nexus 7 ssd HS ?
ma nexus 7 cherie a commencer a bugger...
au redemarrage elle restait indéfiniment sur les 4 ronds de couleurs.
un redemarrage de plus et elle est passée en mode recovery...
ensuite juste le boot...
j'arrive via Nexus root toolkit a passer sur une custom recovery mais en temporary...
si j'essaie de faire un wipe j'ai le message:
E: could not mount /data
E: can't mount /cache/ recovery /command
E: can't mount /cache /recovery/log
etc...
je suis bien perdu la... pouvez vous m'aider ?
Merci de votre aide !
Merci de ta réponse !
voila ce que j'ai tenté
téléchargement de nakasi-ktu84p-factory-76acdbe9
téléchargement du sdk
ensuite: j'ai extrait le recovry.img du zip nakasi
D:\Users\famille\AppData\Local\Android\android-sdk\platform-tools\nakasi>fastboot devices
015d4a4eee5fec0d        fastboot
D:\Users\famille\AppData\Local\Android\android-sdk\platform-tools\nakasi>fastboot erase recovery
erasing 'recovery'...
OKAY [  0.032s]
finished. total time: 0.036s
D:\Users\famille\AppData\Local\Android\android-sdk\platform-tools\nakasi>fastboot flash recovery recovery.img
sending 'recovery' (5534 KB)...
OKAY [  0.714s]
writing 'recovery'...
OKAY [ 32.291s]
finished. total time: 33.010s
ensuite je tente un
fastboot -w update image-nakasi-ktu84p.zip
archive does not contain 'boot.sig'
archive does not contain 'recovery.sig'
archive does not contain 'system.sig'
archive does not contain 'vendor.img'
Creating filesystem with parameters:
    Block size: 4096
    Blocks per group: 32768
    Inodes per group: 8160
    Inode size: 256
    Journal blocks: 32768
    Label:
    Blocks: 7343872
    Block groups: 225
    Reserved block group size: 1024
Created filesystem with 11/1836000 inodes and 159268/7343872 blocks
    Block size: 4096
    Inodes per group: 7088
    Inode size: 256
    Journal blocks: 1772
    Label:
    Blocks: 113408
    Block groups: 4
    Reserved block group size: 31
Created filesystem with 11/28352 inodes and 3654/113408 blocks
Bootloader Version...: 4.23
Baseband Version.....: N/A
Serial Number........: 015d4aeeec5fec0d
checking product...
OKAY [  0.040s]
checking version-bootloader...
OKAY [  0.025s]
sending 'boot' (4994 KB)...
OKAY [  0.649s]
writing 'boot'...
et la ça patine sans rien faire ....
Modifié par taltosm
Bonjour, si tu as récupérer l'image officiel sur le site de Google (attention il y a 2 images différentes ne te trompe pas. Une pour la N7 (wifi) et une pour la N7 (mobile).
https://developers.google.com/android/
Dans l'archive tu as un fichier qui se nomme flashall.bat, il suffit juste de le lancer en invite de commande.
Envoyé depuis Tapatalk
Modifié par WillSGS
oui
https://dl.google.com/dl/android/aosp/nakasi-lrx21p-factory-93daa4d3.tgz
pour la nexus 7 wifi de 2012
et toujours le meme message:
D:\Users\famille\AppData\Local\Android\android-sdk\platform-tools\nakasi-lrx21p>flash-all.bat
(bootloader) Bootloader is already unlocked
OKAY [  0.016s]
finished. total time: 0.016s
erasing 'boot'...
OKAY [  0.031s]
finished. total time: 0.031s
******** Did you mean to fastboot format this partition?
erasing 'cache'...
OKAY [  0.094s]
finished. total time: 0.094s
OKAY [  0.047s]
finished. total time: 0.047s
erasing 'system'...
OKAY [  0.125s]
finished. total time: 0.125s
erasing 'userdata'...
OKAY [  4.937s]
finished. total time: 4.953s
sending 'bootloader' (2100 KB)...
OKAY [  0.266s]
writing 'bootloader'...
FAILED (remote: (InvalidState))
finished. total time: 0.406s
rebooting into bootloader...
OKAY [  0.016s]
    Block size: 4096
    Inode size: 256
    Label:
    Blocks: 7343872
    Block groups: 225
    Block size: 4096
    Inode size: 256
    Label:
    Blocks: 113408
    Block groups: 4
Serial Number........: 015d4a5efc5fec0d
checking product...
OKAY [  0.047s]
OKAY [  0.016s]
sending 'boot' (5146 KB)...
OKAY [  0.625s]
writing 'boot'...
OKAY [ 32.297s]
sending 'recovery' (5682 KB)...
OKAY [  0.687s]
J'ai des problèmes assez similaires... ça date depuis un moment et je me suis dit que je les réglerai avec lolipop qui devait sortir bientôt.
J'ai eu du mal à installer la dernière version de l'OS mais j'ai fini par y parvenir.
Malheureusement, les problèmes sont revenus... j'ai tenté de réinstaller encore mais maintenant je bloque.
Je mets les copies des messages ci-dessous.
Je pense que c'est le disque qui est mort mais je n'en suis pas sûr.
Impossible de réinstaller le bootloader et quand je reboote le bootloader via la commande fastboot, j'ai un périphérique "APX" qui apparaît dans ma liste et impossible de mettre à jour le driver (rien n'est reconnu) et le bootloader ne se lance pas.
Autre exemple, lorsque je lance le flashall.bat, je bloque en premier sur le reboot bootloader comme indiqué ci-dessus puis en redémarrant le bootloader avec la combinaison de boutons, je bloque sur le flash du recovery.
Par contre, si je lance la commande fastboot pour flasher le recovery ça passe sans problème !
Et maintenant... la copie des messages :
E:\Nexus\nakasi-lrx21p>fastboot -w update image-nakasi-lrx21p.zi
archive does not contain 'tos.img'
    Block size: 4096
    Inodes per group: 8192
    Inode size: 256
    Label:
    Blocks: 7503616
    Block groups: 229
Created filesystem with 11/1875968 inodes and 161774/7503616 blo
    Block size: 4096
    Inode size: 256
    Label:
    Blocks: 113408
    Block groups: 4
Serial Number........: 015d3248d917ee0f
checking product...
OKAY [  0.030s]
OKAY [  0.018s]
OKAY [  0.636s]
writing 'boot'...
OKAY [  0.981s]
OKAY [  0.708s]
FAILED (remote: (FileWriteFailed))
finished. total time: 7.092s
E:\Nexus\nakasi-lrx21p>fastboot flash recovery recovery.img
FAILED (command write failed (Invalid argument))
finished. total time: 0.015s
OKAY [  0.686s]
OKAY [  1.719s]
finished. total time: 2.406s
E:\Nexus\nakasi-lrx21p>fastboot flash system system.img
erasing 'system'...
OKAY [  2.517s]
sending 'system' (648787 KB)...
OKAY [ 78.517s]
writing 'system'...
finished. total time: 81.079s
Si vous avez une solution... merci d'avance !
Re,
Je réponds à mon dernier post... désolé
Je tente toujours de réinstaller Android sur ma N7 et maintenant quand je tente de mettre à jour le bootloader (tentative de repasser sur kitkat) j'ai un message en haut à gauche de l'écran de la tablette qui me dit "signature mismatch"
Donc je ne peux plus flasher mon bootloader et j'ai toujours les problèmes décrits précédemment
Serait-il possible que ce soit un virus ?
Est-ce la mémoire qui est HS ?
Je peux dire adieu à ma tablette ?
