DON) VERSIONS? La version publique de La trousse comprend tout ce dont vous besoin de manipuler votre appareil. NO principales fonctions sont restreintes. Activation de la VERSION PROFESSIONNELLE ajoute la fonction plus utile dans le Toolkit, la possibilité de vérifier POUR «mises à jour automatiques» directement via la trousse et les avons envoyés à votre PC IMMÉDIATEMENT dès qu'ils sont téléchargés sans avoir à télécharger la Trousse ENTIER CHAQUE FOIS . Vous aurez toujours la dernière version QU 'IL EST MIS. CELA SIGNIFIE JOUR PETITS peuvent être envoyés plus souvent, comme l'ajout d'une fonction unique, correction d'un bug ou l'ajout de compatibilité pour un seul transporteur. LES MISES À JOUR PETITS sera compilé et publié à la communauté XDA en version complète (PUBLIC) de télécharger des versions très professionnel SONT TOUJOURS À JOUR PLUS TÔT. LA VERSION PRO ajoute également la possibilité de vérifier la dernière version DE super utilisateur, et de restauration des fichiers et télécharger directement à la trousse à outils. La section 'CHOIX RAPIDE "[/ B] vous permet de programmer jusqu'à 10 emplacements avec des tâches qu'il peut effectuer sur une base régulière ou JUSTE veulent garder un ensemble de tâches en 1 lieu. Ensuite, il suffit de sélectionner l'emplacement et il sera Rappelez-vous tous vos paramètres pour cette tâche et l'exécuter. Si vous trouvez ce programme utile Se IL VOUS PLAÎT un don à périphérique de votre choix pour obtenir un code d'activation pour le PRO VERSION. Vous trouverez les fonctions Pro très utile, Recevez des mises directement depuis le programme ET appuyer le développement futur. Sans développement des dons seront pas en mesure de continuer. LIENS AUTO réponse pour PAYPAL pour obtenir un code instantanément SONT DISPONIBLES SUR http://goo.gl/nyGqv -------------------------------------------------- ------------ 2. Utilisation de la trousse ANDROID UNIFIED Lors du démarrage de la boîte à outils vous devrez d'abord l'appareil que vous voulez travailler avec. Les fichiers outils de base sont inclus dans le package d'installation complet, mais si vous sélectionnez un périphérique puis les dossiers de travail seront créés et les fichiers de périphériques téléchargés. Une fois que les fichiers ont été extraits de la boîte à outils vous demandera si vous voulez vérifier si une mise à jour est disponible (pour les utilisateurs Pro à télécharger / installer). Si vous tapez «non», vous serez redirigé vers le modèle / Créer écran de sélection où vous pouvez faire un certain nombre de choses: Type '00' pour entrer votre code d'activation et activer les fonctions pro, 'i' vous passerez à la section Aide de l'information et, 'a' vous donnera des informations sur la façon d'ajouter le support pour une nouvelle construction, '99' vous passerez à la boîte à outils de base pour une utilisation rapide ou si vous ne disposez pas d'un périphérique pris en charge et que vous voulez effectuer des tâches générales android. Soutenu construit sont énumérés dans le modèle / Créer écran de sélection et en tapant le numéro associé (soit 11) téléchargera les fichiers de démarrage et de récupération nécessaires (stock et récupération personnalisée), puis vérifier et de télécharger la dernière récupération personnalisée et fichiers super-utilisateur disponible (versions pro ), vérifier tous les fichiers et lancer le menu principal. Vous pouvez maintenant utiliser toutes les fonctions et les outils les offres Toolkit Android. La section de l'information que vous pouvez obtenir à partir de l'écran de sélection du modèle ou dans le menu principal a une richesse d'aide et de questions fréquemment posées. Si vous avez besoin d'aide puis se il vous plaît regardez là avant de poser des questions dans le fil. -------------------------------------------------- ------------ INFORMATIONS UTILES Activer les options de développement pour le débogage USB Allez dans Paramètres, section Système, propos appareil et appuyez sur 'Build nombre "7 fois jusqu'à ce qu'il vous dit que vous êtes maintenant un développeur. Vous pouvez maintenant aller sur Paramètres, section Système, Options pour les développeurs et permettre USB debug. Comment passer en mode de récupération 1. Débranchez le câble USB. 2. Arrêtez le téléphone. 3. Maintenez les touches + "Volume Up '' Accueil 'et appuyez sur le bouton' POWER 'pendant environ 5 secondes pour entrer en mode de récupération. Comment entrer dans le mode de transfert (Pour Odin) 1. Débranchez le câble USB. 2. Arrêtez le téléphone. 3. Maintenez la «maison» + «DOWN volume» et appuyez sur le bouton 'POWER' pendant environ 2 secondes jusqu'à ce qu'un ATTENTION! Écran apparaît. Appuyez sur le bouton 'VOLUME UP »pour entrer dans le mode de transfert. -------------------------------------------------- ------------ ChangeLog Unifiée Android ToolKit v1.2.7 [Galaxy S5 V1.0.0] 16th Avril 2014 + Première version du module ToolKit Samsung Galaxy S5 libéré -------------------------------------------------- ------------ * AVERTISSEMENT * Je ne prends aucune responsabilité pour toute faute ou dommage causé par les procédures décrites dans ce guide. Aucune garantie de quelque nature que sont donnés. Modifié 30 octobre 2014 par MuayX10 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
heparti Posté(e) 30 octobre 2014 Share Posté(e) 30 octobre 2014 Merci pour cette traduction qui peut permettre d'utiliser plus sereinement ce toolkit. J'ai cependant une question : est-ce que le root par cette procédure modifie le knox à 0x1 ou reste-t-il à 0x0 ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
