[MPDC112] Read-only file system [Google Play]
Poulpyy77
Je n'arrive pas a installer le play store ca la memoir reste bloquer sur Read-only file system
Regardez par vous meme :
voici ce que j'ai quand je lance le RUNME.BAT
\bob\.android" /s /i /y
.android\adb_usb.ini
1 fichier(s) copié(s)
If next command hangs, then your MPDC88 is not detected
- make sure it is in USB debug mode
- make sure that you have installed the provided driver
- make sure that there is a copy of the provided .android folder in:
  C:\Documents and Settings\yourname          OR
  C:\Users\yourname                           OR
  C:\Utilisateurs\yourname
  ...depending on your version of Windows
--- waiting for device
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
--- remounting /system read-write
remount failed: Read-only file system
--- copying Phonesky.apk to /system/app
failed to copy 'Phonesky.apk' to '/system/app/Phonesky.apk': Read-only file s
em
--- correcting ownership
Unable to chown /system/app/Phonesky.apk: No such file or directory
--- correcting permissions
Unable to chmod /system/app/Phonesky.apk: No such file or directory
DONE.
Appuyez sur une touche pour continuer...
avez vous une solution pour installer le playstore ?
Merci d'avance.
Cordialement,
